POV-Ray : Newsgroups : povray.general : <no subject> Server Time
30 Sep 2024 16:17:40 EDT (-0400)
  <no subject> (Message 1 to 5 of 5)
Subject: <no subject>
Date: 10 Dec 2010 05:35:00
Message: <web.4d0200c5c23a6d986a0ac3f0@news.povray.org>
I try to render a room using Povray v3.6.1.
I have some issues remaining about rendering with and without radiosity.
I included 2 pov files one with, one without radiosity. Of course I get 2
different results. Which is nice but just a few minor(maybe major) glitches
remain to achieve more of povray's true potential.
My questions are
in sample Without radiosity-----
1- the wall to the right is dark, how can this be corrected? I tried using
   shadowless keyword, this caused more problems eg. taking phong and shineness
   away, leaving a matt and dull looking picture. Without shadowless some areas
   remain in the dark. Should I use more than one light?
2- the sink could be made look more metallic, how can this be achieved? Is my
   usage of METAL5.jpg correct for this purpose? I want metals to look like
   metals, not grayish. Like the metals I see in Jaime's renderings.
in sample with radiosity-------
walls look better, how can I correct the rest of these isuues?
1- sink still is not metallic
2- the painting on the wall looks like it lost some of its shininess or
   ambience value same maybe true for cabinet doors since they use jpegs too.
I appreciate any help, I am really stuck on these for some time. I hope I was
able to explain what I need, Like everyone else I want the best result Povray
can offer with the materials I use.
Thanks  a lot.
here you can find the relevant files
http://www.kitchendesigned.com/tmp/render_settings.zip
Subject: Re: <no subject>
Date: 10 Dec 2010 06:32:41
Message: <4d020fd9$1@news.povray.org>
Am 10.12.2010 11:30, schrieb optima:
Unfortunately, the files don't render (missing include files), and the
bmp files included don't seem to match your problem description (I don't
see any signs of radiosity in what claims to be the output of the
radiosity version, for instance).
Most importantly you should place your light someplace where it will
illuminate the whole room. If you cannot, then feel free to use as many
light sources as you like. (Make sure however to reduce them in
brightness as you add more.)
For metallic surfaces, using "reflection { 1.0 metallic }" should get
you started. Make sure you have something to be reflected in the scene.
Is the painting behind glass? In that case, you may experience a known
bug of POV-Ray 3.6.
Date: 10 Dec 2010 12:22:16
Message: <4d0261c8@news.povray.org>
> Hi,
> My questions are
You may need more lights.
Shadowless light_source effectively don't cause any highlight. This is
by desing. A shadowless light purpose is to act as a fill light, not as
the main illumination.
To improve your scene, you should take a look at fading lights.
You enable it by adding: fade_power 2 fade_distance Some_Distance
When rendering an inside scene, it can realy improve the result.
I don't think that any image_map is a viable solution to make any
surface look metallic. No image_map can include the correct reflections.
Your code:
//begin SINK
#include "evye_22_POV_geom.inc"union{
#declare evye_223_size = max_extent(evye_22_) - min_extent(evye_22_);
#declare evye_223 = object {evye_22_ translate -min_extent(evye_22_)
scale <1/evye_223_size.x, 1/evye_223_size.y, 1/evye_223_size.z> scale
<60,25,40>}
object { evye_223 translate -x * 60 pigment {uv_mapping image_map {jpeg
"METAL5.jpg"}scale 1 }
finish {phong 1 ambient 0.6 reflection 0.08}}
  rotate y * 0 rotate x * 0 rotate z * 0 translate <-213.5,64.5,152.5>}
//end SINK
You have a tyni amount of reflection and a huge ambient. Reduce the
ambient to less than 0.1 and increase the reflection in the 0.6..0.95 range.
Adjust the phong value and use phong_size to get satisfying highlight.
The default phong_size probably gives highlights that are to broad.
Start round 200 and you probably need to go up from there.
ADD the metallic keyword.
You may remove the image_map and replace it with a plain pigment.
Anyway, metal5.jpg is essentialy monochrome.
For the radiosity, you should remove any ambient component from your finish.
For the finishes that don't include ambient, you should add:
#default{finish{ambient 0}} early in the scene.
The picture on the wall seems to have to much reflection.
If you use high ambient objects to illuminate your radiosity scene,
those will NOT cause any highlight, only a light_source can do that.
Keep the light(s) or add some reflection to your shiny surfaces.
> Thanks  a lot.
You can use #if(Use_Rad)...#else...#end and #declare Use_Rad = on; and
#declare Use_Rad = off; to turn radiosity on and off.
That way, you only need a single scene file and don't need to copy your
changes from one file to the other. In the long run, you'll simplify
tour task.
Remember that any texture with an ambient different than zero will shed
light on it's surrounding when you use radiosity.
Nobody can do a test render as you don't include some of the images needed.
There are also asome missing inc file:
stdinc.inc
model_101_POV_geom.inc
k_model_1_POV_geom.inc and possibly some others...
Another thing:
It's a bad practice to use full paths in your scene, as even if we have
all the needed files, we don't have them in your path structure...
I may have the krem.jpg file, but not in:
"D:\\OPTIMA\\optima\\bin\\v2\\Textures\\ODA\\DUVAR\\krem.jpg"
Date: 11 Dec 2010 06:10:00
Message: <web.4d035b706f92e8565ea5bd3c0@news.povray.org>
Hi Clipka,
if you tell me the missing file names I will upload them too. Thanks for your
suggestions I 'll try them and see what happens. I am pretty excited about
Povray. I wanna see it produce beautiful pictures by the standards of 2010 and
live upto its proud heritage.
I only wish I could do more for Povray but my interior design app uses Povray as
the renderer and this you can be sure makes alot of people know Povray.
thanks a lot
PS : but due to my inabilities we dont want them to think badly of Povray.
Appreciate any help.
Date: 11 Dec 2010 06:20:00
Message: <web.4d035d446f92e8565ea5bd3c0@news.povray.org>
Alain ,
thank you so much,
I apologize for uploading missing files and full path names for jpegs.
I will try to learn from yours and Clipka's ideas and I won't make the above
mistakes in my next post.
thanks again
optima
