POV-Ray : Newsgroups : povray.general : Same pov file and different result (with HDR) Server Time
30 Sep 2024 10:19:37 EDT (-0400)
  Same pov file and different result (with HDR) (Message 1 to 10 of 10)
Subject: Same pov file and different result (with HDR)
Date: 28 Jul 2011 10:05:00
Message: <web.4e316b7b630a1fa94c0a951f0@news.povray.org>
Dear POVRay users,
when I put sky sphere (with HDR file) + reflective box (with gif texture file) +
reflective/refractive mesh2, the rendering results are different even they are
generated from the same pov file. Is this usual or am I missing something?
Thanks
Subject: Re: Same pov file and different result (with HDR)
Date: 29 Jul 2011 17:58:10
Message: <4e332cf2$1@news.povray.org>
> Dear POVRay users,
> Thanks
Can you post a small sample scene that show your problem?
Many users can provide their own HDR and image map.
If the mesh2 is large, use a symplified/largely decimated one.
If the sanple scene is relatively small (under 5K), you can post it
here. For larger ones, you can use povray.text.scene-files or
povray.binaries.scene-files.
Make sure that you use spherical mapping for your HDR image. Add
map_type 1 to your pigment.
Is your mesh2 closed?
Date: 31 Jul 2011 06:50:01
Message: <web.4e3531c76c7c55c24c0a951f0@news.povray.org>
Alain <aze### [at] qwertyorg> wrote:
> > Dear POVRay users,
> > Thanks
Yes, it is closed. I tested with a simple object (ovus) as well, and the same
problem existed. I post the simple test pov-file:
#version 3.7;
global_settings {
  assumed_gamma 1.33
  max_trace_level 30
  radiosity {
    count 200
    error_bound 0.1
    recursion_limit 2
    nearest_count 8
    brightness 1
    normal on
    adc_bailout 0.005
#declare CamPos = <0.72, 1.52, 3.2>;
#declare CamLookAt = <0.2, 0.5, 0.8>;
  right -x*image_width/image_height
  location CamPos
  look_at CamLookAt
#declare F_Water = finish {
  ambient 0
  diffuse 0
  phong 1
  phong_size 90
  reflection {0.1, 1 fresnel on}
  conserve_energy
#declare F_Plane = finish {
  phong 0.37
  phong_size 25
  ambient 0
  reflection 0.05
#declare T_Water = texture {
  pigment { rgbf <0.98, 0.98, 0.98, 0.98> }
  finish {F_Water}
#declare T_Plane = texture {
  pigment { rgb<0.6, 0.3, 0.5> }
  finish {F_Plane}
#declare I_Water = interior {
  ior 1.33335
  fade_power 1
#declare M_Water = material {
  texture {T_Water}
  interior{I_Water}
#declare Water = ovus {
  0.2, 0.1
  translate -y*0.04
  material {M_Water}
#declare Thickness = 0.025;
#declare Table = box {
  <-2, -Thickness, -2>, <2, -Thickness*4, 2>
  rotate y*-49
  texture { T_Plane }
light_source {CamPos color rgb<0.9, 0.9, 1>*0.1}
sky_sphere {
  pigment {image_map {hdr "*HDR_FILE_PATH.hdr*" map_type 1 interpolate 2}}
  rotate y*-120
union {
  object {Table}
  object {
    Water
    translate <0, 0.5, 0.5>
The table is always differently rendered with some jitters.
Date: 31 Jul 2011 09:25:46
Message: <4e3557da$1@news.povray.org>
Le 31/07/2011 12:45, kiwon nous fit lire :
Confirmed... using classical kitchen_probe.hdr... when more than 1
working thread.
using +wt1 removes the difference (but it is still sensible to +BS(int)
+RP(int) +RS(int) (Block Size, Render pattern, Render step)
Looks like some code is using a global resource, unprotected (like a
random generator ?)
Date: 31 Jul 2011 14:04:53
Message: <4e359945@news.povray.org>
> working thread.
> random generator ?)
There is a note about radiosity that say that *exact* reproduction is
NOT guaranteed from render to render when using radiosity.
It seems to be because radiosity use some montecarlo approximation and
some other pseudo-random sequences.
There is a flag that can be set to increase the similarity. It will tend
to slightly increase the rendering time.
Date: 1 Aug 2011 01:00:01
Message: <web.4e3632936c7c55c24c0a951f0@news.povray.org>
Is this always correct even when I do not use the HDR image?
Kiwon
Date: 1 Aug 2011 11:00:34
Message: <4e36bf92$1@news.povray.org>
Yes, it is due to radiosity. HDR has nothing to do with it.
	Thorsten
Date: 2 Aug 2011 07:55:01
Message: <web.4e37e5516c7c55c24c0a951f0@news.povray.org>
Thanks. This sounds like that it isn't a good choice to use radiosity for
animation. Huh?
Kiwon
Date: 4 Aug 2011 18:34:11
Message: <4e3b1e63@news.povray.org>
Am 31.07.2011 15:25, schrieb Le_Forgeron:
> random generator ?)
Possibly the radiosity sample cache; for pretrace efficiency, this is
shared among all threads, with the effect that a sample at a certain
point may or may not be taken depending on whether another thread has
already taken samples nearby or not.
You may try using +HR (or "High_Reproducibility=on"); this will
essentially prevent re-use of radiosity samples taken for a different
render block in the same pretrace pass (with certain well-controlled
exceptions), so that the radiosity pretrace always produces the very
same set of samples regardless of thread scheduling and number of render
threads. It is slower though.
At present this option affects only radiosity sampling; however, the
idea is for the option to eliminate any non-determinisms in render
artifacts (there still are some, but I never found the time to hunt them
down yet) by throwing a moderate deal of extra computing effort at them
if they can't be avoided otherwise.
Date: 4 Aug 2011 18:50:09
Message: <4e3b2221$1@news.povray.org>
Am 02.08.2011 13:53, schrieb kiwon:
> animation. Huh?
If you want to do radiosity in animations, make sure to use very
high-quality settings to minimize any radiosity artifacts (which of
course requires high render times, which you'll usually want to avoid in
animations).
If your animation is limited to changes in camera perspective you can
mitigate this drawback by re-using the radiosity samples from frame to
frame. You may even get away with lower quality settings if you do two
passes of the animation, one for collecting radiosity samples to cover
all camera angles (this can be a low-resolution pass rendering only
every N-th frame) and one for the actual render. (Without the first pass
you might see some flickering at the border of areas the camera sees for
the first time).
