POV-Ray : Newsgroups : povray.general : Radiosity help Server Time
30 Sep 2024 13:21:59 EDT (-0400)
  Radiosity help (Message 1 to 10 of 12)
Subject: Radiosity help
Date: 23 Apr 2006 11:30:00
Message: <web.444b9d653e18951ea842a49e0@news.povray.org>
I'm trying to make an outdoor scene with a white object. I have a sky_sphere
that is basically a light blue. However, whenever I render with radiosity,
the object has a blue tint to it. Is there some way to keep the background
color without it affecting the rest of the scene? I can't seem to find it
in the doucmentation. Thanks
Subject: Re: Radiosity help
Date: 23 Apr 2006 11:35:23
Message: <444b9ebb$1@news.povray.org>
"jhu" <nomail@nomail> wrote in message
news:web.444b9d653e18951ea842a49e0@news.povray.org...
isn't that exactly the point of radiosity?
cu!
Date: 23 Apr 2006 12:10:00
Message: <web.444ba68113671ebca842a49e0@news.povray.org>
In some situations, yes. In real life, when you walk outdoors, things don't
have a blue tint. I'm trying to get that sense without having completely
dark shadows behind objects.
> cu!
> #macro G(b,e)b+(e-b)*C/50#end#macro _(b,e,k,l)#local C=0;#while(C<50)
> sphere{G(b,e)+3*z.1pigment{rgb G(k,l)}finish{ambient 1}}#local C=C+1;
> #end#end _(y-x,y,x,x+y)_(y,-x-y,x+y,y)_(-x-y,-y,y,y+z)_(-y,y,y+z,x+y)
> _(0x+y.5+y/2x)_(0x-y.5+y/2x)            // ZK http://www.povplace.com
Date: 23 Apr 2006 12:30:07
Message: <444bab8f@news.povray.org>
Hash: SHA1
	Actually, they do. However most of the times, when the sky is blue
enough for the effect to be visible, you've got the sun shining
yellow light on the scene which balances the blue. But if you look
closely at a pure white object in shadow, you should notice that it
has taken a blue cast.
		Jerome
+------------------------- Jerome M. BERGER ---------------------+
|    mailto:jeb### [at] freefr      | ICQ:    238062172            |
|    http://jeberger.free.fr/     | Jabber: jeb### [at] jabberfr   |
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.2.2 (GNU/Linux)
iD8DBQFES6uOd0kWM4JG3k8RAgRMAJ9NvZMlPzngBvZHT3VwG8gm9GzPrwCff6ID
Pca5guFKGUilyW7+te7K2So=
=fM1s
-----END PGP SIGNATURE-----
Date: 23 Apr 2006 12:40:03
Message: <e2gafd$ut4$1@chho.imagico.de>
> have a blue tint.
That's not right.  The blue tint you observe would also occurs in real
life.  The reason why you find it unnatural is that you designed the
scene (textures, lighting etc.) to look natural without radiosity and
expect it to look the same with it.  This does not work.
You have the no_radiosity flag in MegaPOV to exclude certain objects
from radiosity calculation but this is just a artistic feature without a
  physical background.  If you want your render to look realistic you
should design the scene to look this way with radiosity and with sky.
http://www.imagico.de/ (Last updated 14 Mar. 2006)
Date: 23 Apr 2006 12:48:50
Message: <444baff2$1@news.povray.org>
sky_sphere
I'm thinking the gray_threshold in the radiosity-block was introduced for
just this.
But as others have already pointed out, the blue tint is actually realistic,
gray_threshold just takes the color out of the brightness.
Tim
aka "Tim Nikias v2.0"
Date: 23 Apr 2006 13:05:00
Message: <web.444bb39613671ebca842a49e0@news.povray.org>
Ok, that did it. Thanks!
> sky_sphere
> just this.
> Regards,
> Tim
> Homepage: <http://www.nolights.de>
Date: 23 Apr 2006 13:52:45
Message: <444bbeed@news.povray.org>
> have a blue tint.
  Would you call the blue tint in this image unrealistic, non-real-life-like?
http://warp.povusers.org/sponza.jpg
Date: 23 Apr 2006 15:00:01
Message: <web.444bcde113671ebca842a49e0@news.povray.org>
No, just that mine wasn't realistic
> > have a blue tint.
Date: 23 Apr 2006 15:18:14
Message: <444bd2f6@news.povray.org>
  Your image was probably realistic if you had set up a real-life scene
which was identical to your modelled scene.
  However, since your modelled scene was probably quite different from
what you usually see in real life, it was something unexpected, but not
unrealistic per se.
