POV-Ray : Newsgroups : povray.general : how to make a revolution plot from a parametric function? Server Time
14 Jan 2026 23:31:12 EST (-0500)
  how to make a revolution plot from a parametric function? (Message 1 to 8 of 8)
Subject: how to make a revolution plot from a parametric function?
Date: 2 Jun 2014 18:10:01
Message: <web.538cf5fb7c057d0c1e36f4d20@news.povray.org>
Is it possible to create a revolution plot directly from a parametric function?
For example, I have a 2d parametric function
x[u]=Cos[u]*(1 + 2 Cos[2 u])
y[u]=Sin[u]*(1+2Cos[2 u])
and the function looks like this when plot of u from 0 to pi
http://imgur.com/nfEAOs8
how can we rotate it around the x axis and make it into a revolution plot like
this
http://imgur.com/7MWbnT2
Thanks for the help in advance.
Subject: Re: how to make a revolution plot from a parametric function?
Date: 5 Jun 2014 03:40:00
Message: <web.53901d8135ccce6fbe7517870@news.povray.org>
In this case, yes.
Since x = rcos(theta) and y = rsin(theta) in standard polars, your parametric
equations are just saying
r   = 1+2cos(2theta)
    = 1+2cos^2(theta)-2sin^2(2theta)
    = 3cos^2(theta) - sin^2(2theta)
    = (3x^2 - y^2)/r^2
r^3 = (3x^2 - y^2)
Square to pick up the negative r lobes
r^6 = (3x^2 - y^2)^2
In 2D
(x^2+y^2)^3 = (3x^2 - y^2)^2
To go to 3D, to be axi-symmetric around the x axis, replace y^2 with y^2+z^2.
Replacing x^2 by x^2+z^2 would be axi-symmetric around the y axis. A similar
shape, but the large lobe rotates to a "disk".
#declare surftest =
isosurface {
 function { pow(x*x+y*y+z*z,3)-pow(3*x*x-y*y-z*z,2)}
// evaluate 356*Min_factor,  sqrt(356/(356*Min_factor)),  0.7
 max_gradient 1500
 all_intersections
 contained_by { sphere { 0 3}}
 clipped_by {box {-3 3}}
 pigment {Red}
 finish { phong 0.6 reflection 0.2 }
object{surftest }
background{White}
light_source { <20,20,20> color 1}
camera{location <0, 0, 20> look_at <0, 0, 0> angle 40}
Produces the surface.Note the rather large max_gradient. For a while, with
smaller max_gradient, I wasn't getting anything.
Thanks,
JimT
Date: 5 Jun 2014 12:50:15
Message: <53909fc7$1@news.povray.org>
> #declare surftest =
> isosurface {
>   max_gradient 1500
>   all_intersections
>   pigment {Red}
> JimT
A simplification when using evaluate:
sqrt(356/(356*Min_factor)) = sqrt(1/Min_factor)
In this case, the following should work correctly and should be faster:
#declare Min_factor = 0.6;
evaluate 1500*Min_factor,  sqrt(1/1Min_factor),  0.7
Date: 6 Jun 2014 10:40:01
Message: <web.5391d25035ccce6f1e36f4d20@news.povray.org>
> In this case, yes.
> r   = 1+2cos(2theta)
>     = (3x^2 - y^2)/r^2
> r^3 = (3x^2 - y^2)
> In 2D
> #declare surftest =
> isosurface {
>  max_gradient 1500
>  all_intersections
>  pigment {Red}
> object{surftest }
> background{White}
> Thanks,
> JimT
Thanks. That's very helpful.
But can we get the most outer surface of the plot? I mean can we make the
surface into a single solid object without all the internal structures?
And what does this line mean "evaluate 356*Min_factor,
sqrt(356/(356*Min_factor)),  0.7" ?
Date: 8 Jun 2014 18:24:19
Message: <5394e293$1@news.povray.org>
>> In this case, yes.
>> r   = 1+2cos(2theta)
>>      = (3x^2 - y^2)/r^2
>> r^3 = (3x^2 - y^2)
>> In 2D
>> #declare surftest =
>> isosurface {
>>   max_gradient 1500
>>   all_intersections
>>   pigment {Red}
>> object{surftest }
>> background{White}
>> Thanks,
>> JimT
"evaluate 356*Min_factor, sqrt(356/(356*Min_factor)),  0.7" is an
alternate manner to account for the max_gradient value of your function.
In effect, it allow the used max_gradient do dynamicaly change during
the trace within some limits.
The first value is a starting gradient value. It should be somewhat
smaller than the found max_gradient.
The second value is a ovder-evaluation factor. It controll how fast the
gradient used is allowed to increase. This value must be larger than 1.
It can be simplified as sqrt(1/Min_factor)
Lastly, is the under-evaluation factor controlling how fast the gradient
is allowed to fall. "0.7" is a good starting value.
After rendering without setting max_gradient, you take note of the found
max_gradient from the message window (for the Windows and Mac versions,
messages stream on Linux).
You use that value in place of the "356" of that example.
It's very usefull when you have several isosurfaces placed with a #while
loop, using slight variations, variously scalled, rotated and translated
and you have messages for both to large AND to small max_gradient values
at the same time...
Date: 8 Jun 2014 21:50:02
Message: <web.5395121035ccce6f1e36f4d20@news.povray.org>
> >> In this case, yes.
> >> r   = 1+2cos(2theta)
> >>      = (3x^2 - y^2)/r^2
> >> r^3 = (3x^2 - y^2)
> >> In 2D
> >> #declare surftest =
> >> isosurface {
> >>   max_gradient 1500
> >>   all_intersections
> >>   pigment {Red}
> >> object{surftest }
> >> background{White}
> >> Thanks,
> >> JimT
> at the same time...
> Alain
In the rendered plot, we can see through the object and see multiple surfaces.
Can we make the iosurface into a solid object? I mean can we plot the out most
surface only?
Thanks.
Best,
xslittlegrass
Date: 9 Jun 2014 19:58:08
Message: <53964a10@news.povray.org>
> surface only?
> Thanks.
> Best,
> xslittlegrass
If you want to see any internal surfaces or structure you need to use a
transparent texture.
Unless the surface have any transparency, you'll only see the very first
surface that the tracing ray encounter. In this case, any internal
structure won't be computed as no ray ever reatches them.
In the provided example, the center lobe will be visible if you apply a
rotation around the X axis because it's effectively located outside of
the space defined by the rotation of the end lobes.
Date: 13 Jun 2014 09:00:01
Message: <web.539af54735ccce6fbe7517870@news.povray.org>
> surface only?
As Alain says, unless you make the object transparent in some way, you are
seeing only the outer surface. The statement
pigment{Red}
uses a simple solid red colour.
If you are asking to get rid of the central 'disk' which comes from a negative
value for r in the polar plot, you can use
function { pow(x*x+y*y+z*z,3/2)-(3*x*x-y*y-z*z)}
in the isosurface block. This renders slightly quicker.
Thanks,
JimT
