POV-Ray : Newsgroups : povray.general : Help with thin object Server Time
30 Dec 2025 07:15:45 EST (-0500)
  Help with thin object (Message 1 to 10 of 12)
Subject: Help with thin object
Date: 14 Aug 2003 10:30:30
Message: <slrnbjn768.msb.povfan@corky.voltar-confed.org>
I'm making yet another go board.  Wonderful game.
I'm having some trouble rendering thin rectangles.  I can
completely see why povray fails to render some of the lines in
the from-the-side views.
But in this case, I'd like it to really really draw the lines no
matter what.  I experimented with making the ink artificially
tall, but it looked obviously wrong in the close-ups.
Jitter didn't really work how I'd hoped and no amount of
anti-aliasing recursion seemed to help.
I've posted the images here:
    http://voltar-confed.org/tmp/goban2.snaps
Here's how I'm drawing the ink:
#declare inkclr = texture {
    finish { phong 0 crand 0 specular 0 reflection 0 ambient 1 }
    pigment { color rgb <0, 0, 0.005> }
#declare inkshp = object {
    union {
        #declare counter=0;
        #while (counter < hatches)
            #declare a=(9.7-hatchwt)-(widthofhatch*counter);
            #declare b=9.7-(widthofhatch*counter);
            box { <a, inklow, 9.7>, <b, inktop, 0.3> }
            box { <9.7, inklow, a>, <0.3, inktop, b> }
            #declare counter=counter+1;
        cylinder { posc( 4,  4, inklow) posc( 4,  4, inktop), hatchwt*2.2 }
        cylinder { posc(16, 16, inklow) posc(16, 16, inktop), hatchwt*2.2 }
        cylinder { posc( 4, 16, inklow) posc( 4, 16, inktop), hatchwt*2.2 }
        cylinder { posc(16,  4, inklow) posc(16,  4, inktop), hatchwt*2.2 }
        cylinder { posc(10, 10, inklow) posc(10, 10, inktop), hatchwt*2.2 }
If riding in an airplane is flying, then riding in a boat is swimming.
39 jumps, 8.0 minutes of freefall, 14.5 ff vertical miles.
Subject: Re: Help with thin object
Date: 14 Aug 2003 10:56:40
Message: <3F3BA327.6050800@loria.fr>
I've made some gobans with povray and what I did for the grid was to
used cylinder for lines and differenced them with the board (since grid
for a real goban is made using a japanese sword, there exist some
depression between plain board and grid).
I can post the picture if you want.
Nicolas
>     union {
>         #declare counter=0;
>         #end
Date: 14 Aug 2003 11:06:14
Message: <3f3ba566@news.povray.org>
You need to tell POV-Ray to antialias every pixel if you want all the
thin lines to be visible. It's slow, but at least it should work.
  A good way to achieve this is to use "+a0.0 +am2" settings for extra-good
quality.
  By the way, there are some errors which you might want to fix if you
want a perfect go board.
  Firstly, the squares are not square. The distance from the middle of
a line to the middle of the next line is exactly 22 mm widthwise and
23.7 mm lenghtwise. The thickness of the lines should be approximately 1 mm.
  The total width of the goban should be 424.4 mm and the total length
should be 454.5 mm.
  (Unlike chess, the dimensions of a go board are well-defined and
standardized. This is because go stones come with a standard size.)
  The diameter of the stones should be approximately 22.5 mm. This is 0.5 mm
more than the line spacing widthwise and it's intentional.
  For rendering purposes this can be a bit cumbersome, so I suppose it's
not such a big deal if your stones are 22 mm.
  Secondly, your board lacks four hoshi-markers.
Date: 14 Aug 2003 12:12:48
Message: <slrnbjnd62.ntm.povfan@corky.voltar-confed.org>
Actually the images I posted in my temp dir are +a0.1 +am2 ... Do
you think the 0.0 will make a big enough difference?  (trying it
now).
OMG, that was it.  I had previously determined that anything
lower than 0.1 was just too darn low.
> standardized. This is because go stones ...
Yes... I didn't get that far cuz I was discouraged by the problem
above. :)  I will most definitely adjust for this later.  I'm
trying to get this thing as realistic as possible.  I'm an 17kyu
now.
But for my first goban, I was a 38kyu and it shows:
http://www.voltar.org/povray/
But I've learned a LOT since then -- about gobans and about the
game.
No, the stars are there... Tengen too, or am I crazy?
Anyway, thanks so much for your help.  That AA thing has been
bugging me for days!
Date: 14 Aug 2003 12:38:15
Message: <3f3bbaf7@news.povray.org>
  There are 9 hoshi markers in a 19x19 board. You only have 5.
Date: 14 Aug 2003 12:56:07
Message: <slrnbjnfn9.idt.povfan@corky.voltar-confed.org>
Oops, you are correct sir.  There should be 9... my bad.
Interesting, until you called the stars: hoshi, I thought hoshi
meant 4-4.
4-4 - hoshi
3-4 - komoku
4-5 - takemoku
5-3 - mokuhazushi
Which is true as it pertains to shimari/fuseki.  But on further
reading I discovered that all the star points are called hoshi.
Fascinating.  You learn a little go every day -- if you're so
inclined. :)
Cut kiema at the waist,
Jet
Date: 14 Aug 2003 17:33:09
Message: <3f3c0015@news.povray.org>
> But on further
  For more info (in fact, about everything related to go), see
http://senseis.xmp.net/?Hoshi
Date: 15 Aug 2003 09:21:24
Message: <slrnbjpngk.b7h.povfan@corky.voltar-confed.org>
Yes, I love that site.
http://senseis.xmp.net/?jettero
http://senseis.xmp.net/?k5gs
Actually, I tried to post more info about the cool goban on
the front page, but it was removed by other site editors.
I'm under the impression that you made that goban.  Is that actually correct?
>> But on further
Date: 15 Aug 2003 09:43:59
Message: <3f3ce39f@news.povray.org>
  Yes. The original is here:
http://iki.fi/warp/pics/goban.jpg
  I was quite surprised when the admin of the site asked me if he could
use that picture in question in the front page.
  (By the way, if you are wondering, the picture is the final position
of one of my own kgs games. A famous pro game could perhaps have been
better for sensei's front page, but I didn't know that it would be used
for that purpose when I made the image... :) )
Date: 15 Aug 2003 10:14:49
Message: <slrnbjpqkq.qt1.povfan@corky.voltar-confed.org>
OK, as long as it's on topic sorta.  I noticed that you positioned
the stones in the lids by hand.  Do you know of a way to position
objects automatically... Um ... as if they had fallen there?
I've been trying to reason out a way to do that, but I think it's
impossible.  I doubt I could calculate the edge of one of my
stones... oddly shaped as they are.
Does povray or it's plugins have a way of doing anything like
gravity and/or edge detection?
