POV-Ray : Newsgroups : povray.general : new guy...to everything. Server Time
25 Dec 2025 17:37:24 EST (-0500)
  new guy...to everything. (Message 1 to 8 of 8)
Subject: new guy...to everything.
Date: 4 Aug 2009 22:15:00
Message: <web.4a78eaf34a07b4048bd383a50@news.povray.org>
Hi everyone.
I am new to POV Ray and imaging in general, suffice to say I am completely lost
as to how I am going to create art using this program or how I can render my
art in this program. If anyone has any tips on where to begin (a manual to read
perhaps) please let me know.
thanks
-javi.
Subject: Re: new guy...to everything.
Date: 4 Aug 2009 22:55:42
Message: <4a78f4ae@news.povray.org>
javi schrieb:
> Hi everyone.
How about the built-in help then? ;-)
Or, if you're using the Linux version and can't find the HTML help files
that should be installed with it, you can read it on the net at
http://www.povray.org/documentation/.
In any case, welcome to POV-Ray!
Date: 5 Aug 2009 00:10:01
Message: <web.4a7905c8d8b02b1a8bd383a50@news.povray.org>
> javi schrieb:
> > Hi everyone.
I think I'm good for set up, I am using the mac version already compiled. I'm
just like....woah.... ya know. The only option I have is to create a marker
after that I am LOST ha.
Date: 5 Aug 2009 03:26:42
Message: <4a793432$1@news.povray.org>
> I'm
> marker
Load up some of the simple demo scenes included and read through the code,
look up the keywords you see in the help, generally fiddle about with stuff
and learn.  And if you don't understand anything or get stuck, then post in
the new users group - someone will surely help you.
Date: 5 Aug 2009 04:06:05
Message: <4a793d6d$1@news.povray.org>
"javi" <jay### [at] hawksrwuedu> wrote in message
news:web.4a7905c8d8b02b1a8bd383a50@news.povray.org...
> clipka <ano### [at] anonymousorg> wrote:
>> javi schrieb:
>> > Hi everyone.
>> > completely lost
>> > render my
>> > to read
> I'm
> marker
Are you able to run the POV-Ray application?
If so you should get the Mac interface described at
http://www.povray.org/documentation/view/3.6.1/731/
From that you should be able to load one of the scene files that comes with
POV-Ray and render it. For example biscuit.pov from the scenes:advanced
folder. So long as that renders ok you can move straight on to creating your
own art. This is done by adding instructions into a text file to describe
the scene, then rendering it. The instructions are written in SDL (the Scene
Description Language) and the majority of the documentation that Clipka
linked to covers the wealth of things that you can do using the SDL.
You'll need to understand the X-Y-Z coordinate system (Y is usually
considered 'up') and you'll need to be able to specify colours, either using
their RGB values or using the predefined names in 'colors.inc'.
When developing your first scene it's best to keep it really simple, so
you'll need a camera, a light source and one or more objects. A simple
starting point would be:
camera {location <0, 2,-2> look_at <0,0,0>}
light_source {<2,20,-4> color rgb <1,1,1>}
sphere {<0,0,0>,1 pigment {rgb <1,0,0>}}
Or, if you want to use the predefined colors in 'colors.inc':
light_source {<2,20,-4> color White}
sphere {<0,0,0>,1 pigment {Red}}
A common first project is to create some form of reflective sphere on a
checkered plane (RSOCP).
The 'povray.newusers' newsgroup is dedicated to the sort of questions that
new users often ask. There's also a FAQ at http://tag.povray.org/povQandT/
If you run into any Mac specific problems it may be worth looking through
the Mac specific newsgroup at http://news.povray.org/povray.macintosh/
Hope that helps.
Chris B.
Date: 6 Aug 2009 22:35:48
Message: <4a7b9304@news.povray.org>
> Hi everyone.
> thanks
> -javi.
Welcome in the gang!
The first thing I did was to go trough the tutorial and enter all the
samples by hand.
Once you have rendered a sampls, go ahead and change some thing(s) in it
and render again to see the difference.
Next, skimm over the rest of the documentation that comes with the
installer.
Now, start making a few simple scenes of your own, and progressively, go
on to some more complexe scenes.
If you have a problem, or need some additional explanations, come back
on this forum or on povray.newusers.
As for the artistic value of your creations, I can't juge that.
Date: 11 Aug 2009 03:24:03
Message: <4a811c93@news.povray.org>
"javi" <jay### [at] hawksrwuedu> schreef in bericht
news:web.4a78eaf34a07b4048bd383a50@news.povray.org...
> Hi everyone.
> lost
> my
> read
If you are using the Windows version, something which might help you
visualize what you are doing are the following two free modellers specially
dedicated to POV-Ray:
Moray for Windows http://www.stmuc.com/moray/index.html . Be aware that
Moray works well only with POV version 3.5 but it could help you along in a
comprehensive way. In the future, Moray is expected to be overhauled and
made compatible with latest versions. As is, Moray can let you make great
things. I am still using it regularly for my creations.
Bishop3D http://www.bishop3d.com/index.htm . This modeller is compatible
with later POV versions and is under development.
Hope this helps.
Date: 11 Aug 2009 08:50:01
Message: <web.4a81687cd8b02b1a443424e70@news.povray.org>
"javi" <jay### [at] hawksrwuedu> wrote:
> Hi everyone.
> thanks
> -javi.
You can also use the online tool pointed to by
http://sixpairs.com/PovOL.aspx
You can just try stuff like "Sphere;" or
"difference Sphere; Torus Green; end"
in the text box and you will have a complete scene.
Or you can modify existing scenes (by putting your name in the strings...)
Then you can have a look at the generated
Pov-Ray SDL code to learn about SDL.
The documentation is on the tool's page as well and
it is written in the same language; so you can
use the documentation as "a set of scenes to learn about Pov-Ray".
(The doc scenes are still in the process of buing built)
You can even modify the documentation scenes to have your own set
doc scenes.
See also a recent previous post in this newsgroup:
http://news.povray.org/povray.general/thread/%3Cweb.4a706c4b86936ff9f2bcf83f0%40news.povray.org%3E/
-Ciper
