POV-Ray : Newsgroups : povray.general : Wanted: dealing with font style 'bold' and 'italics' Server Time
13 Oct 2025 11:38:26 EDT (-0400)
  Wanted: dealing with font style 'bold' and 'italics' (Message 1 to 10 of 17)
Subject: Wanted: dealing with font style 'bold' and 'italics'
Date: 6 Dec 2007 14:35:00
Message: <web.47584d4d1e565df12a7b15450@news.povray.org>
Can someone suggest how to deal with font 'bold' and 'italics' ?
I have started working with fonts and haven't found an answer from the docs or
searching the newsgroups.
As always, thanks in advance.
Leef_me
I am using POV-Ray for the Microsoft Windows.
Other windows apps have the capability of scale, bold, italics, underline,
shadow.
I happen to be using the font as a pigment on a 'theater screen',
and 3d aspect of the pigment isn't an issue.
My fall-back position is to create an image using the desired font/bold and then
us that as the pigment. But I'd rather do it in POVRAY alone.
Here's my tweaked version from:
   http://tag.povray.org/povQandT/languageQandT.html#cylindricalrepeat
//start
camera { location -z*6 look_at 0 angle 35 }
light_source { <10, 20, -50>, 1 }
// create a box that extends between the 2 specified points
box {
  <-1, -1, 0>  // one corner position <X1 Y1 Z1>
  < 1,  1,  .1>  // other corner position <X2 Y2 Z2>
  pigment
  { object
    { text { ttf "crystal", "Hello", 1.1, 0 }
      // Note: Thickness must be larger than cylinder radius
      rgb 1, rgb x
    translate -z/2      // prevent "artifact known as coincident surfaces"
                        // From: Samuel Benge
                        // Subject: Re: Simple 2D text on a cylinder's surface
                        // Date: 20 Oct 2007 23:55:41
                     // http://news.povray.org/471a957d%241%40news.povray.org
    scale <-.5, .5, 1>
    warp { planar }
    translate x*.6      // better handled with Text_Space or Text_Width
  rotate y*145
plane { y, -1.001 pigment { checker rgb 1, rgb .5 } }
//end
Subject: Re: Wanted: dealing with font style 'bold' and 'italics'
Date: 6 Dec 2007 18:23:42
Message: <4758847e$1@news.povray.org>
#include "transforms.inc"
// normal text
#declare Ntext = text {ttf "timrom.ttf", "Sample Text", 0.1, <0,0,0>};
object { Ntext
   Center_Trans(Ntext,x)
   scale <0.5,0.5,1>
   translate <0,0,0>
   pigment {Gray50}
// italic text
#declare Itext = text {ttf "timrom.ttf", "Sample Text", 0.1, <0,0,0>};
object { Itext
   Center_Trans(Itext,x)
   scale <0.5,0.5,1>
   Shear_Trans(x, y+0.25*x, z)
   translate <0,-0.5,0>
   pigment {Gray50}
// bold text
#declare Btext = text {ttf "timrom.ttf", "Sample Text", 0.1, <-0.1,0,0>};
object { Btext
   Center_Trans(Btext,x)
   #local Nwidth = max_extent(Ntext).x - min_extent(Ntext).x;
   #local Bwidth = max_extent(Btext).x - min_extent(Btext).x;
   scale <Nwidth/Bwidth,1,1>
   scale <0.5,0.5,1>
   translate <0,0.5,0>
   pigment {Gray50}
Date: 6 Dec 2007 21:12:27
Message: <4758ac0b$1@news.povray.org>
Bold and italics are on different .ttf files. For Arial, I have these files:
arial.ttf //normal
arialbd.ttf //bold
ariali.ttf //italics
arialbi.ttf //bold and italics
Date: 7 Dec 2007 01:40:00
Message: <web.4758ea7917d569dd892adb1d0@news.povray.org>
> // normal text
Thanks again.  Leef_me
Date: 7 Dec 2007 01:45:01
Message: <web.4758eb9317d569dd892adb1d0@news.povray.org>
> arial.ttf //normal
> arialbd.ttf //bold
Thanks Nicolas,
I tried to give all the details, I missed reporting that.
I understand that there are some fonts with separate files like these.
The particular font I wanted to use, doesn't happen to do it this way.
Leef_me
Date: 7 Dec 2007 11:08:27
Message: <47596ffb@news.povray.org>
"Leef_me" <nomail@nomail> wrote in message
news:web.4758eb9317d569dd892adb1d0@news.povray.org...
>> these files:
>> arial.ttf //normal
>> arialbd.ttf //bold
> Thanks Nicolas,
> these.
> way.
> Leef_me
What's the font?
Some of us have collections of typefaces ...
Date: 7 Dec 2007 12:36:40
Message: <475984a8$1@news.povray.org>
>> arial.ttf //normal
>> arialbd.ttf //bold
> Thanks Nicolas,
Then the particular font you want to use has no bold or italics, simple.
Maybe some word processors *fake* it in a similar way to what Tim
Attwood said; but POV-Ray definitely doesn't have that built-in.
Date: 7 Dec 2007 16:10:00
Message: <web.4759b63117d569dd2a7b15450@news.povray.org>
> > these.
> > way.
> > Leef_me
> What's the font?
It has Curlz in the name, but it's a uSoft font packaged with some uSoft
products. Based on that thought, it's surely copyright and trading is likely a
no-no. I appreciate the thought, but Tim Attwood's code will suffice or I'll
make do with 'normal' or using a generated picture.
Leef_me
Date: 7 Dec 2007 16:22:03
Message: <4759b97b$1@news.povray.org>
Leef_me nous apporta ses lumieres en ce 2007/12/07 01:43:
>> arial.ttf //normal
>> arialbd.ttf //bold
> Thanks Nicolas,
> Leef_me
The shear matrix is the way for italic. It's similar to the way used by word
processors and others to display italic when there is no italic version available.
Bold is harder to do. The characters remain about the same size, but the lines
are thicker. A way would be to scale up horizontaly and reduce the spacing
between the characters. It will be more like "whide condenced"
You *know* you've been raytracing far too long when you look at a heap of dirt
and go "wow, that looks really realistic..."
Date: 7 Dec 2007 18:25:08
Message: <4759d654$1@news.povray.org>
Can't help you with bold, as that involves changing the basic shape of
the text.
Doing italic text object in POV-Ray is easy:
text { ttf "arial.ttf","Some text",.1,0
   matrix <1,0,0, .1,1,0, 0,0,1, 0,0,0>
The matrix line italicizes the font.  The .1 setting slopes the text
over to a 10% grade.  You can go to .2 if you want very obvious italics,
but that's enough.
There is no way of telling POV-Ray that you want to apply whatever text
style you're used to using from your word processor; you have to
understand what actually happens to the shapes of the letters, and then
apply that change by altering the model accordingly.
John
