POV-Ray : Newsgroups : povray.general : How to render a realistical raindrop on a leaf surface? Server Time
10 Jan 2025 13:01:41 EST (-0500)
  How to render a realistical raindrop on a leaf surface? (Message 1 to 7 of 7)
Subject: How to render a realistical raindrop on a leaf surface?
Date: 27 May 2010 06:40:00
Message: <web.4bfe4add49e4350e1524ae1d0@news.povray.org>
Hi, guys,
Nowadays I have rendered a scene of raindrops on a leaf surface with Pov-Ray for
windows. And now I get a rendering result which you can see at this web page:
http://cid-ad5320bb5424a20c.skydrive.live.com/self.aspx/raindrop%20rendering/raindrops265.png.
(Sorry for that I can put up an attachment for my first time to this newsgroup)
Generally speacking, this result of raindrop rendering has a long distance from
the realistical appearence. You can see the raindrops on the leaf has an ugly
reflection and they are not transparent enough. However many papermeters of drop
material have been modified several times, but I can't get a satisfying result.
Therefore, here I ask for your help for how to render this scene for a
realistical result? How to set the papemeters for drops meterial?
The following is my parameter setting for drop:
material {
      texture{
           pigment{Clear}
           finish{
                reflection {0.1,0.3}
                conserve_energy
                ambient 0 diffuse 0
                specular 0.8 roughness 1/1000
       interior {
        ior 1.33
Expect your answer sincerely.
Thank you.
Subject: Re: How to render a realistical raindrop on a leaf surface?
Date: 27 May 2010 07:03:27
Message: <4bfe517f$1@news.povray.org>
On 05/27/2010 07:35 AM, Dream wrote:
> material {
>       texture{
>            pigment{Clear}
>            finish{
>                 conserve_energy
>                 ambient 0 diffuse 0
>        interior {
>         ior 1.33
I think diffuse 0 is part of your problem and perhaps roughness. larger
value for roughness makes the the specular bloom more (wider) and
smaller roughness makes it more like pinpoint. once you get that
straightened out be aware of the problem that co-incident surfaces can
cause.
Date: 27 May 2010 07:11:18
Message: <4bfe5356$1@news.povray.org>
> cause.
oops ... forgot to add this:
http://wiki.povray.org/content/Knowledgebase:Language_Questions_and_Tips#Topic_20
Date: 27 May 2010 08:57:57
Message: <4bfe6c55$1@news.povray.org>
> cause.
Coincident surfaces was my first thought as well.  Something else I see
are the harsh shadows from the raindrops.  A dark shadow underneath the
raindrop could cause a similar effect.
Date: 27 May 2010 09:49:34
Message: <4bfe786e$1@news.povray.org>
Le 27/05/2010 12:35, Dream a écrit :
> Hi, guys,
What about the max trace level (global at scene level) ?
A: Because it messes up the order in which people normally read text.<br/>
Q: Why is it such a bad thing?<br/>
A: Top-posting.<br/>
Q: What is the most annoying thing on usenet and in e-mail?
Date: 27 May 2010 10:05:01
Message: <web.4bfe7b1fb728abee1524ae1d0@news.povray.org>
> > Hi, guys,
Hi, the max trace level  is 50, and the "reflection" and "refraction" are both
"on".
Date: 27 May 2010 11:20:02
Message: <web.4bfe8ce5b728abee1524ae1d0@news.povray.org>
Thank you all for your kindly reply.
The problem has been fixed by mainly two adjustment:
1. Make the raindrop nether surface a bit higher than leaf upper surface. Before
this operation I had made a mistake for an opposite direction.
2. Remove the shadow of raindrop.
Thank you all again.
