POV-Ray : Newsgroups : povray.general : render depth/normal map with povray? Server Time
12 Jan 2025 10:44:48 EST (-0500)
  render depth/normal map with povray? (Message 1 to 10 of 12)
Subject: render depth/normal map with povray?
Date: 15 Nov 2007 09:00:01
Message: <web.473c4fbbdb567e121d0a17590@news.povray.org>
I am wondering if it's possible to render a depth and/or normal map using
povray, instead of a regular scene render.
The depth map can be generated by measuring the depth from a reference plane
(bounding box for example) and cast rays to the surface of the objects.
Is this possible?
I know there are other platforms that can do this, just wondering if POV-Ray can
be setup to generate such maps.
Subject: Re: render depth/normal map with povray?
Date: 15 Nov 2007 09:49:14
Message: <473c5c6a@news.povray.org>
sirhenjo napsal(a):
> Is this possible?
depth map:
set a gradient pigment perpendicular to the camera plane and set ambient
1 diffuse 0
Date: 15 Nov 2007 10:15:01
Message: <web.473c6176fcd9bf9ac150d4c10@news.povray.org>
Jan Dvorak <jan### [at] centrumcz> wrote:
> sirhenjo napsal(a):
> > Is this possible?
> depth map:
> 1 diffuse 0
Normal map, use combined slope patterns.
-tgq
Date: 15 Nov 2007 11:48:01
Message: <473c7841@news.povray.org>
sirhenjo nous apporta ses lumieres en ce 2007/11/15 08:55:
> Is this possible?
For the depth map:
1 - remove all textures and pigments.
2 - bind everything but the camera in one union.
3 - apply a gradient pattern to your big union scaled to it's depth. Have the
gradient perpendicular to the camera axis.
4 - remove all light_source and use ambient 1 diffuse 0.
For the normal map:
Do the same, but replace the gradient by a slope pattern.
Both are easier with a camera on an axis looking as the origin, but you can have
the camera set at any possible location.
You know you've been raytracing too long when your idea of a complete computer
is a fast CPU, lots of RAM, and a means of running POVray.
Aaron Gage a.k.a Slartibartfast
Date: 15 Nov 2007 15:45:00
Message: <web.473cafc7fcd9bf9af721d5e80@news.povray.org>
Okay, thank you all. It seems that POV-Ray is indeed capable of doing it.
However, to make it really viable for me, I need some more functionality. During
the raycasting I want to make some extra checks.
For example, I have multiple objects in front of eachother with some space
between them. Instead of writing a depth map of the scene, letting rays end
whenever they hit any object, I may want to write the depth values of an
complete second object.
To achieve this I may need to let the ray keep till it hits the 3rd face,
ignoring the first 2 faces.
Is this possible at all?
Date: 15 Nov 2007 18:37:35
Message: <473cd83f@news.povray.org>
"sirhenjo" <sir### [at] hotmailcom> wrote in message
news:web.473cafc7fcd9bf9af721d5e80@news.povray.org...
> During
> end
uhm, just remove the blocking object?
I don't get it :)
cu!
Date: 16 Nov 2007 03:15:01
Message: <web.473d50b6fcd9bf9a1d0a17590@news.povray.org>
> > During
> > end
> I don't get it :)
> cu!
> #macro G(b,e)b+(e-b)*C/50#end#macro _(b,e,k,l)#local C=0;#while(C<50)
> sphere{G(b,e)+3*z.1pigment{rgb G(k,l)}finish{ambient 1}}#local C=C+1;
> #end#end _(y-x,y,x,x+y)_(y,-x-y,x+y,y)_(-x-y,-y,y,y+z)_(-y,y,y+z,x+y)
> _(0x+y.5+y/2x)_(0x-y.5+y/2x)            // ZK http://www.povplace.com
Heheh, should have said "without removing the blocking object".
It may seem like something silly to do, but I have my reasons for this question.
Date: 16 Nov 2007 10:23:12
Message: <473db5e0$1@news.povray.org>
news:web.473d50b6fcd9bf9a1d0a17590@news.povray.org...
> question.
Could you elaborate?  'cause I still don't understand why you need the
blocking object if it won't be visible in the render :)
cu!
Date: 16 Nov 2007 11:52:20
Message: <473dcac4$1@news.povray.org>
If you need it for reflections/shadows/whatever, use no_image.
Date: 16 Nov 2007 18:57:36
Message: <473e2e70$1@news.povray.org>
sirhenjo nous apporta ses lumieres en ce 2007/11/16 03:11:
>>> During
>>> end
>> I don't get it :)
>> cu!
Is it that you wand to see the object in the back trough that in the front?
You know you have been raytracing for too long when the animation you render
will be finished after yourself.
Urs Holzer
