POV-Ray : Newsgroups : povray.general : Trouble parsing recursive macro Server Time
12 Jan 2025 20:37:06 EST (-0500)
  Trouble parsing recursive macro (Message 1 to 10 of 10)
Subject: Trouble parsing recursive macro
Date: 28 Jul 2007 13:30:02
Message: <web.46ab7a3b6b420bc8e071738a0@news.povray.org>
I'm creating a fairly simple recursive macro which creates a 10x10x10 cube,
and based on the level of recursion, breaks down each sub cube into
10x10x10 cubes, which may be in turn broken down into 10x10x10 cubes...
[take a look at
http://loudsl01-253-100-25.iglou.com/~tiger/pov_images/cube1.png]
Here's the source:
// by Barton Chittenden, based on PYRAMID2.POV by Chris Young
// Define the macro.  Parameters are:
//   X:  position of lower/right/forward block
//   Y:  position of lower/right/forward block
//   Z:  position of lower/right/forward block
//   E:  Length of edge of cube
//   L:  level of recursion
#macro Cube(X,Y,Z,E,L)
  #local Side = E * 0.80;
  #if ( L = 0)
        box { <X,Y,Z>, <X+Side,Y+Side,Z+Side>
                //pigment{color <R,G,B> }
  #end // if recusion is false
  #if (L > 0)
    # local New_L = L - 1;
    # local New_E = Side / 10;
    # local i = 0;
    # local j = 0;
    # local k = 0;
    #while(i < 10)
        #while(j < 10)
                #while(k < 10)
                        Cube(
                                X+i*New_E,
                                Y+j*New_E,
                                Z+k*New_E,
                                New_E, New_L
                        #declare k = k+1;
                #end // Xhile k
                #declare k = 0;
                #declare j = j+1;
        #end // while j
        #declare j = 0;
        #declare i = i+1;
    #end // while i
  #end // if recursion is true
#end // macro Cube
union {
  Cube(-cube_radius,0,-15,10,2)
  pigment { color rgb <1,0,0> }
light_source { <2,20,-10> color rgb <1,1,1> }
light_source { <2,10,-20> color rgb <1,1,1> }
background { color rgb <0, 0, 0> }
// Cube is 10 units wide... sub cubes
        right x
        location <0,3*cube_radius,-25>
        look_at  <0,0,-3.5>
The trouble that I'm having is that I'm running out of memory because there
are numerous tokens created for each sub cube. If I use
Cube(-cube_radius,0,-15,10,1)
I'm fine; it creates 1002 objects (one for each sub cube, then two lights).
the render shows:
  0:00:00 Parsing
  0:00:00 Creating bounding slabs
  0:00:00 Creating vista buffer
  0:00:00 Creating light buffers 209K tokens
Indicating roughtly 200 tokens/sub cube
If I increase the recursion level to 2:
I try to render, and it bottoms out at
0:02:12 Parsing 207628K tokens
Now most of the sub cubes are hidden, but because there is some space
between the sub cubes, there are areas where you can see all the way
through the cube. I'm trying to figure out a way of not parsing the sub
cubes that I can't see so that I don't swamp the memory, yet I want to make
sure that the parts of the
structure which are visible actually show correctly.
I'm not stuck on recursion, although that seems to be the simplest way of
generating a structure of this type.
Any thoughts?
Subject: Re: Trouble parsing recursive macro
Date: 28 Jul 2007 18:10:53
Message: <46abbeed$1@news.povray.org>
Well, your branch factor is a whopping 10^3 = 1000 so obviously you
are not going to achieve a great recursion depth with this approach.
Are you stuck on the 10? Make the division count a parameter and
play with it, e.g., a 5x5x5 cube would be a lot friendlier.
The recursive approach itself is not the problem, just that
the object you are trying to build has a lot of components.
As there are gaps on all levels, almost every box could contribute
something to the output image. However, you might get away with
skipping all inner cubes (i.e., only recurse if one of i,j,k is
exactly 0 or 10), effectively reducing the branch factor to
10x10x10 - 8x8x8 = 488.
Date: 28 Jul 2007 18:21:30
Message: <46abc16a$1@news.povray.org>
Well, actually it could be possible to render the million boxes
you'd get at recursion depth 2, so you could try to get over the
parse problem using an iterative approach. Still I'd recommend
to reduce the number of objects. You might even try to fake the
last recursion level by using some sort of checker-like texture
with transparency.
Date: 28 Jul 2007 19:25:01
Message: <web.46abcf0a53db5e6e071738a0@news.povray.org>
Yeah... the point of the exercise it to illustrate how big a billion is ;-)
I'm definitely willing to give this a try... stupid question:
how do an 'or' in SDL? I would like to do something like this:
#if( i = 0 or j = 0 or k = 0 or i = 9 or j = 9 or k = 9)
  Cube(
    X+i*New_E,
    Y+j*New_E,
    Z+k*New_E,
    New_E, New_L
Date: 28 Jul 2007 21:00:01
Message: <web.46abe59553db5e6e071738a0@news.povray.org>
Ok; I figured it out...
check out http://loudsl01-253-100-25.iglou.com/~tiger/pov_images/cube2.png
for the results...
here's the code:
  #if ( L = 0)
  #if (L > 0)
    # local i = 0;
    # local j = 0;
    # local k = 0;
    #while(i < 10)
        #while(j < 10)
                #while(k < 10)
                        #if( i = 0 | j = 0 | k = 0 | i = 9 | j = 9 | k = 9)
                                Cube(
                                        X+i*New_E,
                                        Y+j*New_E,
                                        Z+k*New_E,
                                        New_E, New_L
                        #else
                                Cube(
                                        X+i*New_E,
                                        Y+j*New_E,
                                        Z+k*New_E,
                                        New_E, New_L - 1
                        #declare k = k+1;
                #end // Xhile k
                #declare k = 0;
                #declare j = j+1;
        #end // while j
        #declare j = 0;
        #declare i = i+1;
    #end // while i
#end // macro Cube
#declare cube_radius = 3.9;
union {
        right x
        look_at  <0,0,-3.5>
What I did was to reduce the recursion level by 2 for the middle cubes ...
so the middle isn't empty, it's just filled with larger cubes that parse
more easily.
Date: 29 Jul 2007 13:36:46
Message: <46acd02e$1@news.povray.org>
> for the results...
well, now you have a million, good luck reaching for the billion ;)
Date: 29 Jul 2007 20:35:01
Message: <web.46ad312e53db5e64daddc090@news.povray.org>
As an alternative, create a mesh2 that has the 1st level of 10 x 10 x 10
cubes as a single object, and use copies of that.
Date: 29 Jul 2007 21:00:02
Message: <web.46ad376453db5e64daddc090@news.povray.org>
An easier way to cut out the interior cubes, would be to declare a smaller
dummy cube and perform an 'inside' test on that.  If your cubes would fall
inside the dummy object, then don't place them.
Date: 30 Jul 2007 06:00:33
Message: <46adb6c1@news.povray.org>
Christian Froeschlin nous apporta ses lumieres en ce 2007/07/29 13:36:
>> check out
>> for the results...
It should be easier or beter to fake the next step. Use 3 gradiants to place
thin black lines, with the part between the lines transparent.
Zen Buddhism: Shit is, and is not.
Date: 30 Jul 2007 13:35:36
Message: <46ae2168@news.povray.org>
You'll be lucky to get more than two levels of recursion before you have
so many scene objects that your memory manager will scream bloody murder,
UNLESS
You are culling a large proportion of the obects from the scene.
John
