POV-Ray : Newsgroups : povray.general : procedural texture as a bump map? Server Time
26 Dec 2025 02:54:52 EST (-0500)
  procedural texture as a bump map? (Message 1 to 10 of 11)
Subject: procedural texture as a bump map?
Date: 3 Nov 2008 16:45:00
Message: <web.490f6fef945e846aa08ed15e0@news.povray.org>
I thought there was a way to do this, so that my wood would have apparent
surface rippling, but I don't seem to be finding it.  I've done "embossing"
before, where I used a BMP of the text, applied it as a bump map, and then as a
texture, to "paint" the object..
I'd like to be able to turn this:
#declare Floor_Texture = texture { pigment { P_WoodGrain18A color_map {
M_Wood18A }}}
                         texture { pigment { P_WoodGrain12A color_map {
M_Wood18B }}}
                         texture { pigment { P_WoodGrain12B color_map {
M_Wood18B }}
into apparent disturbance of the normal so that the wood surface does not appear
to be a perfectly flat surface, up close.
Subject: Re: procedural texture as a bump map?
Date: 3 Nov 2008 18:05:30
Message: <490f83ba$1@news.povray.org>
"Dave VanHorn" <mic### [at] gmailcom> wrote in message
news:web.490f6fef945e846aa08ed15e0@news.povray.org...
> "embossing"
> as a
> M_Wood18A }}}
> M_Wood18B }}}
> M_Wood18B }}
> appear
#declare N_WoodGrain12a = normal {
    bozo
    turbulence 0.04
    lambda 2.5
    omega 0.1
    octaves 7
    scale <0.5, 0.05, 0.05>
#declare N_WoodGrain12b = normal {
   wood
   turbulence <0.1, 0.04, 1>
   scale <0.15, 0.5, 1>
   rotate x*2
#declare N_WoodGrain18a = normal {
    wood
    turbulence 0.02
    octaves 4
    lambda 4
    scale 0.1
    rotate <2, 0, 0>
#declare Floor_Texture = material {
   texture { pigment { P_WoodGrain18A color_map {M_Wood18A }}}
   texture { pigment { P_WoodGrain12A color_map {M_Wood18B }}}
   texture { pigment { P_WoodGrain12B color_map {M_Wood18B }}
      normal {
         average
         normal_map {
            [1  N_WoodGrain18a]
            [1  N_WoodGrain12a]
            [1  N_WoodGrain12b]
      finish {Shiny}
Date: 3 Nov 2008 19:15:01
Message: <web.490f93deb3807db2a08ed15e0@news.povray.org>
>     bozo
>     turbulence 0.04
>     lambda 2.5
>     omega 0.1
>     octaves 7
Ok, but how did you arrive at that?
I looked through the docs on normal, but didn't see any way to apply the pigment
or texture as a normal.
Date: 3 Nov 2008 19:44:01
Message: <490f9ad1@news.povray.org>
news:web.490f93deb3807db2a08ed15e0@news.povray.org...
>>     bozo
>>     turbulence 0.04
>>     lambda 2.5
>>     omega 0.1
>>     octaves 7
> pigment
that's because there isn't.
a pigment defines the color of the surface and has nothing to do with the
normals of the surface (there are exceptions, eg. when you use the slope
pattern)
a texture is a combination of (implicitly or explicitly defined) pigment,
normal and finish, or other textures.
what you should be looking at, is using patterns as a normal.  You might
also want to look at pigment_pattern.
cu!
Date: 3 Nov 2008 19:51:07
Message: <490f9c7b$1@news.povray.org>
>>     bozo
>>     turbulence 0.04
>>     lambda 2.5
>>     omega 0.1
>>     octaves 7
Other than experience and a lot of RTFM, you should read more closely
and realize there's no such a thing as "any way to apply the pigment or
texture as a normal", I think you got that wrong.
A normal features a pattern, just like a pigment.  In fact, you can use
pretty much the same pattern and options for one and the other, the only
main differences are that pigment can have color_map and normal, a
bump_size property.
Date: 4 Nov 2008 04:56:35
Message: <49101c53@news.povray.org>
>>pigment or texture as a normal.
well, as you mentioned yourself, you can use pigment_pattern
to treat the average gray value of the pigment as normal:
texture
   pigment {P}
   normal  {pigment_pattern {P}}
Or, to use a different channel:
texture
   #local f_P = function { pigment {P} };
   pigment {P}
   normal  {function{ f_P(x,y,z).red } }
Whether that makes sense probably depends on the pigment ;)
Date: 4 Nov 2008 05:40:19
Message: <49102693$1@news.povray.org>
"Christian Froeschlin" <chr### [at] chrfrde> wrote in message
news:49101c53@news.povray.org...
yes, but it's no longer a pigment then, it's a pattern
cu!
Date: 5 Nov 2008 05:41:10
Message: <49117846$1@news.povray.org>
>>     bozo
>>     turbulence 0.04
>>     lambda 2.5
>>     omega 0.1
>>     octaves 7
> pigment
It's just the pattern from the P_WoodGrain12a pigment,
modified to be a normal, you can look it up in woods.inc,
that's in the POV/include directory.
The normal patterns look best if they match the color patterns,
if you dislike the resulting normal you can tweak the weighting
of the average.
The next step up in realism is to switch to isosurfaces.
http://www.imagico.de/pov/iw/docu03.html
Date: 7 Nov 2008 09:50:00
Message: <web.491454efb3807db2a08ed15e0@news.povray.org>
Ok, that worked great!  I had to distort the patterns a bit to get the grain the
way I wanted it, but it worked nicely.
I made a floor of boards,
#declare Floor = object { union { object { Board1  translate <-15, 0, 0>}
                                  object { Board2  translate <-12, 0, 0>}
                                  object { Board3  translate < -9, 0, 0>}
                                  object { Board4  translate < -6, 0, 0>}
                                  object { Board5  translate < -3, 0, 0>}
                                  object { Board6  translate <  0, 0, 0>}
                                  object { Board7  translate <  3, 0, 0>}
                                  object { Board8  translate <  6, 0, 0>}
                                  object { Board9  translate <  9, 0, 0>}
                                  object { Board10 translate < 12, 0, 0>}
                                  object { Board11 translate < 15, 0, 0>}
                          scale <0.5, 1, 1>
Each board has the same texture, but slid back and forth so that they don't look
like "clones".
#declare Board1 = object { Board
                           material { Floor_Texture
                                      translate <1, 0, 10>
The actual board is pretty simple, I position them at 3 unit intervals, so they
are 2.9 wide, which gives a fair looking gap between.
#declare Board = object { box { <-0.5, -0.5, -0.5>  // one corner position <X1
Y1 Z1>
                                < 0.5,  0.5,  0.5>  // other corner position <X2
Y2 Z2>
                                scale <2.95, 1.0, 100.0> //2.9" wide, 100" long,
1" thick
                                translate <0, -0.5, 0> //Move the top back down
to 0,0,0
And here's how the texture ended up.
#declare Floor_Texture = material { texture { pigment { P_WoodGrain18A color_map
{M_Wood18A }}}
{M_Wood18B }}}
{M_Wood18B }}
                                              normal  { average normal_map {
[0.5  N_WoodGrain18a]
[0.5  N_WoodGrain12a]
[0.5  N_WoodGrain12b]
                                              finish {reflection 0.05}
                                    scale <0.5, 1.0, 2.0> // stretch and
compress for finer "grain"
Date: 7 Nov 2008 11:18:09
Message: <49146a41$1@news.povray.org>
>                           scale <0.5, 1, 1>
> like "clones".
You can also use a repeat warp to get the same effect on a single floor object.
Nice example with a brick wall:
http://www.shipbrook.com/jeff/raytrace/bricks.html
