POV-Ray : Newsgroups : povray.general : Problem with isosurface Server Time
13 Oct 2025 09:16:33 EDT (-0400)
  Problem with isosurface (Message 1 to 9 of 9)
Subject: Problem with isosurface
Date: 8 Feb 2008 17:40:00
Message: <web.47acd95f26eb41a7ce83de880@news.povray.org>
In the following scene, the transparent sphere causes holes to appear in the
isosurface so that you can see all the way through it to the background behind
it. Why is this happening?
//BEGIN
#include "functions.inc"
global_settings {
  assumed_gamma 1.0
  location  <2.0, 2.0, 2.0>
  look_at   <0.0, 0.0,  0.0>
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.6,0.7,1.0>]
      [0.7 rgb <0.0,0.1,0.8>]
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <1, 1, 1>  // light's color
  translate <30, 30, 30>
#declare My_iso_function = function
 pigment
  granite
#declare Height_Ratio = 0.005;
#declare Water_Ratio = 0.75;
isosurface
 function { f_sphere(x, y, z, 1) + My_iso_function(x, y, z).gray * Height_Ratio}
 contained_by
  sphere {0, 1}
 pigment
  onion
  color_map
           [0 rgb 0]
           [1 rgb 1]
  scale Height_Ratio
sphere
 0, 1 - Height_Ratio * (1 - Water_Ratio)
 pigment
  color rgbt 1
//END
Subject: Re: Problem with isosurface
Date: 8 Feb 2008 18:15:39
Message: <47ace29b@news.povray.org>
Look at the debug messages when the render is done. If it says something
about "max_gradient reached", increase it.
Date: 8 Feb 2008 18:35:00
Message: <web.47ace68143fac46bce83de880@news.povray.org>
There's no mention of "max_gradient" in the messages pane. Note also that the
isosurface renders fine when the transparent sphere is eliminated from the
scene.
Date: 8 Feb 2008 20:00:42
Message: <47acfb3a$1@news.povray.org>
SharkD nous apporta ses lumieres en ce 2008/02/08 17:36:
Same thing using the latest beta.
Adding "all_intersections" don't help.
All parts of the isosurface that are under the sphere surface are missing. You
can see the parts of the far side trough the holes.
Replacing the sphere by a box, and I see circles near the intersection of the
box and the isosurface.
Increasing the amplitude of the surface by a factor of 10, and the deep parts
are there. There are cuts near the surface of the sphere.
Scaling everything by a factor of 10, beter, but slow. Still have cuts.
It looks like a floating point precision problem.
When you first hit the isosurface, it's ok, you stop looking any further.
When you first hit the transparent sphere, the isosurface is to close and the
test just miss it.
You know you've been raytracing too long when quotes about raytracing are making
sence to you.
Date: 8 Feb 2008 21:40:01
Message: <web.47ad11f843fac46b4cdeac580@news.povray.org>
Some more problems related to isosurfaces--this time with pigments. In the
following scene, there is noticable banding of the pigment in the form of
concentric circles around the centerpoint of the image. This problem occurs
regardless of the camera location. If you move the camera, there are still
concentric circles centered around the middle of the image.
//BEGIN
// Persistence of Vision Ray Tracer Scene Description File
// File: ?.pov
// Vers: 3.6
// Desc: Basic Scene Example
// Date: mm/dd/yy
// Auth: ?
#version 3.6;
global_settings {
  assumed_gamma 1.0
  rotate y * 45
sky_sphere {
    gradient y
    color_map {
light_source {
#local Pigment_Granite = pigment
 granite
 color_map
  [0 rgbt 0]
  [1 rgbt 1]
 pigment
  pigment_pattern
   crackle
  pigment_map
   [0 rgbt 0]
   [1 Pigment_Granite]
  scale 1/2
isosurface
 function { f_sphere(x, y, z, 1) + My_iso_function(x, y, z).transmit *
Height_Ratio}
 contained_by
  sphere {0, 1}
 pigment
  onion
  color_map
   [Water_Ratio * 000/100 rgb <000,000,050,>/255] //blue
   [Water_Ratio * 090/100 rgb <000,000,050,>/255] //blue
   [Water_Ratio * 099/100 rgb <034,180,180,>/255] //teal
   [Water_Ratio * 100/100 rgb <034,180,180,>/255] //teal
   [Water_Ratio + (1 - Water_Ratio) * 00/12 rgb <067,084,029,>/255] //green
   [Water_Ratio + (1 - Water_Ratio) * 08/12 rgb <067,084,029,>/255] //green
   [Water_Ratio + (1 - Water_Ratio) * 10/12 rgb <132,114,076,>/255] //tan
   [Water_Ratio + (1 - Water_Ratio) * 11/12 rgb <255,255,255,>/255] //white
   [Water_Ratio + (1 - Water_Ratio) * 12/12 rgb <255,255,255,>/255] //white
  scale Height_Ratio
//END
Date: 9 Feb 2008 12:29:58
Message: <47ade316$1@news.povray.org>
SharkD nous apporta ses lumieres en ce 2008/02/08 21:37:
The banding was obvious in your original sample. Same problem: FP inacurancy.
The problem is that your radial variation is extremely small, at 0.005 unit.
You get much beter result after scaling everything up by 10.
f_sphere(x, y, z, 1) become f_sphere(x/10, y/10, z/10 ,1)
contained_by{sphere{0,1}} become contained_by{sphere{0,10}}
the scale Height_Ratio become scale Height_Ratio*10
This way, you get much less rounding errors and it preserve the intended apearance.
Important letters that contain no errors will develop errors in the mail.
Date: 9 Feb 2008 16:50:01
Message: <web.47ae1efe43fac46b8a2ce73f0@news.povray.org>
> Alain
I've scaled everything by 10 and get virtually identical results.
Date: 10 Feb 2008 04:48:47
Message: <47aec87f$1@news.povray.org>
Hardly a surprise if you contain the isosurface in a sphere of radius R but
define the surface to be R *plus* something, don't you? ;-)
	Thorsten
Date: 28 Feb 2008 19:05:01
Message: <web.47c74b0243fac46bd57dbd0@news.povray.org>
>  Thorsten
Adding the "something" actually causes the radius to be less than 1. Also, I
don't see how what you've suggested has any affect on banding.
