POV-Ray : Newsgroups : povray.general : Animating People Server Time
19 Mar 2026 13:26:12 EDT (-0400)
  Animating People (Message 1 to 10 of 14)
Subject: Animating People
Date: 25 Jan 2006 19:40:01
Message: <web.43d81a10670091f6eed49ef10@news.povray.org>
I've been away from POV for a bit (around 1 1/2 years), so I haven't been
keeping up on what other people are doing.  I'd like to animate a person,
and I don't know if anyone's yet come up with an elegant solution for that
(ie, using a common file format such as skinned models from games would be
an elegant solution; typing in hundreds of bezier patches for each from
would not).  What have other people been doing to solve this problem?
If I need to, I'll work out my own system; I'd just rather not reinvent the
wheel.
....Chambers
Subject: Re: Animating People
Date: 26 Jan 2006 05:37:34
Message: <43d8a66e$1@news.povray.org>
"Chambers" <bdc### [at] yahoocom> wrote in message
news:web.43d81a10670091f6eed49ef10@news.povray.org...
> the
> wheel.
> ....Chambers
Hi Chambers,
I recently posted an Alpha copy of POV-Person. It generates a range of
people, does animations and a bunch of other stuff. It's free and is
designed to be readily extended. It doesn't yet have any converters for
common anatomical model file formats, but over the weekend I wrote a BVH
converter to convert some free motion capture data to POV-Person format to
increase the number of poses that it can handle, so that's coming soon (as
soon as I've debugged my converter).
It's still a work in progress and I get the impression that hardly anyone
has done anything with it yet, but then it's not been out for long.
I posted the source here:
http://news.povray.org/povray.binaries.scene-files/thread/%3C43bb0b2b%40news.povray.org%3E/
There's an example of a walking animation I generated using it here:
http://news.povray.org/povray.binaries.animations/attachment/%3C434287ae%40news.povray.org%3E/pp00animationexample0101.gif
Other Alternatives
Zeger Knaepen is working on an animated Muscle modelling macro. See the
thread:
http://news.povray.org/povray.binaries.animations/thread/%3C43c6bed8%40news.povray.org%3E/
Most of the human forms in POV-Ray I've seen on the newsgroups recently have
been exported from Poser or from modellers.
I think this is how the 'Fighting Temeraire and Friend' mpeg that Stephen
posted at
http://news.povray.org/povray.binaries.animations/thread/%3Co5cos1tjr1upujtsa0417f0cqtq8ddeg16%404ax.com%3E/
was probably generated. It was his posting and his link to the BVH files
that got me writing the converter mentioned above.
Otherwise, most POV Scenes still seem largely devoid of human life.
Chris B.
Date: 26 Jan 2006 06:26:48
Message: <hfcht151c6eov2mfpah6073b5frvjmeb0m@4ax.com>
On Thu, 26 Jan 2006 10:37:33 -0000, "Chris B"
>posted at
Of course, you are right. It was some new BVH files that I found
(available if anyone wants them 2.5 Meg) that prompted me to post.
I'm interested to hear about your converter, keep us informed.
Date: 26 Jan 2006 11:00:01
Message: <web.43d8f114815b384a40d56c170@news.povray.org>
> wheel.
> ....Chambers
Some have done it with just intelligent stacking of a lot of spheres.
(See the source code for Pool Shark at
http://irtc.org/anims/1998-10-15.html)
I myself use either CSG, blobs, or Mike William's sweepspline code
(http://flickr.com/photos/pterandon/sets/110545/).
I haven't released the code because I vascillate between thinking it too
lame or too precious.  I did put a basic stick figure using cylinders into
one of these forums a long time ago. It's the same system, just prettier.
If you build your system where you think in the construction of every
element in terms of transforms, then you can set up a separate scene file
to define all your transforms as a function of the clock.  Build it with
time-zero construction, then instert a
transform{Your_Right_Forearm_Transform} at the end. Then figure out a
transform that moves that limb from the time-zero position to the position
you want it in.
I haven't figured out how to make bicubic patches work where povray SDL
itself does the bending and stretching.
Date: 26 Jan 2006 12:07:10
Message: <43d901be$1@news.povray.org>
I wouldn't mind seeing them. I went looking for BHV files on google a
while ago, but I could only find the specs. What terms did you use, or
did you get them from someone "in person"?
    Luke, the Force is a powerful ally,
    second only to The QuickSave.
Date: 26 Jan 2006 21:16:46
Message: <9k0jt11sfr5o3rrimoauh61tk65p8o08hb@4ax.com>
On Thu, 26 Jan 2006 09:07:14 -0800, Darren New <dne### [at] sanrrcom>
My pleasure to share them. I downloaded most from an American
University that was running a media course now discontinued. And I
picked up 80 martial arts ones from the internet. This has been over a
couple of years. I have about 500 files which come to about 35.7 Meg
zipped. If you drop me a line we can arrange a way of getting them to
you or anyone else. Unfortuanly I don't have a website I can upload
them to.
Date: 26 Jan 2006 22:34:20
Message: <43d994bc$1@news.povray.org>
> wheel.
I have a modeler at www.geocities.com/evilsnack/lionsnake.htm , which
can do a reasonably human-looking model if you take the time.  The
joints will probably have the "bent tube" effect that is painfully
obvious on the elbows of most Poser rendering that I've seen.
I haven't added skin or muscle simulation, or morphs either, but I hope
to do so at some point in the future.
I tried to make the modeler as intutive as possible; right-clicking in
the edit window should give you a pop-up with all of the available options.
John
Date: 27 Jan 2006 01:10:40
Message: <43d9b960$1@news.povray.org>
Stephen wrote:
> Unfortuanly I don't have a website I can upload them to.
Well, if it's not a violation of their copyright, you can put them on
ftp://povray:xyz### [at] sgfdnsaliascom/incoming/
There should be lots of gigs free there. Others should feel free to pull
them from there when you've finished. If it fails, I'm probably
rebooting the machine for some reason and it'll be back in 10 minutes.
It's on cable, so uploading to the machine should be quite fast.
Remember to use binary mode. :-)
You might want to consider putting them into multiple smaller zips, if
it's convenient.
Thanks!
    Crate & Barrel -
      Furnishing Video Games Since 1962!
Date: 27 Jan 2006 04:20:28
Message: <43d9e5dc@news.povray.org>
The BVH files I'm using are here: http://www.bvhfiles.com/
There's also a BVH viewer available from there that I've found useful.
There's a lot of them and they are mostly simple movements (not as complex
as the sequence of movements Stephen used).
Chris B.
Date: 27 Jan 2006 08:04:36
Message: <n86kt1t2a8m5e7m3ho4hbap04okfj3133o@4ax.com>
On Fri, 27 Jan 2006 09:20:26 -0000, "Chris B"
Thanks, I lost that the last time my HD crashed. It's quicker than
loading them into Poser for a quick view.
