POV-Ray : Newsgroups : povray.general : Cannot get scene bright enough Server Time
14 Jan 2026 18:58:13 EST (-0500)
  Cannot get scene bright enough (Message 1 to 9 of 9)
Subject: Cannot get scene bright enough
Date: 23 Feb 2016 04:25:01
Message: <web.56cc22d1f8726f01a6a5f510@news.povray.org>
I have a hard time getting a brighter result. What I've achieved so far:
http://blackbox.diitstudio.com/download/result.png
I use radiosity without conventional lights, and use sky_sphere:
sky_sphere {pigment {color rgb <3.16, 3.56, 4>}}
I don't want (direct) sunlight and want to leave the radiosity parameter
brightness at 1 if possible.
For most objects I use a "flat" finish:
finish {diffuse 0.6 phong 0}
Is the dark image a result of not using a light source? Or am I forgetting to
set something in the finish/texture?
Even adding an ambient value of 0.5 to the finish doesn't make it any brighter.
Any help is appreciated.
Dick
Subject: Re: Cannot get scene bright enough
Date: 23 Feb 2016 04:54:15
Message: <56cc2c47$1@news.povray.org>
Is there a reason you don't want to use a brighter sky_sphere? eg:
sky_sphere {pigment {color rgb 5*<3.16, 3.56, 4>}}
Date: 23 Feb 2016 04:55:00
Message: <web.56cc2ac61c25b418a6a5f510@news.povray.org>
BTW: what I'm really asking is how to let the materials reflect more light, so
the total scene becomes brighter.
In this next example I multiplied the sky_sphere color with 4:
http://blackbox.diitstudio.com/download/result2.png
Now the bright areas "wash out". This is best seen in the treshold and the frame
of the doorway, while the area around door and window becomes much brighter, the
rest of the interior stays dark, as is rather noticable for table and chairs.
Date: 23 Feb 2016 05:06:13
Message: <56cc2f15$1@news.povray.org>
> Hi,
> far: http://blackbox.diitstudio.com/download/result.png
> parameter brightness at 1 if possible.
> For most objects I use a "flat" finish: finish {diffuse 0.6 phong 0}
   If you don't use reflection, then raise the diffuse to 1.
> forgetting to set something in the finish/texture?
   I guess what you want is more light bounces... what is your
recursion_limit? To me it looks like you have currently only 2... better
raise it up to 3 or even 4.
> brighter.
   BTW, do not EVER use ambient if you want realistic results.
jaime
Date: 23 Feb 2016 09:46:01
Message: <56cc70a9$1@news.povray.org>
Am 23.02.2016 um 11:06 schrieb Jaime Vives Piqueres:
>> brighter.
That's ok. I presume Dicko is using a "#version 3.7" statement, in which
case "ambient" is de-activated anyway when radiosity is enabled ;)
Date: 23 Feb 2016 11:25:13
Message: <56cc87e9$1@news.povray.org>
Exactly what material definition have you got for the walls and ceiling?
Date: 23 Feb 2016 14:58:36
Message: <56ccb9ec@news.povray.org>
> Hi,
> Regards,
> Dick
Why use a sky_sphere for a plain, uniform colour. Beter to use
background{ rgb <3.16, 3.56, 4>*Intensity } in this case.
When using the current version (3.7) and radiosity, ambient is set to
zero everywhere. If you want luminous surfaces, use emission. This will
make the texture actualy emit light. An emissive texture should have a
lower diffuse than normal.
You can make your background even brighter by multiplying it's colour by
some value.
recursion_limit default to 2. You may want to increase it to 3 or 4, or
even 5. Going above 5 will usualy have negligeable effect.
You may increase the diffuse value somewhat. Try 0.8 to 0.9. You should
not use diffuse 1 if you want to get realistic results.
Date: 27 Feb 2016 01:39:10
Message: <56d1448e$1@news.povray.org>
Reminds me for my earlier problem: I used the old, almost obsolete
"ambient" instead of the new, better "emission".
>>> brighter.
Date: 21 Mar 2016 07:00:00
Message: <web.56efd3221c25b4185a83e4510@news.povray.org>
Hi all,
Thanks for all your answers.
I was away for a while, so that's why you did not get any reaction from me.
I will try your suggestions in the coming days and will let you know the
results.
Regards
Dicko
