POV-Ray : Newsgroups : povray.general : parse vs. render stages, and best use of memory Server Time
23 May 2024 02:43:29 EDT (-0400)
  parse vs. render stages, and best use of memory (Message 11 to 20 of 26)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: parse vs. render stages, and best use of memory
Date: 28 Jan 2018 08:04:42
Message: <5a6dca6a@news.povray.org>
Am 28.01.2018 um 13:32 schrieb clipka:
Having looked at the code again, I must correct myself:
> Whenever an object instance is inserted into the scene, some additional
> instantiations may also happen. For instance, if a primitive does not
> have an explicit texture, a texture will be instantiated as a copy of
> either the containing CSG's texture or the default texture.
When a primitive inside a CSG has no texture, the parser will /not/
create a new texture instance. Rather, the contained primitive will
share the texture with the containing CSG.
>> To 'muddy the waters' a bit (or  maybe not?), add something simple like a random
>> scale to the texture, in the first-example #while loop (just a typical
>> 'conceptual' example of a change.) Does this cause the texture itself to be
>> re-evaluated every time, and/or to require more memory?
>> #declare S = seed(123);
>> #declare C = 1;
>> #while(C <= 100000)
>> object{B texture (TEX scale .5 + .5*rand(S)} translate 1.1*C*x}
>> #declare C = C + 1;
>> #end
> No change in memory consumption there: Even without the transformation
> of the texture a copy is currently created.
While this statement is technically true, that's only because the object
itself is translated, which constitutes an implicit translation of the
texture. If the texture is transformed anyway, that implict translation
is "fused" into the texture's transformation block.
Date: 28 Jan 2018 08:44:00
Message: <5a6dd3a0@news.povray.org>
hi,
On 28/01/2018 12:32, clipka wrote:
thank you for the clear description of object instantiation and
life-time, and the rest.  invaluable.  it's the type of information that
would be good to have in the manual, perhaps a "the gory details" section?
regards, jr.
Date: 28 Jan 2018 09:25:12
Message: <5a6ddd48$1@news.povray.org>
Am 28.01.2018 um 14:43 schrieb jr:
I'd prefer to avoid that for now, at least in that level of detail, as I
consider the current state of POV-Ray's internal architecture to still
be in transition between pure C code and neat C++ code.
Date: 28 Jan 2018 14:05:00
Message: <web.5a6e1df2a3012ab7a47873e10@news.povray.org>
> Maybe it's worth first clearing up the term "evaluate".
Thanks for your detailed answer. I know it can't be easy to explain such an
'all-encompassing' question as mine-- particularly when I'm not being completely
clear with the proper terms to use (and I'm probably further confusing the issue
by discussing two different aspects of POV-ray as if they are one:
'instantiating' elements in a scene, and the operations performed during the
parse/render stages.) Honestly, I'm still 'groping my way through a fog' to
arrive at a proper set of intelligent questions ;-) And to fully understand some
of the details of your reply.
My use of the term 'evaluate' is probably a bit shabby and uninformed. What I
really mean is, 'where the hard time-consuming work is done.' For instance,
pre-#declaring an image_map for multiple use later: 'Evaluate' would mean,
'during the #declare step' (and the parse stage)... then it's simply
instantiated later, with no extra time-consuming work required during the parse
or render stages (a gross simplification of what really happens there.) In other
words, the greatest amount of time time is spent 'evaluating' that image_map
only once.
I obviously need a better phrase to describe that paradigm.
> Maybe what you mean is something I'd call "creating an instance" of, or
> just "instantiating", an object: Reserving a block of memory as required
> for a primitive of that particular type, and filling in the values
> required later during the render stage. This may include a few
> precomputed values, but for most primitives it is just the data
> specified in the SDL code.
Yes, that's basically it.
Subject: OT: How nice...
Date: 28 Jan 2018 14:25:44
Message: <5a6e23b8@news.povray.org>
How nice this Newsgroup is compared to most open forums and newspapers.
{I just felt like saying.}
Regards
Date: 28 Jan 2018 14:30:00
Message: <web.5a6e2432a3012ab7a47873e10@news.povray.org>
> Am 26.01.2018 um 22:22 schrieb Kenneth:
> > #declare C = 1;
> > #while(C <= 100000)
> > object{B texture TEX translate 1.1*C*x}
> > #declare C = C + 1;
> > #end
> (If I'm not mistaken you need curly braces around `TEX` when using it.)
I wasn't sure about that myself; you're right, it does need them.
Date: 28 Jan 2018 18:46:49
Message: <5a6e60e9$1@news.povray.org>
> only once.
In the case of an image_map, that image can be seen as a kind of
constant. It's a container of many values that are each constants by
themselves.
So, while the #declare don't actually evaluate anything in this case,
but only assign a name and some work space, it can be evaluated later.
In this case, it's more loading the image file, and usually decoding it,
that takes time. You can save a lot of time by attributing it to some
identifier to be used later in several places.
Same goes for a mesh or a complex blob object.
Subject: Re: OT: How nice...
Date: 29 Jan 2018 02:46:09
Message: <5a6ed141$1@news.povray.org>
I second that. I would have left long ago otherwise.
Date: 30 Jan 2018 15:35:00
Message: <web.5a70d604882c75ada47873e10@news.povray.org>
I just noticed that my original post's title has been changed here (in the
newsgroups' web interface, at least). What the...???   I had to look around to
find my own post!
When I look in 'Thread Digest', it has changed to "OT: How nice..." (!!) But if
I look in 'POV-Ray Topics/General', it has its original title of "parse vs.
render stages, and best use of memory."
Hmm. Some gremlins or leprechauns are having some fun somewhere...
Date: 30 Jan 2018 16:10:20
Message: <5a70df3c$1@news.povray.org>
> find my own post!
Oops! sorry. 'Twas I
If you look at the thread in a newsgroup reader. It is only a branch of
the thread that has that title. Replies to any other posts will gave
your original one.
I just wanted to commend the manners of the newsgroup.
Regards
