POV-Ray : Newsgroups : povray.general : hang on render Server Time
11 Apr 2026 05:38:38 EDT (-0400)
  hang on render (Message 1 to 7 of 7)
Subject: hang on render
Date: 28 Jul 2010 21:40:00
Message: <web.4c50dab1e61329d79e1c416d0@news.povray.org>
I've been attempting to model a 3d attractor in povray using the following code.
#declare Delta_T = 50000;
#declare T1 = 500000;
#declare T0 = T1 - Delta_T;
union {
#local pA = <3.0, 6.9, 4.2>;
#local Aleph = 0;
#while(Aleph <= 1000)
#debug concat(str(Aleph,0,0), "\n")
#local nA = <pA.x*pA.z*sin(.3*pA.x)-cos(.2*pA.y),
               pA.y*pA.x*sin(.5*pA.y)-cos(.4*pA.z),
               pA.z*pA.y*sin(.7*pA.z)-cos(.6*pA.x)>;
#local pA = nA;
sphere { pA, 0.05 }
#local Aleph = Aleph + 1;
I'm using a default pigment atm to lower the memory requirements, but it still
hangs after calculating all the positions.  I know it's looping through all the
calculations because of the debug statement, so I can't figure out why it hangs.
 my only thought is that it's trying to create bounding boxes for thousands of
tiny objects and having a conniption.
At the current setting of 1000 it hangs for several hours and does nothing. can
anyone advise me on this?
I'm running 3.7 beta 35 on a fujitsu lifebook with Ubuntu lucid and KDE
A.D.B.
Subject: Re: hang on render
Date: 29 Jul 2010 07:15:52
Message: <4c5162e8$1@news.povray.org>
didn't hang for me, however when i substituted:
#debug concat(vstr(3,pA,",",0,4), "\n")
into the code the vectors are ALL coming back as nan,nan,nan
Jim
Date: 29 Jul 2010 07:29:28
Message: <4c516618$1@news.povray.org>
Am 29.07.2010 03:34, schrieb Anthony D. Baye:
Doesn't sound anywhere close to convincing: A lousy 1000 spheres is
nothing POV-Ray should have any trouble to bounding, and memory
consumption is no higher than ~230 MByte (30 MByte more than what seems
to be basic overhead), and both parsing and rendering times are sane on
my machine (okay, it's an Intel i7 Quad with 6 GB RAM, but still...)
As it seems, the problem is rather that your attractor isn't very
attractive: It marches off to infinity after ~10 iterations, and /that/
is apparently giving POV-Ray the bends ("try bounding /this/!").
BTW, for saving some memory (and possibly also speed up rendering) you
may want to try using a blob instead of a union.
Date: 29 Jul 2010 12:30:01
Message: <web.4c51ac0acb6ca2759e1c416d0@news.povray.org>
> Jim
The problem might be an inferior school laptop, it is only a 32-bit machine.
When I try it on my desktop machine (Mac G5 quad-core 64-bit OS 10.4.11) it
seems to run, but I still get no good image. I have to use 10.6 because the new
beta only runs under 10.5+, apparently.
maybe it's something with beta 35a specifically, but I can't think what.
as for the attractor, I got the math from this site:
http://softologyblog.wordpress.com/category/chaos/page/2/
it's the Rampe3 Attractor.
A.D.B.
Date: 29 Jul 2010 12:37:22
Message: <4c51ae42$1@news.povray.org>
kind of doubt it ...
Nevertheless ... I'd check the math. I agree with clipkas' follow up (I
ran again and scrolled back farther) ... good luck ;-)
Date: 30 Jul 2010 04:18:58
Message: <4c528af2$1@news.povray.org>
Am 29.07.2010 18:27, schrieb Anthony D. Baye:
The site mentions that starting values should be initialized to <0,0,0>;
other values may give "sane" sequences as well, but according to the
formulas virtually anything outside the range <-2,-2,-2> to <2,2,2>
(with possible exceptions very close to the coordinate axes) /will/
"explode" right away. So while the formula seems ok, your starting point
<3.0,6.9,4.2> is definitely not.
Date: 30 Jul 2010 04:55:03
Message: <4c529367$1@news.povray.org>
Am 30.07.2010 10:18, schrieb clipka:
The choice of the a,b,c,d,e,f parameters seems crucial, too: Even with
<0,0,0> as the starting point, the chosen values make the sequence
"explode" within a few iterations, while a=-.3 instead of +.3 already
makes a significant difference (though the result is still dull, but
that's a different story).
