POV-Ray : Newsgroups : povray.general : Radiosity causing black blotches Server Time
1 Nov 2024 03:18:39 EDT (-0400)
  Radiosity causing black blotches (Message 1 to 6 of 6)
Subject: Radiosity causing black blotches
Date: 15 Oct 2013 13:40:01
Message: <web.525d7d3048a8dee7ff8aba140@news.povray.org>
I am experiencing some weird artifacts with radiosity, namely black blotches. I
know this is a pretty standard problem, but all solutions I found recommend
changing the error bound etc which I think I've done correctly yet I still get
the artifacts. I am using povray 3.7.
       global_settings { assumed_gamma 1 radiosity {             // --- Settings
3 (high quality) ---
    pretrace_start 0.08
    pretrace_end   0.005
    count 400
    error_bound 0.01
    recursion_limit 1
    nearest_count 20
#include "colors.inc"    // The include files contain
location < -100,240,-20>
look_at  <0.0,20,0>
//angle 8.7
focal_point <0,20.0>
    blur_samples 80
 sphere{<100,100,0> 20 finish{emission 40} pigment{White} hollow}
plane {
        <0, 1, 0>, -3
        pigment{color <1,1,1>}
        finish { reflection {0.5} ambient 0.0 diffuse 1 specular 0 brilliance 0}
        no_reflection
Subject: Re: Radiosity causing black blotches
Date: 15 Oct 2013 15:30:00
Message: <web.525d96e39410ac961c7cb8080@news.povray.org>
>     pretrace_start 0.08
>     pretrace_end   0.005
>     count 400
>     error_bound 0.01
>     recursion_limit 1
>     nearest_count 20
> camera {
> look_at  <0.0,20,0>
> //angle 8.7
>     blur_samples 80
> plane {
>         <0, 1, 0>, -3
>         no_reflection
Sorry, here's an even simpler working example that reproduces my problem, this
time even using just povray's default config:
#include "rad_def.inc"
global_settings {
   radiosity {
      Rad_Settings(Radiosity_OutdoorHQ,off,off)
look_at  <0.0,20,0>
 sphere{<100,100,0> 20 finish{emission 1} pigment{White} hollow}
plane {
        <0, 1, 0>, -3
        finish { reflection {0.5} ambient 0.0 diffuse 1 specular 0 }
        no_reflection
Date: 15 Oct 2013 20:20:28
Message: <525ddbcc$1@news.povray.org>
Scenes using emissive objects as illumination source are always delicate
to configure.
Try this:
#version 3.7;
//#include "rad_def.inc"
	radiosity {
     pretrace_start 0.08
     pretrace_end   0.005
     count 10000 990000
     error_bound 0.3
     recursion_limit 1
     nearest_count 20 3
#default{radiosity{importance 75/10000}}
// count will tend, on average, toward 75 for most of your scene.
look_at  <0.0,20,0>
sphere{<100,100,0> 20 finish{emission 10} pigment{White}
radiosity{importance 1}}
// VERY high sampling of your emissive sphere
importance set to allow adaptive sampling.
This allow you to set count to some very large values and keep rendering
speed acceptable
by having most of your scenes objects to have more reasonable sampling
plane {
         <0, 1, 0>, -3
         finish { reflection {0.0} ambient 0.0 diffuse 10 specular 0 }
Date: 16 Oct 2013 16:50:01
Message: <web.525efbc39410ac96e71ca80c0@news.povray.org>
> to configure.
> Try this:
> #version 3.7;
>  radiosity {
>      pretrace_start 0.08
>      pretrace_end   0.005
>      count 10000 990000
>      error_bound 0.3
>      recursion_limit 1
>      nearest_count 20 3
> camera {
> look_at  <0.0,20,0>
> speed acceptable
> plane {
>          <0, 1, 0>, -3
> Alain
Thanks, Alain, that showed some improvement. However I am still getting weird
artifcats, although more subtle ones. Here is a scene with your suggested
improvement, however you can still see black rings on the halo of the sphere
across the plane. I feel like I am missing something in this radiosity
buisness..
 radiosity {
     pretrace_start 0.08
     pretrace_end   0.005
     count 10000 990000
     error_bound 0.3
     recursion_limit 1
     nearest_count 20 3
location < -100,40,-20>
look_at  <0.0,20,0>
 sphere{<100,60,0> 20 finish{emission rgb<1,1,1>} pigment{White} hollow
plane {
        <0, 1, 0>, -3
        finish { reflection 0.5 ambient 0.0 diffuse 1 specular 0 phong 1 }
        no_reflection
Date: 17 Oct 2013 03:22:03
Message: <525f901b@news.povray.org>
> buisness..
I once had a similar issue with horrible black circles inside a bit of
furniture I was modelling. That's when someone introduced me to mcpov -
I've never looked back.
mcpov can be found easily via Google, it's an unbiased patch for POV
v3.6. That means the resulting render always tends to *exactly* the
physically correct value over time, no need to fiddle with any radiosity
parameters or worry about artefacts.
The main downsides are that you can't use any new v3.7 features,
including multi-core rendering (so you need to run several instances and
then average the results), and that you cannot use point light sources,
you need to use physical geometry as light (not such a big issue as it
sounds). There's also a minor bug with the brightness of pigments, but
that is easy to compensate for in your code.
Hopefully there will be an unbiased patch for v3.7 soon - I think
someone is working on it... :-)
Date: 19 Oct 2013 20:18:21
Message: <5263214d@news.povray.org>
> buisness..
>   radiosity {
>       pretrace_start 0.08
>       pretrace_end   0.005
>       count 10000 990000
>       error_bound 0.3
>       recursion_limit 1
>       nearest_count 20 3
Try using a larger second parameter here. It may help.
> camera {
> look_at  <0.0,20,0>
>   sphere{<100,60,0> 20 finish{emission rgb<1,1,1>} pigment{White}// hollow
> plane {
>          <0, 1, 0>, -3
>          no_reflection
Your emissive sphere don't need the hollow modifier as it don't contain
any media.
Try using a smaller value for the radiosity's adc_bailout. It dafault to
0.01/2 (or 0.005).
Try something like 0.003 or less.
It's a parameter that's often overlooked and can make a huge difference
when you use emissive objects to illuminate your scene.
