When I open the door of cabinet, say 45o, the cabinet is pushed back along z
axis. If the door is closed, zero rotation, problem disappears. So it has to do
something with rotations inside a union of 5-6 objects.
I guess the object order or rotation placement is wrong in the Union.
I couldn't figure out the solution, if someone was kind enough to offer some
help, I will appreciate it very much. Thanks a lot.
Why is the cabinet on the right is pushed back when its door is opened?
sample is at http://www.kitchendesigned.com/download/handle.zip
Ibrahim Dogan
> Hi,
> Ibrahim Dogan
It realy look like a bad grouping of the union's components.
The door's rotation should ONLY affect the door itself and any element
that are ON the door.
You need to use nested unions.
Your union *should* look like:
union{// First, the "static" objects
object {Cabinet rotate Some_Rotation translate Some_position}
union {// then the door and components.
object{Door}
object{Door_handle}//things that must moove with the door
onject{Door_Decorations}
rotate Door_opening translate Door_Location
Note: The door and it's handle and decoration can be defines as a
complete object:
#declare Door_Complete =
union{object{Door}object{Handle}object{Decorations}}
It's best to declare the door with the AXIS of it's hinges along the Y
axis. It will be much easier to place it.
Alain, thank you for your response, I appreciate it. I think you are right it is
a bad Union strategy I employ in my sample. Instead of only the door rotating,
the whole object moves. I will work on it some more and let you know when I
have it working right. Thanks again.
Ibrahim
I took 3 different approaches to the problem with no success. Let me define the
problem in simpler terms for everyone to grasp at first look.
How do we rotate 2 combined objects (door and handle) inside a Union?
I tried
1- #declare Door_Handle =
union{object{Door}object{Handle}}
// as a separate object
2- another union (for door and handle) inside the main union
3- everything in a single union (with door and handle rotated)
in all 3 cases the cabinet moves back by a visible margin.
I'm stuck, I want to do it in a single or 2 nested unions. What can I do?
Thank you, any kind of help will be appreciated a lot.
I got it with the code shown below, thank you. I hope this is the best way to
assemble a cabinet in povray code. I extracted the solution from povray's
woodbox sample. Alain's help was encouraging also.
#declare door = object{ model_101_ scale <0.01,0.01,0.8> scale
<49.4999961853027,75,1> translate <25,-1,61> pigment {image_map {jpeg
"A333_bergama.jpg"} scale 1} finish {phong 1 ambient 0.6 reflection 0.08}
translate -<0,47.5,60> rotate y*-0 translate <0,47.5,60>
#declare handle = object {k_model_1_ pigment {image_map {jpeg "A316_wenge.jpg"}
scale 1}
scale <0.1,0.1,0.1> rotate z*0
translate <3,62,64>finish {phong 1 ambient 0.3 reflection 0.3}//a2
#declare cabinetcase = union{
object{ BOX scale <50,2,60> translate <25,0,0> pigment {color rgb <1,1,1>}}
object{ BOX scale <2,73,58> translate <49,37.5,2> pigment {color rgb <1,1,1>}}
object{ BOX scale <2,73,58> translate <1,37.5,2> pigment {color rgb <1,1,1>}}
object{ BOX scale <50,73,2> translate <25,37.5,0> pigment {color rgb <1,1,1>}}
}//close union
//FINALLY PUT EVERYTHING TOGETHER
union {
object { cabinetcase }
object { door }
object { handle }
translate x*62 rotate -y*35
This translate should be used to align the door relative to the Y axis.
Remove this line.
A rotation here will only rotate the door. It will not affect anything
attached to it.
----> don't rotate here!
Make sure that one edge, preferably the hinge axis, of the door lies ON
the Y axis.
> scale 1}
This must be located relative to the door at it's starting location.
> }//close union
> union {
> object { door }
> object { handle }
This rotation will affect EVERYTHING in the union and make it orbit
around the origin. Very probably the cause of your unexpected movements.
New union:
union{
union{ // for the door itself
object { door }
object { handle }
rotate Door_Opening
// This will rotate ONLY the door and it's decorations
// To place the door at it's final location
rotate Cabinet_Rotation
// To align the cabinet to a wall or some thing
translate Cabinet_Location
// Final placement of the whole cabinet
Remember to rotate THEN translate.
If you translate then rotate, the rotation will cause the object to
change position. Usefull if you want to place several objects in a circle.
Alain, thank for your explanatory answer, a few points remain
1 - With the code below I cant open the door, where to place the opening code?
<49.4999961853027,75,1> translate <25,0,61> pigment {image_map {jpeg
//translate -<0,47.5,60> rotate y*-0 translate <0,47.5,60>
//> This must be located relative to the door at it's starting location.
scale 1}//a1
translate <47,62,64>finish {phong 1 ambient 0.3 reflection 0.3}}//a2
//translate -<0,47.5,60> rotate y*-0 translate <0,47.5,60>}//b2
//New union:
union{
object { door }
object { handle }
rotate y*45 //Door_Opening
translate -<0,0,0>//Door and Handle Location
rotate y*0//Cabinet_Rotation
translate <-0,0,0> rotate <0,0,0>//Cabinet_Location
2 - You say,
the Y axis. How, I don't get it? I guess because of that the above union don't
work.
3 -You say
Is it better to use min max extent for final placements?
#declare CentrePoint = (min_extent( altdolap1kpk2 )+max_extent(altdolap1kpk2
))/2;
object { altdolap1kpk2 translate -CentrePoint rotate <0,0,0> translate
<-170.5,47.5,134.5>}
Thank you million times.....
Normaly, I make the following assumptions:
The y axis is vertical.
The x-z plane is the reference plane. The base level of the top surface
of the floor.
Not assumptions:
With that, furnitures are defined with all Y coordinate been zero or
positive. You don't need to translate then to place them on the floor.
Free standing object are idealy defined centered around the Y axis. We
instinctively see them rotate around ther center.
Doors are beter defined with an edge along the Y axis.
Traps with an edge along the X or Z axis. We naturaly see them as
rotating around an axis.
Big furnitures, such as cabinets with the back side along the X-y or the
Z-Y plane, centered on the Y axis. To make them easier to place along
the walls.
This is NOT the place from where you open the door. This is the place
where you define the door at it's starting location and orientation.
If you have several doors, you don't always want all of them to open the
same way at the same time. Say you have 10 Large cabinets, each with
with 10 identical doors and you want to open only one of them, or have
some doors opened, but at different angles, if you set the opening here,
you'll have some problem: 99 doors that you want closed will open.
> scale 1}//a1
You open the door in the following location.
I prefer to use a variable to set the angle of the opening.
#declare Door_Opening = <0,45,0>;
OR
#declare Door_Opening = 45*y;
> //New union:
> union{
> object { door }
> object { handle }
> 2 - You say,
> work.
If the door is not defined with an edge ON the y axis, it will orbit
around the y axis.
> 3 -You say
> ))/2;
No. Not in this case. As the cabinet itself is defined at a known
location in a known orientation, you don't need to find it's location.
Idealy, you defined the cabinet with it's base on the x-z plane and
centered around the y axis, or with one corner along that axis.
As you used a box as the base, all it's edges are parallel to the axis.
If that's the case, you don't need to translate along the y axis unless
you want to place it on some raised or sunked part.
You only need to move it to place it along some wall.
min_extent() and max_extent() are mostly usefull when you are not sure
of the dimentions and placement of an object and want to place it
precisely along other objects,
One of your problem seems to be that the door is not defined with one of
it's edge ON an axis. You should then translate the door once in it's
definition to acheive that alighment.
You can use max_extent(Door) and min_extent(Door) to find the bounding
box of the door. From that, you can find the edge that should be used as
the rotation axis to use to open the door.
It's probable that the x-y part of min_extent correspond to the corner
that interest you. If you translate by -min_extent(Door), the bottom,
front left corner will be moved at <0,0,0>.
You can do this after Door have been defined:
#declare Door = object{Door translate -min_extent(Door)}
A side note: When, in an CSG operation, you have several objects that
share the same plain pigment, it's beter to apply that pigment to the
whole thing instead of applying it to each component.
It's easier to read and maintain. A component that have it's own texture
is then obviously a part that have a different texture than the rest.
Alain, thanks to you and your samples, I got the door to rotate correctly with
the code below.
//DECLARE DOOR AND HANDLE, (case is defined separately "altdolap1kpk")
#declare model_101_ = object{ model_101_ scale <0.01,0.01,0.8> }
#declare k_model_1_ = object {k_model_1_ scale <0.1,0.1,0.1> }
//PLACE CABINETS IN SCENE
union{
object { altdolap1kpk }
union{
object { model_101_ scale <39.4999961853027,75,1> translate <20,0,61> pigment
{image_map {jpeg "Blue.jpg"} scale 1} finish {phong 1 ambient 0.6 reflection
0.08} }
object { k_model_1_ rotate z*0 translate <37,62,64> pigment {image_map {jpeg
"a700.jpg"} scale 1} finish {phong 1 ambient 0.3 reflection 0.3} }
translate -<0,47.5,60> rotate y*-0 translate <0,47.5,60>}//ROTATE DOOR
translate -<0,0,0> rotate <0,0,0> translate -<0,0,0>//TO ROTATE WHOLE CABINET
translate <-50,0,0>}
Thanks to everybody helping me before the DOOR problem is solved with above
code. Now I got a second problem, I want to rotate the cabinet on its on y axis
(turn left or right) but it orbits again. I can only rotate objects on their y
axis 90-180-270 degrees cause I change their width and depth values with each
other in the translate statement. But I know this is wrong...
How do I rotate my cabinet or any object in place. How would you rotate the
above cabinet 34 degrees with values given above?
Note: I have been using povray for a year now, I still can't rotate objects in
place without orbiting? Sorry if I'm slow to understand. Thanks again.
Anytime you get your objects orbiting when you rotate them, it's because
they are not created at the origin, or you have positioned them before
the rotation.
A cabinet should be modeled with it's back having a zero coordinate and
sit on the grouns: 0-> +Y.
A door should have an edge along the Y axis.
A trap with an adge along the X or Z axis.
Furnitures and objects destined to stand on something should extend from
the X-Z plane toward +Y and be located around the Y axis.
Other objects should sit around the origin.
So, before you rotate the object, be sure it's sitting at the correct
place. Never translate from the origin before you rotate.
1 - Create all objects AT the origin.
2 - Scale the object as needed.
3 - Rotate the object as needed.
4 - Translate the object to it's final location.
