POV-Ray : Newsgroups : povray.general : How to render faster? Server Time
30 Mar 2026 04:04:39 EDT (-0400)
  How to render faster? (Message 1 to 10 of 17)
Subject: How to render faster?
Date: 9 Oct 2004 22:30:00
Message: <web.41689e5939249baca3f068ef0@news.povray.org>
Hello. Is any way to put my radeon 9800 pro to render the scene in povray?
Some script or else?
Thank you.
Subject: Re: How to render faster?
Date: 9 Oct 2004 23:07:49
Message: <4168a785$1@news.povray.org>
No, POV-Ray implements the ray-tracing algorithm which is not used by video
cards.
http://tag.povray.org/povQandT/miscQandT.html#3dcard
 - Slime
 [ http://www.slimeland.com/ ]
Date: 10 Oct 2004 11:54:28
Message: <41695b34$1@news.povray.org>
armands nous apporta ses lumieres ainsi en ce 2004-10-09 22:28... :
>Thank you.
Your video card won't make any difference. Even using an old Hercules 8
colours ISA CGA card, from the 286 or earlier era, won't change the
rendering performences!
(if you manage to use such an old card)
Date: 12 Oct 2004 06:26:04
Message: <416bb13c$1@news.povray.org>
>> povray? Some script or else?
> video cards.
3D cards do actually have some things which are useful to ray-tracing, like
all the geometry transformation operations, and the ability to run the same
code many times on different data very efficiently.  In fact I believe some
people have already written ray tracers for 3D cards with pixel shader
support.
Maybe in the future there will be a way for POV to take advantage of some of
these operations.
Date: 13 Oct 2004 02:46:28
Message: <Xns95815942AC903jgrimbertmeandmyself@203.29.75.35>
>> video cards.
> like all the geometry transformation operations, and the ability to
> run the same code many times on different data very efficiently.  In
> fact I believe some people have already written ray tracers for 3D
> cards with pixel shader support.
> some of these operations.
Unless PoV turn into a stupid triangle-renderer, as well as becoming non-
portable and very hardware aware, do not count on it (and it would at
best be a very marginal gain (not even warranted)).
Now, if you could increase your understanding of
http://tag.povray.org/povQandT/miscQandT.html#3dcard , I think I would be
happier :-)
l'habillement, les chaussures que le maquillage et les accessoires.
Date: 13 Oct 2004 05:30:04
Message: <416cf59c@news.povray.org>
>>> by video cards.
>> ray-tracing, like all the geometry transformation operations, and
>> the ability to run the same code many times on different data very
>> efficiently.  In fact I believe some people have already written ray
>> tracers for 3D cards with pixel shader support.
> non- portable and very hardware aware, do not count on it (and it
> would at best be a very marginal gain (not even warranted)).
http://moe.jrq.ch/?iC=pjs&iP=psrt
Is a good example.
> would be happier :-)
I think I would be happier if you could increase your understanding of how
pixel shaders work on the latest 3D cards :-)
I haven't looked at the code in detail, but the basic idea is that you give
the "data" to the pixel shader pipeline in the form of textures.  The pixel
shader in the GPU can then perform the usual ray-object intersection code,
and give the output in the form of a texture.  The main CPU then reads this
texture and uses it to construct the final image.
The pixel shader GPU has been designed in hardware to run the same code on
lots of data very quickly, this is ideal for raytracing calculations.  And
it isn't impossible to use it for raytracing calculations.  In the future as
GPUs allow longer pixel shader programs to run, doing more and more complex
ray tracing will become possible.
Google for "pixel shader raytracer", I'm sure you'll come up with something.
IIRC it was either NVidia or ATI that have a raytracer as one of the demos
in their pixel shader development kit.
Date: 13 Oct 2004 09:26:46
Message: <416d2d16$1@news.povray.org>
"scott" <sco### [at] spamcom> wrote in message news:416cf59c@news.povray.org...
... but this misses the point. Irrespective of whether modern 3d card
acceleration options are compatible with raytracing or not, povray is
unlikely to support them if it requires custom code.
On the other hand, if the 3d card automatically took over the calculation
from the main CPU when appropriate....
That said, given what I understand of POV and 3d cards, unless 3d cards were
suitable for involvement in *any* intensive CPU activity, then I fail to see
why they would be of use.
Povray, after all, is about creating a file from a series of calculations -
the display of the image is not part of povray's job.
Date: 13 Oct 2004 13:05:57
Message: <416d6075$1@news.povray.org>
>> of how pixel shaders work on the latest 3D cards :-)
> calculation from the main CPU when appropriate....
The way you write code for a pixel/vertex shader is so different from that
of a normal CPU, I think that would be almost impossible.
> cards were suitable for involvement in *any* intensive CPU activity,
> then I fail to see why they would be of use.
Well, if you write a ray-object intersection algorithm that runs on the GPU,
that would certainly help a lot.  Of course POV-ray would need to be
modified (and this will not likely happen, but it could be a patch, or
another raytracer entirely).  GPUs are *very* fast at doing the same code in
parallel.  So POV could give the GPU a batch of rays to calculate
intersections with, the GPU can go away and do this and return the result
when it's done.  During this time the CPU can also be doing the same (and
working out the pixels from the last GPU result).  It would certainly speed
things up, look at that link where they guy was getting 30fps from his
simple raytracer and then was getting 1200fps when it was running with the
GPU helping.
Don't forget that GPUs can run pixel shaders at stupid speeds, of the order
of millions of texels/second, that's *far* faster than any code could run on
a normal CPU.
> calculations - the display of the image is not part of povray's job.
True, and the job of a pixel shader in a GPU is to run code and output a
chunk of data.  Normally that chunk of data is then displayed on the screen,
but it doesn't have to be!
Date: 16 Oct 2004 14:07:13
Message: <cjameshuff-AC4DBE.14065416102004@news.povray.org>
In article <416d6075$1@news.povray.org>, "scott" <sco### [at] spamcom>
> GPU helping.
It's still not very useful to POV-Ray. It'd spend too much time copying
data to and from the card, and pulling data off the card is generally
not a fast operation...they're optimized for displaying triangles and
crunching numbers local to the card. What these demos are do is
basically hard code a simple, small raytracer and scene designed around
the abilities of the card into the pixel shader. It's fast because it
all fits on the card and it doesn't do anything that needs to move stuff
between the card and the main system. In addition, precision limitations
will be a huge problem...POV uses double precision for most
calculations, and it needs them. From what I've seen, GPUs use half
precision...good enough for a demo, but not enough for general
raytracing.
It's a neat trick, but it's just not general enough to handle what
POV-Ray needs to do. You might be able to make use of it with a more
limited raytracer (maybe a scientific visualization app, for example),
but it's of no help to POV-Ray.
Date: 18 Oct 2004 04:45:42
Message: <417382b6$1@news.povray.org>
>> the GPU, that would certainly help a lot.  Of course POV-ray would
>> need to be modified (and this will not likely happen, but it could
>> be a patch, or another raytracer entirely).  GPUs are *very* fast at
>> doing the same code in parallel.  So POV could give the GPU a batch
>> of rays to calculate intersections with, the GPU can go away and do
>> this and return the result when it's done.  During this time the CPU
>> can also be doing the same (and working out the pixels from the last
>> GPU result).  It would certainly speed things up, look at that link
>> where they guy was getting 30fps from his simple raytracer and then
>> was getting 1200fps when it was running with the GPU helping.
> copying data to and from the card, and pulling data off the card is
> generally not a fast operation...they're optimized for displaying
> triangles and crunching numbers local to the card. What these demos
> are do is basically hard code a simple, small raytracer and scene
> designed around the abilities of the card into the pixel shader. It's
> fast because it all fits on the card and it doesn't do anything that
> needs to move stuff between the card and the main system. In
> addition, precision limitations will be a huge problem...POV uses
> double precision for most calculations, and it needs them. From what
> I've seen, GPUs use half precision...good enough for a demo, but not
> enough for general raytracing.
Oh yes, I realise this.  Just worth keeping an eye on in the future, I'm
sure the GPUs are going to get more and more complex.
