POV-Ray : Newsgroups : povray.general : Trace question Server Time
28 Feb 2026 17:20:09 EST (-0500)
  Trace question (Message 1 to 9 of 9)
Subject: Trace question
Date: 21 Oct 2005 14:55:00
Message: <web.43593899299fff6083b840600@news.povray.org>
I've been working with a tutorial on the trace() function in conjunction
with a random placement macro.  I'm getting some great results, but I was
wondering: Is there any way to make my macro take into account the objects
it's already placed on the surface, such that there would not be any
overlaps?  I'd like to be able to  have the objects pile up as more of them
are generated.
A.D.B.
Subject: Re: Trace question
Date: 21 Oct 2005 17:28:45
Message: <43595d8d$1@news.povray.org>
> are generated.
  You can declare an union with copies of the placed objects, without
using it on the scene, just for trace() test purposes on next calls to
the macro.
Jaime
Date: 21 Oct 2005 20:35:01
Message: <web.435989224e074c266f9348f0@news.povray.org>
> are generated.
> Regards,
> A.D.B.
That's a good idea. I keep thinking that there's a demo file included with
POV-Ray of alphabet blocks stacked up that might be useful to look at.
Date: 22 Oct 2005 04:07:43
Message: <4359f34f@news.povray.org>
> overlaps?
  Generic collision detection is almost impossible.
  However, you can make it so that if the distance between the new object
to be placed to any of the other objects is smaller than a certain distance,
you don't place the object there.
  This, of course, requires that you keep the locations of the objects
in an array and you make the check using that.
Date: 22 Oct 2005 04:35:01
Message: <web.4359f9024e074c21ae306d60@news.povray.org>
> are generated.
> Regards,
> A.D.B.
Do you know you can add to a union? Here's an example from one of my Penrose
triangle scenes.
#debug "\nIgnore following warning, this union intentionally empty\n"
#declare Null = union{}
#debug "Ignore previous warning, this union intentionally empty\n"
#declare SetT = Null;
#macro AddTri(A,B,C) #declare SetT = union{object{SetT} Tri(A,B,C)} #end
Also take a look at these POV standard scenes:
 advanced/gaussianblob.pov by Greg M. Johnson (& Rico Reusser).
and
 advanced/blocks/makestacks by Gilles Tran, derived from work by John Van
Sickle and Christoph Hormann, although this one has bits I don't quite
follow myself as yet... :)
I hope this helps.
Date: 22 Oct 2005 23:06:53
Message: <435afe4d$1@news.povray.org>
>>are generated.
>>Regards,
>>A.D.B.
> triangle scenes.
> and
> I hope this helps.
What purpose does that serve, besides an annoying error message?  I fail
to see how you could even get such a scene to parse without shutting
down - you've declared the same parameter twice.
A.D.B.
Date: 23 Oct 2005 03:12:59
Message: <435b37fb$1@news.povray.org>
In POV-Ray, "declare" is more like a "set" statement; there's no real
declaration of variables. So
#declare myvar = 1;
#declare myvar = myvar + 1;
is perfectly fine, and myvar will have the value 2.
Aside from that, his example isn't complete as it doesn't include the Tri()
macro, but it illustrates how to add objects to a union one at a time. By
tracing against the union, you can do collision detection against previously
placed objects.
The flaw with this approach is that the union isn't optimized with a
bounding box heirarchy or anything, which means that as more objects are
added it will start to get slow to trace().
 - Slime
 [ http://www.slimeland.com/ ]
Date: 23 Oct 2005 17:16:21
Message: <435bfda5$1@news.povray.org>
>>are generated.
>>Regards,
>>A.D.B.
> triangle scenes.
> and
> I hope this helps.
Thanx.
	After a little thought, I was able to implement a stacking function
based largely off the code snip you posted. I am, however, still getting
some overlap.  I think it's going to have to be a combination of the two
methods suggested.
	I need to figure out a way to trick the macro into thinking that the
object's bounds extend a minimum distance (Laterally) from the actual
object.  Can this be done by setting the bounding box manually?  If so,
how is this accomplished?
I've posted a test render in P.B.I.
A.D.B.
Date: 23 Oct 2005 22:37:58
Message: <435c4906$1@news.povray.org>
> methods suggested.
I think you'll need to run four traces per cube for each of the corners
on the XZ plane. (and if you're rotating, you might want to add more
traces along each side ..)
You can then take the higest Y of the four traces as the lowest your
object can be at that point. If you ignore balancing, that's where to
place your next cube. If you want to take balancing into account, I
reckon you're screwed .. consider this:
That would probably balance OK. But then if you go up another level:
it's clearly going to topple the middle one off the stack as well as the
top one. And once you've placed it, you can't move it (unless you're
working with an array which you'll later render) and the correct 'fall'
might be this:
      _-+
      \  _+
which is all the harder :)
Personally, I'd either be positioning them all by hand, ignoring balance
or calculating falls externally (like a perl or C program)
Cheers!
Rick Measham
