POV-Ray : Newsgroups : povray.general : Isofunctions and meshes Server Time
12 Jul 2025 21:19:14 EDT (-0400)
  Isofunctions and meshes (Message 5 to 14 of 24)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Isofunctions and meshes
Date: 1 Dec 2016 06:35:00
Message: <web.58400adcb9cec73de15d43a80@news.povray.org>
> Am 01.12.2016 um 11:34 schrieb John Greenwood:
> > Yes I think so. It seems that the x,y,z is needed when it is a function within a
> > function as in R_Surface.  I am nesting functions 5 deep and it looks like the
> > x,y,z needs to be "passed down" but I am not clear exactly what the rules are.
> > The x,y,z is a bit of clutter for the user.
> That shouldn't be the case -- unless the functions further down the
> rabbit hole actually try to access x,y,z.
> There's essentially just one special case with regards to x,y,z: If you
> specify a function without a parameter list, it will default to (x,y,z).
In the line:
  #declare R_Surface =
function(p,r,L,xo,yo,zo,x,y,z,Fm){R_S_function(p,x,y,z,((x*xo+y*yo+z*zo)/sqrt(pow(xo,2)+pow(yo,2)+pow(zo,2))
+L+Fm) /-r)}
Substituting R_function for R_S_function no longer works. I think this is
because Fm is a function that contains functions of x,y,z.
R_function works when it is at the bottom of the hole as in this example from a
previous post:
  #declare R_Object1 =
     function(x,y,z){
        R_Intersection(
                +R_function(p,(x  +(4)) /-r)
Date: 1 Dec 2016 06:52:30
Message: <58400efe$1@news.povray.org>
Am 01.12.2016 um 12:34 schrieb John Greenwood:
> In the line:
> +L+Fm) /-r)}
> previous post:
>      function(x,y,z){
>         R_Intersection(
Can you attach an example scene file in povray.binaries.scene-files?
Date: 1 Dec 2016 07:10:01
Message: <web.5840129bb9cec73d28cdfe180@news.povray.org>
> In the line:
> +L+Fm) /-r)}
This works:
  function(p, r, L, xo, yo, zo, x, y, z, Fm) {
    R_function(
      p,
      ((x*xo + y*yo + z*zo)/sqrt(pow(xo,2) + pow(yo,2) + pow(zo,2)) + L + Fm)/-r
Fm is not a function, it is a parameter that already contains a value when the
R_Surface function is evaluated, so x, y and z is not needed within the
R_Surface function for the purpose of calculating Fm.
Btw.:
If you do this:
#include "functions.inc"
Then you can replace this:
- with this:
f_r(xo, yo, zo)
Tor Olav
http://subcube.com
Date: 1 Dec 2016 11:00:00
Message: <web.58404720b9cec73de15d43a80@news.povray.org>
> This works:
>     R_function(
>       p,
> Btw.:
> If you do this:
> - with this:
> f_r(xo, yo, zo)
> Tor Olav
> http://subcube.com
Thanks for showing me this. I need to look at it more closely.
But what about the main question: can my function which, is a single closed
surface, be turned into mesh?
Date: 1 Dec 2016 14:50:00
Message: <web.58407e12b9cec73de83a01320@news.povray.org>
You are welcome.
Perhaps you can find something useful in this thread:
Subject: Isosurface Approximation macros rewrite
Date: 2008 February 22nd
Message: <47be20ab@news.povray.org>
Newsgroup: povray.binaries.scene-files
http://news.povray.org/povray.binaries.scene-files/thread/%3C47cc76fd@news.povray.org%3E/
Tor Olav
http://subcube.com
Date: 2 Dec 2016 08:05:01
Message: <web.584170a1b9cec73de15d43a80@news.povray.org>
>> can my function, which is a single closed surface, be turned into mesh?
> From: Tor Olav Kristensen
> Tor Olav
> http://subcube.com
I have had a look and am floundering.
An example would be worth ten thousand words.
Could some kind person point me at an actual example of converting a simple
function, such as:
    function(x,y,z){sqrt(pow(x,2)+pow(y,2)+pow(z,2))-L)/r }
into a mesh object?
Date: 2 Dec 2016 12:30:00
Message: <web.5841af1fb9cec73d6ebf07f0@news.povray.org>
> > Tor Olav
> > http://subcube.com
See the code below.
> function, such as:
> into a mesh object?
That function seemsto be missing a start parenthesis somewhere.
The code below uses a similar function.
Noe that this code also creates a file named triangles.inc that contains all the
triangles.
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7 ======= 8
// Other functions to experiment with
//#declare Fn = function { f_torus(x, y, z, 1, 0.4) }
//#declare Fn = function { y - sin(2*x*z)*cos(x*z) }
//#declare Fn = function { cos(2*pi*x) + cos(2*pi*y) + cos(2*pi*z) }
// A sphere with radius 1.8
// x^2 + y^2 + z^2 = 1.8^2
// (x^2 + y^2 + z^2)^(1/2) = 1.8
// (x^2 + y^2 + z^2)^(1/2) - 1.8 = 0.0
// The elaborate way
//#declare Fn = function(x, y, z) { sqrt(pow(x,2) + pow(y,2) + pow(z,2)) - 1.8 }
// A simpler way
#declare Fn = function { f_sphere(x, y, z, 1.8) }
#declare isoThreshold = 0.0;
// Set to yes to produce the approximation
// or to no for the actual isosurface
#declare approximateIso = yes;
// Set to yes to produce a smooth_triangle approximation
// or to no ro produce a flat triangle approximation
#declare isoSmooth = no;
// Controls the size of the cube that is beeing sampled
#declare R = 2.0;
#declare isoMin = -<1, 1, 1>*R;
#declare isoMax = +<1, 1, 1>*R;
// The resolution of the sampling in the x, y and z directions
#declare Resolution = 6;
#if (approximateIso)
  #declare Depth = 1; // Set to 0 for no recursion
  #declare isoSegs = <1, 1, 1>*Resolution;
  #declare isoFileOption = 1;
  #declare isoFile = "triangles.inc";
  #declare isoName = "Surface";
  #include "isosurface_kl_jf_tok.inc"
  object {
    Surface
    pigment { color rgb <1, 1, 1>*0.9 }
    finish {
      phong 0.5
      phong_size 10
#else
  isosurface {
    function { Fn(x, y, z) }
    max_gradient 8.0
    contained_by { box { isoMin, isoMax } }
    open
    finish {
      phong 0.5
      phong_size 10
#end // if
sky_sphere {
    function { abs(y) }
    color_map {
      [ 0.0 color rgb <0.0, 0.0, 0.6> ]
      [ 1.0 color rgb <1.0, 1.0, 1.0> ]
  location <1, 2, -4>*2*R
  look_at <0, 0, 0>
  angle 32
light_source {
  <1, 2, -1>*100
  color rgb <1, 1, 1>
  shadowless
light_source {
  <-1, -2, -1>*100
  color rgb <1, 1, 1>*0.5
  shadowless
Tor Olav
http://subcube.com
Date: 3 Dec 2016 05:00:01
Message: <web.584296c5b9cec73de15d43a80@news.povray.org>
> See the code below.
> > function, such as:
> > into a mesh object?
> triangles.
> // A simpler way
> #declare R = 2.0;
>   object {
>     Surface
>     finish {
>       phong 0.5
>       phong_size 10
> #else
>   isosurface {
>     max_gradient 8.0
>     open
>     finish {
>       phong 0.5
>       phong_size 10
> #end // if
> sky_sphere {
>   pigment {
>     function { abs(y) }
>     color_map {
> camera {
>   look_at <0, 0, 0>
>   angle 32
> light_source {
>   <1, 2, -1>*100
>   color rgb <1, 1, 1>
>   shadowless
> light_source {
>   <-1, -2, -1>*100
>   shadowless
> Tor Olav
> http://subcube.com
Thanks I will have a go.
Date: 3 Dec 2016 07:30:00
Message: <web.5842b5f4b9cec73de15d43a80@news.povray.org>
snip
> > Tor Olav
> > http://subcube.com
I have had a go and it works!
This is a great help for composing rounded objects. By reducing the resolution
to 5(and ignoring the artifacts) and putting isoSmooth = no, the render time is
4 seconds, AND I can have muliple views, almost essential for creating 3D
objects.
A single isosurface rendering took 88 seconds
I understand that with a mesh object I can change the colour locally. This will
be much better for introducing lip colours and rosy cheeks in this example.
Thanks
John
(I have posted the result in povray.binaries.images/ but am not clear if and how
to make it appear here)
Date: 4 Dec 2016 14:15:00
Message: <web.58446a6bb9cec73d9c5d6c810@news.povray.org>
If by a link...?
http://news.povray.org/web.5842b2dd261ae99ae15d43a80%40news.povray.org
That object to mesh stuff is fascinating, unfortunately I'm terrible with
meshes. And not so good with isosurfaces either. LOL
Looks like you got a fair result. When I tried the in-pov converting from Chris
Young I was getting inner CSG surfaces found until changing from unions to
merge. Something I hadn't expected. No idea what could happen with isosurfaces
based on that.
Wish you luck.
