POV-Ray : Newsgroups : povray.general : UV map image interpolation not achived Server Time
19 Nov 2025 08:33:59 EST (-0500)
  UV map image interpolation not achived (Message 1 to 3 of 3)
Subject: UV map image interpolation not achived
Date: 26 Jan 2011 07:25:01
Message: <web.4d401231d44cecd45994def70@news.povray.org>
I added a wood image over a big floor mapping a texture. The code of my material
is:
material {
    uv_mapping pigment {
      image_map {
        tiff "wood.tif"
        interpolate 2
    finish {
      ambient 1
      diffuse 1
Texture repeats over the floor, and the result is ok in near distances, but
jittering appears in texture when distance increases.
I tried changing interpolation value, and using 0 (no interpolation), 2 or 4
always render the same image...
What can be the cause of interpolation failing?
Thanks for your help.
Subject: Re: UV map image interpolation not achived
Date: 26 Jan 2011 08:57:03
Message: <4d40282f$1@news.povray.org>
I think you're confusing texture interpolation with mipmapping. Texture
interpolation, what "interpolate" does, is only visibly if 1
texture-pixel (texel?) fills more than 1 screen-pixel (screxel?).
Mipmapping (not natively supported by POV-Ray) kicks in when the
opposite is true.
It is possible to simulate mipmapping in POV-Ray, but it's not very easy
and doesn't work under all circumstances. It's much easier (but possibly
much slower) to just use higher anti-aliasing settings.
ZK
Date: 26 Jan 2011 17:32:52
Message: <4d40a114$1@news.povray.org>
> is:
> material {
>    texture {
>        image_map {
>          tiff "wood.tif"
>          interpolate 2
>      finish {
>        ambient 1
>        diffuse 1
What you see is caused by the details of your image becoming to small,
sub pixel. In that case, anti-aliasing is often not enough.
You can hide it by using gocal blur. Use a small aperture value, less
than 1% of the camera-focal point distance. As the camera get jittered
around, it will catch and average those very small, sub pixel, details.
