POV-Ray : Newsgroups : povray.general : Brick texture Server Time
11 Oct 2025 05:22:47 EDT (-0400)
  Brick texture (Message 1 to 5 of 5)
Subject: Brick texture
Date: 6 Apr 2011 11:25:01
Message: <web.4d9c857533d7c5e4413a4eea0@news.povray.org>
Im trying to create a brick texture on a house shaped box but am having trouble:
this is the code for my box (without trying to add brick texture)
box { <-Hx,0,1>,< Hx,Hy,9>
      texture { pigment{ color White}
                finish { phong 1}
              } // end of texture
      scale <1,1,1> rotate<0,0,0> translate<0,0,0>
    no_shadow
and i have been trying to put one of the following examples in
http://www.povray.org/documentation/view/3.6.0/368/
but keep getting declared errors and have no idea what to do, can anyone help?
Subject: Re: Brick texture
Date: 6 Apr 2011 13:38:45
Message: <4d9ca525@news.povray.org>
> box {<-Hx,0,1>,<  Hx,Hy,9>
>                  finish { phong 1}
>                } // end of texture
>        scale<1,1,1>  rotate<0,0,0>  translate<0,0,0>
>      no_shadow
In your code, you have the following user variables: Hx, Hy, White.
The variable "White" is declared in colors.inc. It's not initialised by
default.
You need to include that file as follow:
In that file, it's defined as:
#declare White   = rgb 1;
If it's the only colour you use, you can add just that #declare to your
code.
Place that line early in your code before you use any colour name.
Hx and Hy are also user variable. You need to explicitely #declare them
before you use them.
#declare Hx = 23;
Keep in mind that anything starting with an UPERCASE character is always
a "user" variable. You may declare it yourself, or have it declared in
some include file.
Date: 7 Apr 2011 10:10:00
Message: <web.4d9dc4ea4eb3ea1b413a4eea0@news.povray.org>
The hy, hz, and hx are defined sizes, as its a for a house. and the white
statement works, but that is not the issue the whole statement works and brings
a white box, but want i want is to add somewhere in this statement (instead of
white) a brick looking texture but not sure where or what im doing wrong (only
with the brick texture not what i already have)
> >                  finish { phong 1}
> >                } // end of texture
> >      no_shadow
> default.
> code.
> #declare Hx = 23;
> some include file.
> Alain
Date: 7 Apr 2011 18:22:50
Message: <4d9e393a$1@news.povray.org>
brick should then replace White in the pigment.
In 2.5.11.5, COLOR_1 and COLOR_2 are place holders. You must supply one
pigment for each. If you don't set these, you get redish bricks with
gray mortar.
Minimal sample:
texture{ pigment{ brick } }
Sample:
texture{ pigment{ brick Aquamarine Firebrick brick_size <7,1,7> mortar 0.1}
  finish{diffuse 0.76 ambient 0.02 phong 0.4 phong_size 100}
Date: 8 Apr 2011 05:25:52
Message: <4d9ed4a0$1@news.povray.org>
>                  finish { phong 1}
>                } // end of texture
>      no_shadow
Time ago I made a brick texture based on Philippe texture (sorry, I
didn't remember the original post, it was a nice plane full off pebbles).
// Texture begin here
#declare t_brick_space=texture{
	pigment{color rgb <200,90,10>/255}
	finish{diffuse .65}
	normal{granite .6 scale .4}
#declare t_brick=texture{
	pigment{color rgb <188,67,8>/255}
	finish{
		diffuse .7
		roughness .15
	normal{
		average
		normal_map{
			[1.00
			boxed 1
			poly_wave .3
			slope_map{
				[0.00 <0,0>]
				[0.02 <0,0>]
				[0.02 <0,.5>]
				[0.6 <1,0>]      // Increase or decrease the bump
			[1.00 granite .15 ]
#declare t_wall=texture{
	boxed
	poly_wave .3
	texture_map{
		[0.00 t_brick_space]
		[0.05 t_brick_space]
		[0.05 t_brick]
		[1.00 t_brick]
	warp{planar}
	rotate -90*x
	scale 0.5
	translate <.5,0,.5>
	warp{repeat 1.05*x}
	warp{repeat 1.05*z offset .5*x}
	scale 0.4*z  // Change here brick props
	#local tseg_Warp_scale=1.3;
	scale tseg_Warp_scale
	warp{
		turbulence <.3,1.5,.3>*.1 //Some turbulence
		octaves 4
		lambda 1.5
	scale 1/tseg_Warp_scale
	scale 0.3
	rotate 90*x
// Texture end here
Example:
box{<-2,0,-0.2> <2,2,0.2> texture{t_wall}}
With some adjustments you can obtain something similar to bricks.
Paolo
