POV-Ray : Newsgroups : povray.general : Can't work out the right scale/translate Server Time
2 Mar 2026 00:13:32 EST (-0500)
  Can't work out the right scale/translate (Message 1 to 10 of 13)
Subject: Can't work out the right scale/translate
Date: 30 Jun 2004 09:54:00
Message: <opsaet6upaefp2ch@news.povray.org>
I've been staring at this on and off for weeks and just can't figure out
how to get the vertical scale/translate right:
Three files:
//Magic Gate1.inc
#declare CameraLocation=<0,1,-10>;
#declare CameraLookat=<0,1,0>;
#declare CameraRotate=10;
// end Magic Gate.inc
//Magic Gate2.pov run first with +fn
#include "Magic Gate1.inc"
camera{
location CameraLocation
look_at CameraLookat
rotate y*CameraRotate}
light_source{<0,18,0> rgb 1}
plane{y,0 pigment{red 1}}
plane{-y,-20 pigment{blue 0.5} finish{ambient 1}}
box{0,6 pigment{green 1} rotate y*-30 translate z*10 finish{ambient 0.5}}
sphere{0,1 pigment{red 1} finish{ambient 0.5} translate <0,15,30> rotate
y*10}
//end Magic Gate2.pov
//Magic Gate1.pov
camera{
plane{y,0 pigment{rgb 1}}
plane{-y,-20 pigment{blue 1} finish{ambient 1}}
box{0,6 pigment{red 1} rotate y*-30 translate z*10}
#declare Distance = CameraLookat.z;
#declare
Length=vlength(<0,0,Distance>-<CameraLocation.x,0,CameraLocation.z>);
difference{
box{z*5,<Length*(2/3)*2,(Length*(2/3)*2)/1.33,0>
pigment{image_map{png "Magic Gate2.png"}
scale<Length*(2/3)*2,(Length*(2/3)*2)/1.33,1>
//why -4?
translate y*-4
finish {ambient 1}
translate -x*(Length*(2/3))
plane{z, 0}
plane{-z, -0.001}
plane{-x, -1}
plane{x, -1}
plane{y, 0}
plane{-y, -5}
cutaway_textures
no_shadow
sphere{0,1 pigment{green 1} finish{ambient 0.5} translate <0,15,30> rotate
y*10}
//end Magic Gate1.pov
Hopefully it should be obvious from the images and the titles what I'm
trying to do, but the images don't quite line up as I would expect.
Horizontally not bad; vertically enough of a discrepency to bug me.
Knowing me probably something simple, but I just can't see it.
TIA
Phil Cook
All thoughts and comments are my own unless otherwise stated and I am
happy to be proven wrong.
Subject: Re: Can't work out the right scale/translate
Date: 30 Jun 2004 12:36:52
Message: <40e2ec24$1@news.povray.org>
Well, fairly simple, at least. I can't tell exactly what you were trying
to do with the texture scaling, but this is how it could be done.
The pigment is mapped from <0,0> to <1,1>, so the first thing to do is
canter the pigment at the origin:
translate -.5
Then the pigment should be scaled to fit perfectly in the viewing
window. I'm making these terms up, but by "viewing window" I mean the
visible portion of a plane located at CameraLookat with a normal of
CameraLocation - CameraLookat. The default camera angle is (from the
docs) ~67.380. [[[I've tried this sentence a half-dozen times, but don't
have the vocabulary to say what I need to say. Hopefully the code (or
some generous math person) will make it clear]]].
You will need to use radians, because the sin and cos functions
understand radians.
#local Length = vlength(CameraLocation-CameraLookat);
#local HalfAngle = radians(67.380)/2;
Half the angle is used because twice the height of half the angle is
equal to the distance between the two ends. <phew> I *hope* that made at
least some sense. Now get the radius of an imaginary circle centered at
the CameraLocation which just touches the edges of the viewing window.
#local Radius = Length / cos(HalfAngle);
Now that the radius is known, sin of half the angle times the radius
time two will give us the width of the viewing window.
#local Width = sin(HalfAngle) * Radius * 2;
Of course, adjust to the standard aspect ratio
#local Scale = Width * <1,3/4,1>;
After scaling, translate the texture up to your CameraLookat point of
<0,1,0>
translate <0,1,0>
Don't put the texture on a box and then cut at that box with planes.
Construct the difference first. Also, instead of rotating the texture
onto a crooked box, rotate the magic box to face the camera.
Well, this post is a f- mess. I did my best, dude. This is why I don't
mess with many math related posts. Anyway, the whole thing will look
like this:
difference{
	box{
     plane{z, -0}
	plane{-z, -.001}
	plane{-x, -1}
	plane{x, -1}
	plane{y, 0}
	plane{-y, -5}
	pigment{
		image_map{
		translate -.5
		// already have length defined earlier in your code
		scale Scale
		translate <0,1,0>
	finish {
		ambient 1
	no_shadow
  -Shay
Date: 1 Jul 2004 09:52:19
Message: <opsagoqsxcefp2ch@news.povray.org>
And lo on Wed, 30 Jun 2004 11:36:51 -0500, Shay <sah### [at] simcopartscom> did
spake, saying:
> translate -.5
Understand completely, that's what I was trying to do.
> understand radians.
Ah, as it said ~67.38 I tried to use tan/atan which cancelled out in the
Length no doubt that helped screw it up.
Yep makes complete sense
> <0,1,0>
> translate <0,1,0>
Thinks... hmm yes missed that.
What I was trying to do was calculate a box that at a distance would fill
the viewing field, slap the texture on and cut it to fit, amusing I tried
a varient of your method first and couldn't get it to gel, probably due to
some dodgy math.
Ah now the catch, the Magic Gate is fixed and is always perpendicular to
the origin I'll explain why at the end.
Hey you understood what I was sort-of doing (which takes some doing) and
produced code that works and an explanation I can follow. I can't see how
you could do more. I extend a grateful thank-you.
> Anyway, the whole thing will look like this:
> difference{
> 	box{
>      plane{z, -0}
> 	plane{-z, -.001}
> 	plane{-x, -1}
> 	plane{x, -1}
> 	plane{y, 0}
> 	plane{-y, -5}
> 	pigment{
> 		image_map{
> 		translate -.5
> 		scale Scale
> 		translate <0,1,0>
> 	finish {
> 		ambient 1
> 	no_shadow
It works and matches fine I just need to tweak for my bizzaro needs.
Grr I hate talking about WIP but:
Essentially this is a test image (of course) what I'm going to do
(eventually) is have Magic Gate1 as a desert landscape and Magic Gate2 as
the *same* landscape but lush and green then animate the desert to show
the camera approaching and moving around the 'gate' with the 'gate'
display always showing the equivalent scene as you would see it if the
'gate' wasn't there rather than as a flat painted-on image, which is why
it can't rotate with the camera and why I was carving it out, I hope that
makes some sense :)
Phil Cook
Date: 1 Jul 2004 10:04:42
Message: <opsagpbfwsefp2ch@news.povray.org>
And lo on Thu, 01 Jul 2004 14:50:42 +0100, Phil Cook
<phi### [at] nospamdeckingdealscouk> did spake, saying:
Yes! Applying the image_map then carving it out with the planes seems to
keep everything matched up even when changing distances or angles. Great
now all I've got to do is create two matching landscapes and render all
the images twice :P
OOC O wise Shay do you happen to know how to get the image_map image to
the brightness of the original image even {ambient 1} seems to add a grey
cast, not really a problem adds to the 'magic'.
Phil Cook
Date: 1 Jul 2004 10:27:56
Message: <40e41f6c$1@news.povray.org>
> grey  cast, not really a problem adds to the 'magic'.
  -Shay
Date: 1 Jul 2004 10:45:41
Message: <opsagq7o0oefp2ch@news.povray.org>
And lo on Thu, 01 Jul 2004 09:27:56 -0500, Shay <sah### [at] simcopartscom> did
spake, saying:
>> to  the brightness of the original image even {ambient 1} seems to add
>> a grey  cast, not really a problem adds to the 'magic'.
I bow before your wisdom :)
Phil Cook
Date: 1 Jul 2004 10:57:33
Message: <40e4265d$1@news.povray.org>
LOL. Glad I could help.
  -Shay
Date: 6 Jul 2004 17:35:41
Message: <cjameshuff-6D6847.16355706072004@news.povray.org>
In article <40e41f6c$1@news.povray.org>, Shay <sah### [at] simcopartscom>
Won't that only work if Display_Gamma is 1? You want to turn gamma
correction off. Just not specifying assumed_gamma should work.
Anyway, in addition to setting ambient to 1, you should set diffuse to
0, so light from scene illumination won't wash out the image.
http://tag.povray.org/
Date: 7 Jul 2004 04:50:25
Message: <opsaret2miefp2ch@news.povray.org>
And lo on Tue, 06 Jul 2004 16:35:57 -0500, Christopher James Huff
<cja### [at] earthlinknet> did spake, saying:
>> to
Well commenting out assumed_gamma produces a darker image on the 'gate'
with no Display_Gamma set, so default gamma correction of 2.2 is in use.
Just to check this I changed the two planes in "Magic Gate2.pov" to the
same colour as that in "Magic Gate1.pov" and ran it both ways, without
assumed_gamma produces a noticeable difference.
I've posted a tiny file in p.b.images to show the differences.
diffuse 0 doesn't seem to make a difference but of course might once I
start changing the landscape.
The only thing I did notice was dark dots appearing on the gate then I
realised I was missing a cutaway_textures, adding it removes them as you
might expect.
Phil Cook
Date: 7 Jul 2004 17:14:54
Message: <cjameshuff-81E91B.16145307072004@news.povray.org>
In article <opsaret2miefp2ch@news.povray.org>,
No, gamma correction is off by default. (At least, it's supposed to be.)
It gets turned on when you include assumed_gamma in the global settings.
Weird. If you want the rendered image to appear the same as the original
map, you obviously don't want any gamma correction to be done...the
corrected version won't be the same. Your image doesn't show the
original map, so I can't compare...but the fact that it shows up
differently from the surrounding scene, which should be the same color
pre-correction, is very odd.
What formats are you using? It may be an artifact of however POV and
your other image software handles gamma values in PNG images. You should
get the effect you want if you render the map without an assumed_gamma
value, and the final image with assumed_gamma 1.
Try shining a bright light on the gate.
