POV-Ray : Newsgroups : povray.general : Freeware Displacement Mapping for Pov-Ray for Windows Server Time
27 Feb 2026 08:51:18 EST (-0500)
  Freeware Displacement Mapping for Pov-Ray for Windows (Message 1 to 10 of 10)
Subject: Freeware Displacement Mapping for Pov-Ray for Windows
Date: 12 Feb 2008 16:15:01
Message: <web.47b20b7d20247d8fd3b1f88e0@news.povray.org>
Is the following method the only way to use displacement mapping in Pov-Ray for
Windows using only freeware?
1) CrazyBumps to create displacement map (GIMP optional;
2) Blender, to create mesh deformed by displacement map;
3) Blend2Pov to export from Blender to Pov-Ray
Subject: Re: Freeware Displacement Mapping for Pov-Ray for Windows
Date: 12 Feb 2008 18:16:52
Message: <47b228e4$1@news.povray.org>
FlaPovFan napsal(a):
height_field
isosurface
even slower, parametric
the map can be made using procedural pigments
Date: 12 Feb 2008 19:12:16
Message: <47b235e0$1@news.povray.org>
PoseRay too
Date: 12 Feb 2008 23:03:25
Message: <47b26c0d$1@news.povray.org>
> Pov-Ray for
No, there are almost too many ways to remember them all easily,
depending what you mean by displacement mapping.
POV comes with a few macros for creating mesh objects
from a displacement image and an assumed basic shape.
There are programs like Terragen and Worldmachine.
There are other programs to convert from DEM format
(real data) landscapes, though it's a hassle.
You can manipulate almost any graphic tool available
to output to POV.
Date: 13 Feb 2008 01:10:00
Message: <web.47b287db12f59258d3b1f88e0@news.povray.org>
> > Pov-Ray for
> to output to POV.
Thanks all for the help.
From a short review of the articles on the web, I think that "displacement
mapping" differs from "normal mapping" and "bump mapping" in that "displacement
mapping" actually deforms the vertices of the object, whereas the others just
apply a texture to the object that gives the impression of a change in shape.
I'm not sure where this is significant.
It seems that PoseRay's displacement function is actually the application of a
bump map.
Originally I became interested while following a Blender tutorial, which was
labelled, to paraphrase, "Turning a 2d image into a 3d object".  An image of
the word "Blender", softened with Gaussian blur, is added as a "displacement
map"; it's also modified with subsurface scattering. the final product gives
the impression of being "embossed", as if pushed out from back to front.  It
might be useful for logos.
Finally, I wanted to give a heads up to an application found at
http://www.crazybump.com, which takes a photo and converts it into several
different kinds of maps.  It works great and it's free.
Date: 13 Feb 2008 04:16:53
Message: <47b2b585@news.povray.org>
Normal maps in POV don't support 3-axis displacement,
which is what is present in many game engines. It's a
single pseudo displacement along the object normal,
similar to data used in height fields.
Date: 13 Feb 2008 20:00:27
Message: <47b392ab@news.povray.org>
> bump map.
No, it has real displacement, it is just that the resolution necessary
to do this in mesh makes it impractical most of the time.
Date: 14 Feb 2008 00:45:00
Message: <web.47b3d53112f59258d3b1f88e0@news.povray.org>
Jim Charter <jrc### [at] msncom> wrote:
> > bump map.
Thanks for the correction, and sorry about the misinformation.
I tried applying displacement in PoseRay, to both .3ds and .obj imports.  It
seems though that the Blender displacement function allowed a more precise
displacement.  The object that I used was a mesh with a uv mapping of a line
drawing, just sharply defined black and white lines.  Blender allowed the black
lines to be raised in relief in a sharply defined and distinct way.  I don't
know if I tried it correctly in PoseRay, but my results showed a general,
nondescript relief.
How is it possible to obtain a similar effect using isosurfaces?
Date: 14 Feb 2008 13:46:58
Message: <47b48ca2$1@news.povray.org>
FlaPovFan nous apporta ses lumieres en ce 2008/02/14 00:44:
>>> bump map.
> nondescript relief.
You can use a pigment function.
"We returned the General to El Salvador, or maybe Guatemala, it's difficult to
tell from 10,000 feet."           -- Anon.
Date: 14 Feb 2008 20:59:52
Message: <47b4f218$1@news.povray.org>
Here is a snippet of the code I used to get the engraved letters along
with other textures all real displacement
It was necessary to superimpose two objects, one with noshadow to
get rid of some artifacting, one to create shadows in the scene.
I'll post example pictures on p.b.images
This code used the isocsg include files published by Christoff Hormann
This include files make it easy to reproduce POV objects and apply
textures.
#declare Fn_Sor =
IC_Sor (Point_Array, IC_Open)
#declare Fn_Text =
function {
     image_map {
       jpeg "k13.cup.wk.jpg"
       interpolate 2
       map_type 2
       once
#declare Fn_Bump1 =
function {
   pigment {...
#declare cup_lathe_noshadow=
isosurface {
         function {
               Fn_Sor (x, y, z)
               - Fn_Bump1 (x, y, z).gray*.0025
               - Fn_Text (x, y, z).gray*.001
         contained_by {
		box { <-.7,0,-.7>, <.7,P7.y,.7> }
         threshold 0.0
         accuracy 0.001
         max_gradient 6.25
         no_shadow  //<- seems to prevent artifacting
                 T_Brass_
#declare cup_lathe_shadowdummy =
isosurface {
         function {
               Fn_Sor (x, y, z)
         contained_by {
		box { <-.7,0,-.7>, <.7,1.1,.7> }
         threshold 0.0
         accuracy 0.001
         max_gradient 6.25
         scale .998
                 pigment { rgb .8 }
#declare k13_cup_lathe_ =
union {
         object { cup_lathe_noshadow }
         object { cup_lathe_shadowdummy}
         translate <0,2.49,0>
