POV-Ray : Newsgroups : povray.general : Re: How to Improve texture Server Time
27 Dec 2025 15:52:58 EST (-0500)
  Re: How to Improve texture (Message 1 to 4 of 4)
Subject: Re: How to Improve texture
Date: 1 Feb 2006 09:50:01
Message: <web.43e0c9dc69d30601f618c0@news.povray.org>
"RCRuiz" <ram### [at] hotmailcom> wrote:
> I try to emulate lava, but the mapping on the texture is not good wend the
> fluid move, is like it have some global mapping , how can i fix this? and
> How can I improve this texture?
What objects are you using to visualise the lava? blobs? try this:
1) apply one texture to every sphere instead of one texture for the whole
blob
2) apply the texture to the spheres and translate them afterwards. that way
the texture moves with the spheres
Hope that helps
Regards Roman
Date: 1 Feb 2006 11:15:01
Message: <web.43e0ddf269d3098a7cf320@news.povray.org>
> blob
> Hope that helps
> Regards Roman
Nope, I'n not using blobs , I make the Fluid Simulation in blender and
exported to Pov, so the object is a mesh, but every frame is a diferent
mesh, I will try with blobs if I do not have any other choice
Thanks for the reply
Date: 1 Feb 2006 11:40:00
Message: <web.43e0e32569d30601f618c0@news.povray.org>
> > blob
> > Hope that helps
> > Regards Roman
For a mesh uv_mapping would be the right solution but i don't know anything
about the uv_mapping abilities of blender. i doubt this would work in this
case anyway as this is not one mesh (with its vertices moving) but one
different mesh for every frame. maybe someone else knows a solution for
this. i'm out ;-)
Regards Roman
Date: 2 Feb 2006 09:05:00
Message: <web.43e210c169d3098a7cf320@news.povray.org>
> > > blob
> > > Hope that helps
> > > Regards Roman
> this. i'm out ;-)
> Regards Roman
No you right it did not work . Blender is very good with uvm but fluid
simulation becouse is regenerating the mesh it can nor control it :-( , But
thanks anyway
