POV-Ray : Newsgroups : povray.general : Some help with Media please. Server Time
2 Mar 2026 15:48:43 EST (-0500)
  Some help with Media please. (Message 1 to 7 of 7)
Subject: Some help with Media please.
Date: 30 Dec 2003 10:21:47
Message: <qu53vvosn5it1kkor4vts10ajlpu6agfod@4ax.com>
I am trying to create a scene that has a visible spotlight. I've got the
spotlight showing OK but the rest of the scene is under illuminated. The spot
and the target are in a Media Container. I have added two omni lights that don't
react with Media but they don't do a lot. If I make the omni lights react with
Media I get a whiteout. I'm doing this in Moray so a scene would have a lot of
junk in it.
The Media settings are:
      texture
         pigment
            color rgbf <1.0, 1.0, 1.0, 1.0>
      interior
         media  // MyAtmosphere_1_1
            variance 1.0/128.205128
            scattering
               1 ,  rgb <1.0, 1.0, 1.0> // isotropic scattering
               extinction 0.15
Regards
Subject: Re: Some help with Media please.
Date: 30 Dec 2003 12:16:23
Message: <3ff1b2e7$1@news.povray.org>
"Stephen McAvoy" <mcavoys(at)AOLdotCOM> wrote in message
news:qu53vvosn5it1kkor4vts10ajlpu6agfod@4ax.com...
spot
don't
with
lot of
> junk in it.
Common occurance when dealing with scattering media, it obscures things like
smokey air. You have the color value at rgb 1.0 (scattering amount) which is
typically too high to see through. While that can make a light source
brighter in its vicinity it doesn't work well at a distance, nor for objects
more distant from the camera. Also, even if you lower extinction to zero it
remains as opaque as before and doesn't help with transparency. So, you'll
need to lower the scattering color values instead. Can also use a density
statement with smaller value than the default of rgb 1. Basically, you'll be
adjusting all those values until you get what looks appropriate.
As to the additional lights you added to help illuminate the scene... I
would say you would cause unwanted affects (hilights, diffuse surfaces,
oversaturation) by brightening the scene using those (with large light
source color values), so probably not a good idea to do that.
Bob H.
http://www.3digitaleyes.com
Date: 30 Dec 2003 14:26:36
Message: <dak3vv4rbenfosgdr5ju5arqpobt9lfv93@4ax.com>
On Tue, 30 Dec 2003 11:16:21 -0600, "Hughes, B." <omn### [at] charternet> wrote:
That did it. Density with a gradient in the up direction works.
Is that a lucky guess? :-}
I'll have to work on this. One thing I found is that the spotlight does not give
the characteristic illuminated ellipse on the floor so I needed a second one
that does not react with media.
Thanks Bob.
Regards
Date: 30 Dec 2003 17:00:41
Message: <3ff1f589$1@news.povray.org>
news:dak3vv4rbenfosgdr5ju5arqpobt9lfv93@4ax.com...
be
Even better, good to know you worked something out like that for it. Just
remember that light scattering in the air might be from particles floating
at the ceiling, or descended to the floor, at some intermediate level, or
turbulated around too. :-)
Educated guesses, usually.
not give
one
Not sure why you aren't seeing one, except maybe from light fading or media
attenuation causing dimming too much before reaching the floor. Or if the
floor finish has a low diffuse value too.
I'll post an example image at p.b.i. showing isotropic scattering media
having a few different values. It never is easy to fine-tune media together
with the lights, backgrounds, and objects. Probably because there can be
more to the visual perception than a texture alone has, at the risk of being
somewhat philosophical about it. ;-)
Bob H.
Date: 30 Dec 2003 17:30:08
Message: <3ff1fc70$1@news.povray.org>
Try negative absorbtion.  (check out my 'haze' texture that's with
the user-submitted library in M 3.5 for reference)
Tim Cook
Version: 3.12
Date: 30 Dec 2003 18:22:55
Message: <n524vvgaammsk4dkp5e53n7c4istmtd6hd@4ax.com>
On Tue, 30 Dec 2003 17:32:59 -0500, Tim Cook <z99### [at] bellsouthnet> wrote:
Oh I thought that I had used your haze as a starting point but since it is
direct code I can't have. It must have been one posted in moray.binaries by Arne
Kleinophorst. I'll try that tomorrow as I'm in the middle of a longish render
just now. In fact I might post it in pov.b.images so someone can tell me what
the deliberate mistake is. BTW I really liked your post with the Poser 5 model
especially the clothes and hair.
Regards
Date: 30 Dec 2003 18:41:49
Message: <r634vv0g9tpq8ucu1b061n432e23b3bo17@4ax.com>
On Tue, 30 Dec 2003 16:00:40 -0600, "Hughes, B." <omn### [at] charternet> wrote:
> Just
Arrg! Every time I sit in the theatre I want to do the smoke/dry ice effect.
The floor finish is the BoisJaune wood texture in a brick pattern and I'm not
using attenuated by media. I'll post a render I'm doing just now, later.
Thanks for the post, again, I'll experiment tomorrow. As for visual perception
it is funny what you think you see. I am sure that when the eye sees an object
the brain remembers it and when it looks at another object, in RL the brain puts
together a composite picture. Like rendering different parts of the view with
their own optimum settings
Regards
