POV-Ray : Newsgroups : povray.general : Object oriented Povray? (Modifying existing objects) Server Time
22 Nov 2025 05:15:54 EST (-0500)
  Object oriented Povray? (Modifying existing objects) (Message 1 to 10 of 10)
Subject: Object oriented Povray? (Modifying existing objects)
Date: 28 Feb 2005 16:45:01
Message: <web.4223902ef4bf0e27820779d30@news.povray.org>
I know you can use #declare statements to create reusable objects, but is
there any way to modify individual instance once they've been instantiated?
Or is that not a feature of the language at this point? I'm thinking of
something like this:
#declare ball = sphere
 // basic ball attributes go here
ball ball1, ball2, ball3
ball1.translate<0,1,0>
ball2.pigment = rgb<1,0,0>
ball3.scale<10,10,10>
Apologies for the poor syntax; I haven't worked much with raw Povray code
lately!
Subject: Re: Object oriented Povray? (Modifying existing objects)
Date: 28 Feb 2005 18:17:21
Message: <4223a681$1@news.povray.org>
"ekolis" <kol### [at] fusenet> wrote in message
news:web.4223902ef4bf0e27820779d30@news.povray.org...
instantiated?
> lately!
#declare ball = sphere {
 1, <0, 1, 0>
 pigment {rgb <1, 0, 0>}
 //... and so on
object {
 ball
 translate <0, 1, 0>
object {
 ball
 pigment {rgb <1, 0, 0>} //not sure that this will override the pigment
statement in the #define'd ball
object {
 ball
 scale <10, 10, 10>
anyway, is that what you were asking?
Date: 28 Feb 2005 18:20:42
Message: <4223a74a$1@news.povray.org>
"Ross" <rli### [at] everestkcnet> wrote in message
news:4223a681$1@news.povray.org...
is
> instantiated?
code
> > lately!
>  1, <0, 1, 0>
oops. that should be
sphere {
 <0, 1, 0>, 1
Date: 28 Feb 2005 20:50:00
Message: <web.4223c982fd3c3a0b820779d30@news.povray.org>
Cool!
Basically what I wanted to do is have a set of base objects like a laser
cannon and a particle gun and such (I'm making images for a Space Empires
IV mod inspired by Master of Orion II ;-), but generate a bunch of
variations on each of them (for various enhancements that can be applied,
such as "heavy" or "armor piercing") by running through a loop and doing
modifications (like scaling up or adding coolant tubes)... it would take
forever to do all the possibilities, but if I could use a single script to
render all the images, and just include the actual models from exported
..ini files from KPovModeler... ;-)
And if you're a fan of MOO2, yes, there will be a heavy point defense shield
piercing armor piercing no range dissipation autofire continuous enveloping
ion pulse cannon image, even though MOO2 never allowed such a thing...
mwahahaha! :-D
Date: 1 Mar 2005 01:06:15
Message: <S3fXiGAnSAJCFw73@econym.demon.co.uk>
Wasn't it ekolis who wrote:
>Cool!
>mwahahaha! :-D
As mentioned above, you can apply object modifiers to copies of a
declared object - that's things like textures, translations, scales and
rotations.
You want to change the structure of the object, so I suggest making a
macro to which you can pass parameters.
#macro Laser_cannon (Heaviness, Armour_Piercing, Coolant_Tubes)
  object {
      code that uses the passed variables
      to generate different varieties
      of laser cannon
Then you can invoke the macro and place the objects
object {Laser_cannon(5.25, false, 3) rotate y*30 translate <10,0,3>}
object {Laser_cannon(2, true, 0) rotate y*55 translate <3,0,4>}
Mike Williams
Gentleman of Leisure
Date: 1 Mar 2005 05:26:51
Message: <4224436b@news.povray.org>
  You can instantiate the object and apply transformations to it.
If it didn't have a texture, you can also apply one. However, that's
about it. You can't access any of its other parameters (not in the
current SDL anyways).
Date: 1 Mar 2005 17:11:15
Message: <4224e883$1@news.povray.org>
Mike Williams nous apporta ses lumieres en ce 2005-03-01 00:59:
>>Cool!
>>mwahahaha! :-D
> rotations.
>   object {
>       of laser cannon
> #end
You can extrapolate by including pigments, textures and even materials as parameters.
That way, you
can have one with mate green tubing, end another with transparent, multicaloured,
glowing "plasma"
filled tubes.
Date: 3 Mar 2005 13:48:32
Message: <42275c00@news.povray.org>
> object {
> ball
No, it won't.
POV-Ray docs - section 3.4.6.2:
[...] The entire union can share a single texture but each object contained
in the union may also have its own texture, which will override any texture
statements in the parent object.
Date: 3 Mar 2005 13:55:36
Message: <42275da8$1@news.povray.org>
contained
texture
I think that only applies to unions; when it's a direct copy of an object
that you're setting the texture on, I think it overrides the original
(though, if the object were a union, it wouldn't override the textures of
the subobjects of the union).
 - Slime
 [ http://www.slimeland.com/ ]
Date: 4 Mar 2005 05:29:54
Message: <Xns960F74F7BBE94jgrimbertmeandmyself@203.29.75.35>
> contained
> texture
I think it does not override, it just apply an additional layer of texture.
No difference, until your new texture has some transparency or filtering.
This is an unauthorised cybernetic announcement.
When someone says "I want a programming language in which I need only
say what I wish done," give him a lollipop.
