POV-Ray : Newsgroups : povray.general : The question about of projected through option Server Time
29 Apr 2024 03:25:30 EDT (-0400)
  The question about of projected through option (Message 3 to 12 of 22)
<<< Previous 2 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: The question about of projected through option
Date: 15 Dec 2017 10:41:05
Message: <5a33ed11@news.povray.org>
On 15/12/2017 15:08, William F Pokorny wrote:
> I know of no built in way to strictly get a conical light source where
> all the rays are at 45 degrees relative to some light source axis.
I thought you could but I can't get it to work.
Below is the code I got working for LH coordinates.
What puzzles me is that I had to rotate the light source by 180° to get
the light to show.
#version 3.6;
background { colour rgb <0.000,0.000,0.000> }
// referenced scene items and forced visible scene items declaration begin
#declare Blue_White_Tiles2 =
   checker
       colour rgbft <1.000,1.000,1.000,0.000,0.000>
     finish {
       ambient     rgb <0.100,0.100,0.100>
       brilliance  1.000
       crand       0.000
       diffuse     0.600
       metallic    0.000
       phong       0.000
       phong_size  40.000
       specular    0.000
       roughness   0.249
       reflection {
         rgb <0.100,0.100,0.100>, rgb <0.000,0.000,0.000>
         fresnel   0
         falloff   0.000
         exponent  1.000
         metallic  0.000
       colour rgbft <0.000,0.502,1.000,0.000,0.000>
     finish {
       brilliance  1.000
       crand       0.000
       diffuse     0.600
       metallic    0.000
       phong       0.000
       phong_size  40.000
       specular    0.000
       roughness   0.249
       reflection {
         fresnel   0
         falloff   0.000
         exponent  1.000
         metallic  0.000
   rotate    <0.0,0.0,180.000>
   rotate    <-90.000,0.0,0.0>
   scale     <-300.000,-300.000,-1000.000>
   rotate    <90.000,0.000,-180.000>
   rotate    <0.000,-180.000,0.000>
   scale     <0.010,0.010,0.010>
#declare Object1 =
torus {
   0.100000,0.050000
   sturm
   translate <0.000000,0.366564,0.000000>
}  // end Object1
#declare Camera0 =
   perspective
   location <-0.006,12.002,-10.392>
   up y
   right -1.333*x
   angle 33.000
   sky <0.000,0.655,0.756>
   look_at < 0.000, 0.000, 0.000 >
}  // end Camera0
// referenced scene items and forced visible scene items declaration end
light_source {  // Light_Source1
   < 0.000000, 0.000000, 0.000000 >, colour rgb <1.000,0.000,1.000>*10.000
   fade_power 0.000
   fade_distance 100.000
   media_attenuation off
   media_interaction on
   projected_through {Object1}
   rotate    <180.000000,0.000000,0.000000>
   translate <0.000000,1.275000,0.000000>
}  // end Light_Source1
union {  // Lights
   light_source {  // Shadowless_Light_Source0
     < 0.000000, 0.000000, 0.000000 >, colour rgb <1.000,1.000,1.000>
     fade_power 0.000
     shadowless
     translate <15.811000,100.000000,-200.977356>
   }  // end Shadowless_Light_Source0
   light_source {  // Light_Source0
     fade_power 0.000
     translate <-24.636320,55.859425,-195.075000>
   }  // end Light_Source0
   translate <0.000000,0.000000,-74.423000>
}  // end Lights
plane {  // Plane1
   y , 0
   texture{ Blue_White_Tiles2 }
   translate <0.000000,-1.964000,0.000000>
}  // end Plane1
camera{ Camera0 }
Regards
Date: 15 Dec 2017 11:05:05
Message: <5a33f2b1$1@news.povray.org>
Am 15.12.2017 um 16:40 schrieb Stephen:
It's not possible to limit the light source to rays at /exactly/ 45
degrees, as that would be an infinitesimally thin cone, and the
raytracing algorithm wouldn't catch any of the light (except by mere
coincidence).
To limit the light to, say, between 40 to 50 degrees, you could create a
spotlight with a 50 degree angle, and another spotlight with a 40 degree
angle and /negative/ brightness.
However, using a point light and a torus as a `projected_through` object
/should/ also work in principle.
Date: 15 Dec 2017 12:23:41
Message: <5a34051d$1@news.povray.org>
> coincidence).
Muddled thinking on my part.
It does, it gives a disk like beam. The code I posted on the duplicate
of this thread shows that.
But it did not until I rotated the the light source by 180°. Rotating it
by less than that makes it behave as if you are rotating a torch. It
gives an elliptical beam.
That puzzles me as it was a point source.
Regards
Date: 15 Dec 2017 12:35:05
Message: <web.5a3406f351d01bcdc437ac910@news.povray.org>
> coincidence).
Clever!  :)
I was thinking about using a point, or spotlight, and a CSG object - a box with
a conical cutout, and a smaller solid cone in front of it - forming a
cone-shaped void for the light pass through.
Also very clever  :)
From:   http://www.povray.org/documentation/view/3.7.0/316/
"Any textures or interiors on the object will be stripped and the object will
not show up in the scene."
Is that an accurate description?
I have questioned in the past if texturing could be stripped from objects so
that a later texturing could be used (overriding the prior texture), as I
believe Kenneth has as well.
If `projected_through` indeed works by this retroactive mechanism, then could
there possibly be an `override_texture` directive in the future?
Date: 15 Dec 2017 13:07:40
Message: <5a340f6c$1@news.povray.org>
Depends how you define accurate.  :-)
If you call the object as well as defining it. The textures are still there.
It would be good if it could be done.
Regards
Date: 17 Dec 2017 13:40:01
Message: <web.5a36b93051d01bcd89df8d30@news.povray.org>
That's an interesting concept: 'negative' light, to subtract from another light.
Such an idea never occured to me, one worth checking out; thanks.
Date: 18 Dec 2017 06:45:00
Message: <web.5a37a9c351d01bcdc32dd2d00@news.povray.org>
I appreciate for your kind advice.
I started pov-ray recently, so it takes some time to understand the all advice.
I would like to try the two way, projected through and spotlights.
The projected through puzzled me, so I have to consider.
There are two questions about using spotlight.
The reason why I place the 10 lights is that I want to know the response when
the light source moves in the depth direction, but I am very happy if the
reasonable result is obtained from the one light at first.
I post again the source code with object (hexagonal prism).
#include "textures.inc"
background{Black}
    location <0, -3, 0>
    right <-1.33, 0, 0>
    angle 40
    look_at <0, 0.5, 0>
//Object
object {
  prism {
    linear_sweep
    linear_spline
    0.
    1.
    7.
    <2,0>, <1,1.7320508>, <-1,1.7320508>, <-2,0>, <-1, -1.7320508>,
<1,-1.7320508>, <2,0>
       hollow
      material {
            pigment { rgbf<1.0, 1.0, 1.0, 0.7> }
            finish {
               specular 1
               roughness 0.001
               ambient 0
               diffuse 0
               reflection {
                  0.1
                  fresnel on
               conserve_energy
      interior {
         ior 1.458
         fade_distance 1.0
         fade_power 2
 //Source
 #declare r2 = seed(12345);
 #declare I = 0;
 #declare Number = 10;
 #while (I < Number)
 #declare A = rand(r2);
 #declare Object1 = torus {
                            0.1, 0.05
                            sturm
                            translate <0, A-0.1, 0>
 light_source {
        <0, A, 0>
        color
#declare I = I+1;
Masaki
Date: 18 Dec 2017 08:14:56
Message: <5a37bf50$1@news.povray.org>
Thanks for all of us.
There are a couple of things wrong with your scene. First, your lights
and objects are inside the Prism. So you will not see anything.
The Prism is 1 unit thick. So move it down a bit.
The camera is pointing the wrong way as the light source needs to be
above the projected through object. For the effect to work. Only where
the light rays hit the object will they be calculated. So multiply the
camera position by -1 * Y and maybe give it a little offset in the X or
Y direction.
There is no need to create so many lights and objects by putting them in
the loop. If you create then outside the loop then call or reference
them from inside the loop. It is more efficient, I am told.
> (1) How can I configurate the “negative” option?
Multiply the colour by -1.
> (2) Can the “negative” light distinguish the “positive” light completely?
> It seems that the “negative” light only weaken the positive light.
Yes, remember the lights value is not limited to 1
That sounds as if you want to make an animation.
Regards
Date: 18 Dec 2017 08:17:08
Message: <5a37bfd4$1@news.povray.org>
On 18/12/2017 13:14, Stephen wrote:
> So multiply the camera position by -1 * Y and maybe give it a little
> offset in the X or Y direction.
Oops! I use a LH co-ord system.
Should be: offset in the X or Z direction
Regards
Date: 18 Dec 2017 18:13:03
Message: <5a384b7f$1@news.povray.org>
light_source{Location rgb -1}
Any negative value mean a negative light. The intensity of a light can
have almost any value in a range of -1e12 to 1e12... And, if the light
is not white, a component can be negative while the others are positive
like rgb<-2, 1, 0.7>
It can totally suppress a normal light. It only need to have the same or
larger intensity.
In that case, it may be a good idea to use coloured lights. That way,
you'll be better able to distinguish them.
> background{Black}
> camera {
>      location <0, -3, 0>
>      right <-1.33, 0, 0>
>      angle 40
>      look_at <0, 0.5, 0>
> //Object
> object {//you don't need that object wrapper.
>    prism {
>      linear_sweep
>      linear_spline
>      0.
>      1.
>      7.
This risk been interpreted as 0.1, 7.0
Replace those dots with comas.
>         hollow
Not needed unless you plan adding some media. hollow is only meant to
allow an object to contain some media.
>        material {
>           texture {
>              finish {
>                 specular 1
>                 roughness 0.001
>                 ambient 0
>                 diffuse 0
>                 reflection {
>                    0.1
>                    fresnel on
>                 conserve_energy
>        interior {
>           ior 1.458
>           fade_distance 1.0
>           fade_power 2
For a material, you should use fade_power 1 or fade_power 1001 to get a
more realistic result.
fade_power 2 is for light attenuation over a distance in empty space.
If you want the light trajectory to show in that object, you need to
fill it with some scattering media. As it is now, the light can only
show at the surface. It's made impossible by the diffuse 0, meaning that
the surface don't diffuse any of the incoming light.
>   //Source
>   #declare I = 0;
>   #while (I < Number)
>                              0.1, 0.05
>                              sturm
You should make your torus much thinner. As it is now, the illuminated
areas from the various lights overlap a lot unless you are very close to
the torus.
#declare Object1 = torus{0.1, 0.002 translate <0, -0.1, 0>}
>   light_source {
>          <0, A, 0>
>          color
	rgb<rand(r2),rand(r2),rand(r2)>
Makes your lights multi-coloured
> #declare I = I+1;
> #end
> Regards,
> Masaki
