POV-Ray : Newsgroups : povray.general : parametric: error: float factor expected but function found instead. Server Time
31 Dec 2025 08:48:07 EST (-0500)
  parametric: error: float factor expected but function found instead. (Message 1 to 5 of 5)
Subject: parametric: error: float factor expected but function found instead.
Date: 26 Jan 2003 18:50:03
Message: <web.3e3472c9207607823b54632b0@news.povray.org>
Whenever I try to use a parametric object I get an error message
"float factor expected but function found instead."
For instance, if I use the example from the manual (sec 6.5.5) to
draw a sphere,
  parametric {
    function { sin(u)*cos(v) }
    function { sin(u)*sin(v) }
    function { cos(u) }
    <0,0>, <2*pi,pi>
    contained_by { sphere{0, 1.1} }
    max_gradient ??
    accuracy 0.0001
    precompute 10 x,y,z
    pigment {rgb 1}
Parsing...  parametric {
    function  <----ERROR
parametric-sphere.pov:3: error: float factor expected but function found
instead.
I'm not really clear on the syntax, so I've tried variations, but I always
get this message.  I've tried a couple examples posted in the povray
newsgroups, and they also gave me this message.  I am using povray
3.0.20-10 in Debian Woody (i386).  Any clues?  Can someone post a complete
(reasonably short) working file with a parametric object usage?
Thanks for any help.
Liam
Subject: Re: parametric: error: float factor expected but function found instead.
Date: 26 Jan 2003 18:53:03
Message: <3e3474df$1@news.povray.org>
Try putting commas after the first two functions:
     function { sin(u)*cos(v) },
     function { sin(u)*sin(v) },
     function { cos(u) }
I took that straight out of section 6.5.5 of the documentation (searched the
index for "parametric.")
 - Slime
[ http://www.slimeland.com/ ]
Date: 26 Jan 2003 19:57:38
Message: <3e348402@news.povray.org>
In article <web.3e3472c9207607823b54632b0@news.povray.org> , "Liam"
The version of POV-Ray included in Debian is completely outdated (by about
half a decade).  Even worse, it isn't even an official version but some kind
of patched version.
To run any current POV-Ray scene you will need either POV-Ray 3.1 or POV-Ray
3.5 which are available from www.povray.org .
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 31 Jan 2003 22:10:05
Message: <web.3e3b3a20ae37ab543b54632b0@news.povray.org>
>     function { cos(u) }
> - Slime
This doesn't help at all.  Believe me, I tried all combinations of commas,
lack thereof, etc.  This solution is in the next message.
Date: 31 Jan 2003 22:15:04
Message: <web.3e3b3b3c273004143b54632b0@news.povray.org>
Thorsten Froehlich wrote:
>In article <web.3e3472c9207607823b54632b0[at]news.povray.org> , "Liam"
>of patched version.
.... and even worse, it's apparently broken.
and this is the solution, v 3.5 from the povray site works fine.  I finally
hit upon trying this version shortly after posting my original query.
What's really interesting to me is this question has never come up before
(google and google groups draw a blank).  That tells me nobody uses the
Debian version, at least for parametric objects.
>    Thorsten
Thanks Thorsten.
