POV-Ray : Newsgroups : povray.general : Problem with scattering media and .png alpha channel Server Time
10 Jan 2025 12:49:39 EST (-0500)
  Problem with scattering media and .png alpha channel (Message 1 to 8 of 8)
Subject: Problem with scattering media and .png alpha channel
Date: 1 Jun 2010 21:25:01
Message: <web.4c05b266f96fcb534fb7f0280@news.povray.org>
I have the following sphere:
 sphere
 { 0,1 pigment { rgbt 1 } hollow
   interior
   { media
     { scattering { 3, <.3,.1,.1> }
       density
       { spherical density_map
         { [0 rgb 0]
           [.5 rgb .2]
           [1 rgb .5]
  scale 1.1
if I use no background and render using +fn32 no media effect is visible.
Doesn't happen when I use a black background. Is there any way to solve this?
Subject: Re: Problem with scattering media and .png alpha channel
Date: 1 Jun 2010 21:46:28
Message: <4c05b7f4$1@news.povray.org>
Am 02.06.2010 03:22, schrieb MadKairon:
Be aware that the value behind "+fn" does not specify the bits per
/pixel/, but rather the bit depth of each /color channel/; i.e. "+fn32"
would correspond to 96 or 128 bits per pixel (depending on whether you
choose alpha transparency or not).
I guess what you really want is "+fn8 +ua".
Date: 1 Jun 2010 22:10:01
Message: <web.4c05bd0bf0ecff7f4fb7f0280@news.povray.org>
Nope, here's a simple scene:
background{Black}
  angle 20
  location<0,2,-10>*1
  look_at<0,0,0>
light_source { <10, 20, -10> color White }
 sphere
   interior
   { media
     { emission 1
       density
         { [0 rgb 0]
           [0.4 rgb <1,0,0>]
           [0.8 rgb <1,1,0>]
           [1 rgb 1]
try using +fn8 +ua, first render as I posted it and then coment the second line
and see what happens :(
Date: 2 Jun 2010 00:47:38
Message: <4c05e26a@news.povray.org>
  Which version of POV-Ray are you using? Note that there are still some
issues with POV-Ray 3.7 beta regarding the +ua functionality.
Date: 2 Jun 2010 05:59:38
Message: <4c062b8a@news.povray.org>
Am 02.06.2010 04:08, schrieb MadKairon:
I see what you mean.
This is a general problem with transparency handling and emissive media
(and also the scattering portion of scattering media):
The transparency model used in the PNG file format allows only
/blending/ of image color and whatever background the image is to be
displayed on. That is, if you have 100% of the background colour, you
necessarily have 0% image colour, and vice versa.
Emissive media, however, just /adds/ light without taking from the
background. That is, it would require 100% of the background colour and
100% image colour.
Some image file formats (such as OpenEXR) theoretically don't have this
limitation, as they are specified to use a different transparency model,
but many applications seem to apply the wrong transparency model to
these. As a matter of fact POV-Ray is still one of them.
As it happens, the next beta will include a change to make it behave
properly regarding output of OpenEXR, and will also get input files of
that type (and others using that transparency model) mostly right.
(There are still bottlenecks with input files due to conversions between
the transparency models, which cause trouble when transparency is
/exactly/ 100%.)
Thus, when using PNG output file format and/or the current beta, the
only option you have is to introduce a good deal of absorption to make
the emissive media show at all.
With future betas, you may want to try OpenEXR output instead, if that
is an option for you. (You'll still have to add a /bit/ of absorption
though if you should happen to plan on using it as a texture in POV-Ray.)
Date: 2 Jun 2010 06:30:01
Message: <web.4c063281f0ecff7f4fb7f0280@news.povray.org>
> 100% image colour.
> /exactly/ 100%.)
Ah :( thanks. Using 3.7 beta 37. Guess I need some other way of simulating
athmosphere for planets I want to use on GIMP later. Any good ideas?
Date: 2 Jun 2010 07:20:52
Message: <4c063e94$1@news.povray.org>
Am 02.06.2010 12:29, schrieb MadKairon:
Render the scene two times: Once with +UA, once with -UA (and a black
background).
Take the +UA render, and - preserving transparency - paint it
pitch-black. Use this as a layer in front of your intended background
image, with standard blending mode. This will suppress the background
image where the opaque parts of the planet will go.
Take the -UA render, and put it in front of the other layers, using
whichever GIMP layer blending mode will cause it to be /added/ to the
layers below.
This should work even with scattering media (which has both
emission-like and absorption-like components).
Date: 2 Jun 2010 12:10:01
Message: <web.4c068228f0ecff7f4fb7f0280@news.povray.org>
> background).
> layers below.
Thanks for the tip, will try it.
