POV-Ray : Newsgroups : povray.general : Can I set KFF from inside my scene? Server Time
26 Dec 2025 02:56:15 EST (-0500)
  Can I set KFF from inside my scene? (Message 1 to 5 of 5)
Subject: Can I set KFF from inside my scene?
Date: 9 Oct 2008 14:25:00
Message: <web.48ee4bda854a994d401d7400@news.povray.org>
While designing my animation, I came across two snags, both of which could be
easily fixed if I could set KFF from within my scene file.
The animation is pretty simple:  it travels from point to point through the
scene, looking at attractions from different perspectives.  The first snag is
that I would like the number of frames to scale with the number of objects --
half as many attractions means twice as many frames per attraction which means
the animation runs twice as "slow".  The second snag is that the set of frames
allocated to each attraction counts both moving to the attraction and looking
at it but the last "attraction" is an overhead view so I only need half as many
frames to get the desired effect.  Being able to set KFF to something like
(dimension_size(Attractions,1)-0.5)*FramesPerAttraction would allow me to focus
on creating attractions and not on tweaking command-line settings.
I recognize that this sort of feature could lead to total chaos, so if there's
another way to solve this from inside the scene, I'm all ears.  Thanks!
Subject: Re: Can I set KFF from inside my scene?
Date: 9 Oct 2008 15:29:00
Message: <48ee5b7c@news.povray.org>
I don't think you can set KFF from a scene file, but you can set the number of
attractions along with KFF from the ini file, right?
Form the documentation:
Declare=IDENTIFIER=FLOAT  	 Declares an identifier with a float value
You can now declare a constant in an INI file, and that constant will be available to
the scene. Since INI file statements may also be laced on the command-line, you can
therefore also declare on the command-line (though there is no switch for it).
   Declare=MyValue=24
This would be the same as a #declare MyValue=24; in a scene file. The value on the
right-hand side must be a constant float value.
A possible use could be switching off radiosity or photons from commandline:
   --in INI-file / on command-line
   Declare=RAD=0
   --in scenefile
   global_settings {
      #if (RAD)
         radiosity {
Then have the POV file generate a number of attractions dependent on that parameter.
To keep the number of attractions and kff aligned, I'd consider setting generating the
INI with Perl (or just calling POV with command line options)
Dan
Date: 9 Oct 2008 16:25:01
Message: <web.48ee680e8cabb3cd8a103ef0@news.povray.org>
i file, right?
[... docs elided ...]
the INI with Perl (or just calling
I already have an easy way to calculate the number of attractions as they are
stored in the Attractions array.  I was just hoping to keep the changes
required down to a bare minimum -- ideally, just adding a single attraction to
the array would cause the animation to scale up accordingly.
So is this impossible?  I'm current developing on Windows so I'm trying to
minimize the outside-POV scripting.  I can't even automate the script because
Pre_Scene_Command is run after INI files are read.  Bleah.
Date: 10 Oct 2008 08:21:52
Message: <48ef48e0$1@news.povray.org>
Simply calculate a new variable, named it Clock, and use it in place of
the clock variable.
#declare Clock=some_constantly_rising_expression_using_clock;
For some sections, Clock will rise as quickly as clock, but you can
smoothly transition to something rising half as quickly for the slower
parts.
If d*Clock/d*clock is ever negative (that is, the calculated value is
going down at any point), then time will appear to flow backwards in
your animation.
John
Date: 10 Oct 2008 11:25:37
Message: <48ef73f1$1@news.povray.org>
Mathuin nous illumina en ce 2008-10-09 14:23 -->
You can create INI files from SDL. INI files can launch POV files, even several
in succession, and set KFF, they also can set the output file names for the
images created. That way, you can launch several short animations that can flow
from one to the next.
You know you've been raytracing too long when you spend 4 days at work wondering
how to render your tongue.
David Kraics
