POV-Ray : Newsgroups : povray.general : Parsing a data set Server Time
11 Jan 2026 11:53:42 EST (-0500)
  Parsing a data set (Message 1 to 9 of 9)
Subject: Parsing a data set
Date: 29 Mar 2003 11:45:19
Message: <web.3e85cca8c6bb32750ee32b10@news.povray.org>
Hey Everybody,
It's been about 3 years since I did any major POV'ing but I need to make
some quick, yet impressive, 3d images to go in my dissertation (Simulating
flocks with boid technlogy) and POv sprang to mind.  However Im extreamly
rusty andthe last time I touched animations with POV was back on my 486
using Daves TGA Animator kit.
What I need to do is read in a set of position coordinates and orientations
for each scene for a fintie number of positions (of fish), either from a
single flat text file or one for each frame, render them and string them
together.
The modelling, rendering and stringing together I have sorted - but it's the
parsing of the file(s) holding the data im having trouble with - does
anybody know of a quick (eg. pre-existing ) external program to do it or
does somebody have some hand-rolled POV code to do such a thing ?
Thanks awfully,
oli (glad to be back)
oliver (at - spammers evil software begone - )coldclimate.co.uk
Subject: Re: Parsing a data set
Date: 29 Mar 2003 11:53:39
Message: <3E85CE85.FB520F2F@comcast.net>
Oli,
   Check my hermite curve generator.  The input files are simple to create
from 3-d coords.
http://www.geocities.com/emory_stagmer/povherm
It makes in-betweening simple.  The object pass through the control points,
you specify how many frames to the next control point, and the curve is a
smoothing function between them.
At every control point is a vector to which the curve is tangent both into
and out of the control point (piece-wise smooth).
There's example POV source there too...should work great for a Boids sim...
Emory
oliWood wrote:
> Hey Everybody,
> together.
> Thanks awfully,
Date: 29 Mar 2003 12:35:11
Message: <3e85d94f@news.povray.org>
I don't know what you're actually after here. Reading
the data? And can you modify the way in which the
data is written? If you're working from within POV with
POV-script, reading and writing could be done with
my IO-Macros, but aside of that, I don't know how I
could help.
Tim Nikias v2.0
Email: Tim### [at] gmxde
> Hey Everybody,
orientations
> together.
the
> Thanks awfully,
Date: 29 Mar 2003 14:20:17
Message: <web.3e85f1cceb11af84b0be54280@news.povray.org>
>could help.
Sorry - I didnt make myself very clear (having read it back).
Im using a Java program to generate my data, and thus can easily alter
how/what im outputting.
Basically at the minute im outputting a single long text file where each row
holds the x and y coords of a fish and it's orientation (rotated around the
Z axis - right-hand- coord sys).
Between each of the "frames" of data theres a * e.g. theres a 100 lines of
coords etc then a * and then another 100 lines.
If i could read this file in with a bit of POV script and then use the Clock
to cycle through the datasets to place 100 fish for each frame that would
be great.  Failing that i can use Perl to split the file into a heap of
seperate ones , eg. one for each frame, and then somehow read a different
file in for frame of the animation (use the clock vlaue to pick a file name
possibly?)
Hope that clears the fog,
oli
Date: 29 Mar 2003 15:02:20
Message: <Xns934DD66ED309Cseed7@povray.org>
> orientations for each scene for a fintie number of positions (of
> fish), either from a single flat text file or one for each frame,
> render them and string them together.
Read "6.2.3  File I/O Directives" from the docs.
You'll have to put your data comma sepparated in your text file.
Ingo
Date: 29 Mar 2003 17:33:33
Message: <3e861f3d@news.povray.org>
If you'd set your JAVA program to output like this:
Coordinate , Orientation, Coordinate, Orientation, ...,
if you know the amount of boids, and if you make sure
that there's always a comma after every coordinate
or orientation (even after the last one!), you could use
something like:
#declare Boid_Amount=0;
#declare _Counter=0;
#fopen _D Data_File read
//This jumps ahead to the needed frame
#while (_Counter<frame_number*Boid_Amount)
 #read (_D,_Coord, _Orient)
 #declare _Counter=_Counter+1;
//This reads the required data
#while(defined(Data_File) & Boid<Boid_Amount)
 #read (_D, _Coord, _Orient)
 #declare Boid=Boid+1;
 [... Do some stuff with _Coord and _Orient to place a boid ...]
#fclose _D
This should work if frame_number begins with 1. The first
loop will read past the earlier frames, and the second will
read the necessary data. I can't test it without a file though,
so you might want to see frame_number needs to be
(frame_number +/- 1) and if it has to be Boid<=Boid_Amount
instead of just <.
Tim Nikias v2.0
> >could help.
row
the
Clock
name
> possibly?)
> oli
Date: 29 Mar 2003 20:10:03
Message: <web.3e864229eb11af8459ddf11d0@news.povray.org>
>something like:
>#end
>#end
>#fclose _D
And that will do the job nicely !
Thanks for getting me started - I should have been more organised, but the
deadline is running up close - will posta finished animation as soon as i
have one.
Thanks once again,
oli
Date: 30 Mar 2003 05:24:34
Message: <3e86c5e2@news.povray.org>
I'll wait and see what the animation looks like. You
might want to consider releasing the code to the
POV-public? :-)
Tim Nikias v2.0
> >something like:
> >#end
> >#end
> >#fclose _D
> have one.
> Thanks once again,
> oli
Date: 31 Mar 2003 04:03:33
Message: <3E87F996.8060002@informatik.uni-freiburg.de>
Then output a .pov or .inc file.
merge{#local i=-11;#while(i<11)#local
i=i+.1;sphere{<i*(i*i*(.05-i*i*(4e-7*i*i+3e-4))-3)10*sin(i)30>.5}#end
pigment{rgbt 1}interior{media{emission x}}hollow}//  Mark Weyer
