POV-Ray : Newsgroups : povray.general : "Access violation at address 01161E12 in module 'povcmax2.dll'..." Server Time
30 Mar 2026 04:04:36 EDT (-0400)
  "Access violation at address 01161E12 in module 'povcmax2.dll'..." (Message 1 to 5 of 5)
Subject: "Access violation at address 01161E12 in module 'povcmax2.dll'..."
Date: 23 Oct 2004 07:00:01
Message: <web.417a39376bc0293117968a7d0@news.povray.org>
Hello all
I was hoping someone out there could help me! I'm trying to generate nice
pictures of a protein structure, but the output .pov file from VMD cannot
be loaded into POV-ray for some reason. What I get is the the error:
Access violation at address 01161E12 in module 'povcmax2.dll'. Read of
address 00000000.
I press OK and it then says:
Failed to open file: The operation completed successfully.
When I then try to open it again, it says:
Failed top open file: Not enough storage is available to process this
command.
Are these two things related?
I have POV-ray v3.6 installed on a PC running Win2003 and has 1GB RAM. The
program is running from a primary partition of 20GB (with 12GB free), and
my .pov file is on a secondary partition of 65GB (with 4GB free). Also, the
..pov file itself is 246MB...
I have a second smaller question to do with the actual rendering. I get a
lot of comments about denegerate triangles. Is there an easy way of getting
rid of them?
Any help would be much appreciated!
Uplah
Subject: Re: "Access violation at address 01161E12 in module 'povcmax2.dll'..."
Date: 23 Oct 2004 07:15:02
Message: <cldef7$39b$1@chho.imagico.de>
Uplah wrote:
> Hello all
> address 00000000.
Have you tried rendering it without opening it in the editor?  With
large files containing very long lines the editor might have troubles
but POV-Ray should render them without problems.
> rid of them?
Yes, removing the degenerate triangles. ;-)
Degenerate triangles are either triangles with collinear vertices or
smooth triangles with ambiguous normal vectors.  Any program generating
meshes should take care of not generating such triangles.
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
Date: 23 Oct 2004 08:05:00
Message: <web.417a489c2785c4e817968a7d0@news.povray.org>
YAY!
Thanks Christoph!
I suddenly realised that the .pov file is just a text file! So I just fired
it up in Wordpad, did what I had to do and did a quick render in POV-ray
without having to load it in the editor - brilliant!
Still get the degenerate triangles though... Seems VMD is not doing an
optimal job (?). Do I need to worry about getting rid of them? Is there a
simple program that can do this?
Many thanks in advance!
Uplah
Christoph Hormann <chr### [at] gmxde> wrote:
> Uplah wrote:
> > Hello all
> > address 00000000.
> > rid of them?
> Christoph
> POV-Ray tutorials, include files, Sim-POV,
> HCR-Edit and more: http://www.tu-bs.de/~y0013390/
> Last updated 23 Sep. 2004 _____.//^>_*_<^/.______
Date: 23 Oct 2004 11:07:56
Message: <417a73cc$1@news.povray.org>
Uplah nous apporta ses lumieres ainsi en ce 2004-10-23 08:03... :
>YAY!
>Thanks Christoph!
Not realy, it just take longer to parse (time to display the warnings)
and gobble up some memory.
> Is there a
Not that I'm aware of
>Uplah
You may try using a croaser mesh, biger steps. The resulting image won't
be as smooth, you'll get some facing and shadow glitches, but with
larger triangles, the chances of aving degenerate ones will decrease.
Date: 24 Oct 2004 14:36:16
Message: <417bf620@news.povray.org>
Uplah wrote:
> YAY!
> Thanks Christoph!
> Uplah
If VMD can export to DXF, OBJ, 3DS, LWO or RAW you can use PoseRay
(http://user.txcyber.com/~sgalls/). PoseRay will delete all collapsed
faces on load. You can also export at a lower mesh resolution and use
PoseRay's subdivision feature before rendering the model.
later,
FlyerX
