POV-Ray : Newsgroups : povray.general : Isosurface help Server Time
11 Jan 2025 09:44:13 EST (-0500)
  Isosurface help (Message 1 to 10 of 12)
Subject: Isosurface help
Date: 22 Jan 2009 01:40:01
Message: <web.497813d6c397323e3b34ecfe0@news.povray.org>
This is more or less a math question not syntax question. Still, I have killed
many hours on this and so maybe someone has an idea.
Say I have an isosurface:
#declare  P = function {x*x + y*y + z*z - 1}
isosurface {
        function {P(x*2,y*(1.05-y/6),z*2)}
        threshold 1
        accuracy 0.001
        max_gradient 200
        contained_by{sphere{<0,0,0>,3}}
        pigment {rgbt <0,1,0>}
This gives a stretched sphere where one side is squashed and the other
is more sharp. Now what I want to do is to modify this isosurface so that
there is also a bump on the surface, kind of like a wart on the nose.
Any ideas on how to do this would be appreciated.
Subject: Re: Isosurface help
Date: 22 Jan 2009 02:10:06
Message: <eKdRUPKLuBeJFw9n@econym.demon.co.uk>
>isosurface {
>        threshold 1
>        accuracy 0.001
>        max_gradient 200
The way I'd do it is:
First: Eliminate the Threshold value by subtracting 1 in the function {}
        function {P(x*2,y*(1.05-y/6),z*2) -1}
Then: Create a separate isosurface in the right location. It's much
easier to design this as a separate isosurface and then blob it onto the
nose later.
      isosurface {
        accuracy 0.001
        max_gradient 200
      isosurface {
        function {P(x*4+1,y*4,z*4+2) -1}
        accuracy 0.001
        max_gradient 100
        pigment {rgbt <1,0,0>}
Once that's looking reasonable: Multiply the two functions together and
subtract a small constant. The smaller the constant, the sharper will be
the blending between the two isosurfaces. You may need to increase
max_gradient.
#declare  P1 = function {P(x*2,y*(1.05-y/6),z*2) -1}
#declare  P2 = function {P(x*4+1,y*4,z*4+2) -1}
isosurface {
        function {P1(x,y,z)*P2(x,y,z) -0.03}
        accuracy 0.001
        max_gradient 5950
Mike Williams
Gentleman of Leisure
Date: 22 Jan 2009 03:50:01
Message: <web.4978326bfb628f71dd43aa390@news.povray.org>
> >isosurface {
> >        threshold 1
> >        accuracy 0.001
> >        max_gradient 200
> nose later.
>       isosurface {
>         accuracy 0.001
>         max_gradient 200
>       isosurface {
>         accuracy 0.001
>         max_gradient 100
> max_gradient.
> isosurface {
>         accuracy 0.001
>         max_gradient 5950
> Mike Williams
Ah, so it seems I have the master's attention. So before going any further, many
thanks for your isosurface tutorial, it has been a terrific resource.
Now I tried what you have suggested before and got very weird results. Your
reply here has helped me understand where the problem was. You see, I was
really trying to do something like so:
function {P1(x,y,z)*P2(x,y,z)+f_noise3d(x*10, y*10, z*10)*0.3-0.03}
and when I add noise (values straight from the tutorial here, it creates a
problem: the joint shape partly disappears.
And I do not think it has to do with max_gradient. Rather it seems to be due to
the noise function going above threshold. Any suggestions for making this shape
wrinkly?
Date: 22 Jan 2009 17:00:01
Message: <web.4978eb31fb628f71f50167bc0@news.povray.org>
Here's another version, using the isosurface 'smooth transits' idea at
"2.3.3.3.6 Combining isosurface functions" in the docs.  I also came up with a
'wrinkly' function--*trying* to get the look of wrinkly, sagging skin--but it
probably looks more like melted ice cream.  Oh well!
The max_gradient probably isn't high enough, but looks OK as-is.
Ken W.
#declare  P1 = function {P(x*2,y*(1.05-y/6),z*2)}
#declare  P2 = function {P(x*4+1,y*4,z*4+2)}
// I like to specify my own color_map for pigment functions, for more
// control; the default ones look odd sometimes.
#declare my_color_map_1 =
color_map{
 [0.0 rgb 0]
 [1.0 rgb 1]
#declare wrinkly_function =
function{
 pigment{
  spotted
  scale .2*<1,.1,1>
  sine_wave
  color_map {my_color_map_1}
  scale 4
  warp{turbulence .18*<1,1,1> omega .1}
  scale 1/4
  scale 10
  warp{turbulence .18*<.5,1,1> omega .1}
  scale 1/10
  scale .7*<.5,2,1>
isosurface {
        function {
        (1 + .01)
 - pow(.01,P1(x,y,z)*1)
 - pow(.01,P2(x,y,z)*1)
 + wrinkly_function(x,y,z).gray*.23
        accuracy 0.001
        max_gradient 50
        contained_by{sphere{<0,0,0>,1.2}}
        scale 2.5
Date: 23 Jan 2009 00:00:03
Message: <etYhN+DcyUeJFwvF@econym.demon.co.uk>
>> >have killed
>> >isosurface {
>> >        threshold 1
>> >        accuracy 0.001
>> >        max_gradient 200
>> nose later.
>>       isosurface {
>>         accuracy 0.001
>>         max_gradient 200
>>       isosurface {
>>         accuracy 0.001
>>         max_gradient 100
>> max_gradient.
>> isosurface {
>>         accuracy 0.001
>>         max_gradient 5950
>> Mike Williams
>further, many
>wrinkly?
Going this route, you have to apply the noise to the individual
functions, not to the smoothness parameter:
#declare  N = function {f_noise3d(x*10, y*10, z*10)*0.3}
#declare  P1 = function {P(x*2,y*(1.05-y/6),z*2) -1 + N(x,y,z)}
#declare  P2 = function {P(x*4+1,y*4,z*4+2) -1 + N(x,y,z)}
isosurface {
This also allows for the possibility of having different wrinkles on the
wart.
Mike Williams
Date: 23 Jan 2009 10:30:01
Message: <web.4979e179fb628f71f50167bc0@news.povray.org>
Hi, Mike...
I was wondering about the reason for that, in functions P1 and P2. I see that
it's a kind of alternate way to create 'smoothe transits' between the two
spheres; but I'm curious if it has some added benefit that the docs' version
doesn't (speaking from sheer lack of understanding on my part.) The docs'
version produces a final composite object that does look a bit different from
yours--a smaller main sphere--but I can adjust that by making its radius
larger. Can you clue me in on why you've used an alternate technique? I'm most
curious! :-)
While we're on this topic: Something else I don't quite understand is why
*either* technique requires such a high max_gradient, when the resulting object
is just a smooth shape with no *apparent* sharp indents or other
difficult-to-evaluate slopes.
And would max_gradient's 'evaluate' be better to use on such composite
functions?
BTW, I too have learned *much* from your tutorials; what a great resource!
Ken W.
Date: 23 Jan 2009 12:20:06
Message: <Qm8SPnCMqfeJFwfd@econym.demon.co.uk>
>Hi, Mike...
>curious! :-)
Eliminating threshold doesn't have any effect on the geometry, it just
makes the maths easier.
The surface exists at all points where f(x,y,z) = threshold. So
   threshold 1
is exactly the same as
   threshold 0
but now we can handle functions that are complicated expressions of P()
without also having to have complicated expressions of the threshold
value.
It's not the sharpness of the surface, but the rate of change of
function that causes the max_gradient requirement. For example
and
  function {x*x*x*x + y*y*y*y + z*z*z*z - 1}
produce identical surfaces, but the values of the second one rise more
steeply, so there's a high max_gradient.
>functions?
Probably. I never mastered evaluate.
Mike Williams
Date: 23 Jan 2009 12:55:00
Message: <web.497a0441fb628f71bdc576310@news.povray.org>
> and
Are you sure you're correct on this one (I mean, in details)?
I would assume that as (x+y+z-1) gives different results than (x^2+y^2+z^2-1)
(the former is a plane, while the latter is a sphere), so would (x^4+y^4+z^4-1)
(some... quartic? Never tried it out)
I think
    function {500*x*x + 500*y*y + 500*z*z - 500}
comes closer to match the point you're making.
Date: 23 Jan 2009 13:07:12
Message: <497a0750@news.povray.org>
  I think it produces something which looks like a rounded cube, ie. like
a superellipsoid with both parameters the same (like <.1, .1> or whatever).
Date: 23 Jan 2009 14:15:00
Message: <web.497a1630fb628f71f50167bc0@news.povray.org>
Actually, in the case of the two aforementioned 'methods', the final object does
look a bit different from one to the other--the 'wart' protrudes further using
the docs' method, or else the main sphere has been decreased in size. Not sure
which, or why. Not a big deal, of course.
>    threshold 1
>    threshold 0
OK, got that. Thanks. I never understood that 'til now, although it's probably
in your tutorials and I just glossed over that part.  (Heretofore, I've had a
tendency to just leave threshold at it's default value, without even thinking;
it's rather 'unexplored territory' that I need to learn more about.)
> function that causes the max_gradient requirement...
Oh! I do see the point you're making. A new discovery for me. Thanks for
explaining!
Ken
