POV-Ray : Newsgroups : povray.general : Clouds Don't Cast Shadow Server Time
2 Jan 2026 09:41:27 EST (-0500)
  Clouds Don't Cast Shadow (Message 1 to 10 of 20)
Subject: Clouds Don't Cast Shadow
Date: 12 May 2004 13:05:00
Message: <web.40a258ef66383bf31a36c3040@news.povray.org>
My POV-ray tutorial told me that if I wanted the sun created by the
sky_sphere command to emit an apparent shadow through clouds, I'd have to
make a really large sky_sphere with the proper texture,and put the
light_source outside the sky_sphere. How do I do that, since the tutorial
never told me? Here's the programming language below I used to create the
sky_sphere with the sun and clouds, but the clouds do not cast shadows.
#include "finish.inc"
  location <0,1,-10>
  look_at <0,4,0>
  angle 80
light_source {<0,1e4,10000>White scale 1300}
sphere {
  <0,2,0>,1
  pigment {color rgb <1,1,1>}
  finish {ambient .2 diffuse 0 reflection .6}
sky_sphere {
    gradient y
    color_map {
      [0,.002 color rgb<1,.2,0>
              color rgb<1,.2,0>]
      [.002,.2 color rgb<.8,.1,0>
               color rgb<.2,.2,.3>]
  scale 2
  translate -1
  bozo
  turbulence .65
  octaves 6
  omega .7
  lambda 2
  color_map {
    [0,.1 color rgb<.5,.5,.5>
          color rgb<.75,.75,.75>]
    [.1,.5 color rgb<1,1,1>
           color rgbt<1,1,1,1>]
    [.5,1  color rgbt<1,1,1,1>
  scale .1
rotate -135*x
plane {
  y,0
  pigment {color Green}
  finish {ambient .3 diffuse .7}
Subject: Re: Clouds Don't Cast Shadow
Date: 12 May 2004 13:31:29
Message: <frn4a0dk8icgdem15vci3vrdejg3hc483r@4ax.com>
The Pov-Ray sky_sphere is a background sort of thing. You cannot put
anything behind it.
The Pov-Ray documentation Section 3.11.2.3  Adding Some Clouds
Says;
The sky sphere has one drawback as you might notice when looking at
the final image (skysph3.pov). The sun doesn't emit any light and the
clouds will not cast any shadows. If you want to have clouds that cast
shadows you'll have to use a real, large sphere with an appropriate
texture and a light source somewhere outside the sphere.
I wonder where you got your tutorial it seems to be leading you
astray.
Regards
Date: 12 May 2004 13:38:56
Message: <40a26130@news.povray.org>
Hash: SHA1
have to
tutorial
create the
	You can't do it with a sky_sphere, since by definition it is infinite
and therefore behind the clouds. So what you do is use a regular
sphere with a large radius and your cloud texture with the blue parts
replaced by a transparent color. Then all you have to do is put your
light source further out. Something like that (the texture will almpst
certainly require tweaking):
sky_sphere {
~  pigment {
~    gradient y
~    color_map {
~      [0,.002 color rgb<1,.2,0>
~              color rgb<1,.2,0>]
~      [.002,.2 color rgb<.8,.1,0>
~               color rgb<.2,.2,.3>]
~  scale 2
~  translate -1
sphere {
~  0, 1000000000
~  pigment {
~  bozo
~  turbulence .65
~  octaves 6
~  omega .7
~  lambda 2
~  color_map {
~    [0,.1 color rgb<.5,.5,.5>
~          color rgb<.75,.75,.75>]
~    [.1,.5 color rgb<1,1,1>
~           color rgbt<1,1,1,1>]
~    [.5,1  color rgbt<1,1,1,1>
~  scale .1
~  rotate -135*x
*      Jerome M. Berger      *
* mailto:jbe### [at] ifrancecom *
*  http://jeberger.free.fr/  *
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.2 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFAomEvqIYJdJhyixIRAi4kAJ99hIPdaB5KKKQAEo6P8tOuCkk1OQCeNvVX
dIWUfnpIKMV6F2XFJHCWZzY=
=s25j
-----END PGP SIGNATURE-----
Date: 12 May 2004 15:15:00
Message: <web.40a276f4f48fa4edf438a2280@news.povray.org>
> sky_sphere {
> ~  pigment {
> ~    gradient y
> ~    color_map {
> ~  scale 2
> ~  translate -1
> sphere {
> ~  0, 1000000000
> ~  pigment {
> ~  bozo
> ~  turbulence .65
> ~  octaves 6
> ~  omega .7
> ~  lambda 2
> ~  color_map {
> ~  scale .1
> ~  rotate -135*x
OK, I created a very large sphere with a pigment and color_map in many
similarities to yours. Unfortunately, the clouds always show up as dark.
What tweaking is necessary to lighten them up?
And I realize that my tutorial, which I downloaded with POV-ray for Windows
v3.5 told me something that seemed a bit off, but now I realize that the
tutorial meant a literal "sphere," not a "skysphere."
Date: 12 May 2004 15:21:31
Message: <40a2793b$1@news.povray.org>
"CFM" <nomail@nomail> wrote in message
news:web.40a276f4f48fa4edf438a2280@news.povray.org...
If the only light in your scene is the "sun" then maybe only the back of the
clouds are recieving light. You could try to add lights between the ground
and the clouds, to illuminate the visible parts of the clouds
Date: 12 May 2004 16:22:45
Message: <40a28795$1@news.povray.org>
the
Or use double_illuminate, so that both sides of a surface are lit.
"Tim Nikias v2.0"
Date: 12 May 2004 16:38:52
Message: <40a28b5c$1@news.povray.org>
Hash: SHA1
| the
ground
	Or add: finish { ambient 1.0 diffuse 0.0 } to get the same effect as
with the sky_sphere
		Jerome
iD8DBQFAootbqIYJdJhyixIRAlYJAKCsyjeu27AynvoZQidZOApnuJ0XHACeLgoL
oS+/X+ZEfpBlxyZmw4vd/TU=
=rXkT
Date: 12 May 2004 17:05:52
Message: <cjameshuff-3E8A27.16055912052004@news.povray.org>
In article <40a28795$1@news.povray.org>,
 "Tim Nikias v2.0" <#macro timnikias (@) #local = "gmx.net" #end>
> the
Both of these will cause additional shading effects due to the angle of
incidence of the light rays varying over the surface of the sphere. The
correct solution is to use ambient 1 and diffuse 0 in the finish, as
lighting.
http://tag.povray.org/
Date: 12 May 2004 17:50:42
Message: <40a29c32$1@news.povray.org>
Christopher James Huff nous apporta ses lumieres ainsi en ce 2004/05/12
17:05... :
>>the
>lighting.
Using that technique, don't forget to put the main light *far* outside
the big sphere. If you don't, the shadows will get blown up to gigantic
proportions. Placing the main light around 10 times the sphere radius
should give you fair results, as well as using parallel light.
Date: 13 May 2004 05:10:45
Message: <40a33b95@news.povray.org>
In some cases using one (or more) y planes will produce better looking clouds
than a sphere. And it's easy to animate too - you can translate the texture in
x/z to simulate wind and in y to make the clouds change their shape...
-sascha
