POV-Ray : Newsgroups : povray.general : the trace function and toroidal objects Server Time
20 Apr 2026 09:15:16 EDT (-0400)
  the trace function and toroidal objects (Message 1 to 7 of 7)
Subject: the trace function and toroidal objects
Date: 30 Sep 2003 13:33:02
Message: <oprwbppd0lmulnlm@localhost>
I'm trying to slap randomly distributed objects onto an isosurface in the
shape of a lumpy torus.  The only tool that I've found to help is the
trace(OBJECT_IDENTIFIER, A, B, [VECTOR_IDENTIFIER]) function.
Unfortunately, it only returns points on the "outside" part of the torus
(ie. not inside the donut hole).  Is there any way I can make it trace to
the entire torus?  Is there another function or macro that will do the
job?
I can put the objects in a regular torus through some inventive vector
math, but conquering the lumpiness is beyond my abilities, it seems.
Subject: Re: the trace function and toroidal objects
Date: 30 Sep 2003 16:47:07
Message: <cjameshuff-670827.16463330092003@netplex.aussie.org>
> job?
All you have to do is point it at part of the surface inside the hole.
The trace() function will return the first intersection with the
specified ray, no matter where on the surface it is. Given your
description, I'm guessing you are shooting at the center of the torus
from random positions outside of it...this obviously won't hit anything
inside the torus.
Not sure what lumpiness you mean. The distribution will not be even, but
that's nothing I'd describe as lumpy.
http://tag.povray.org/
Date: 1 Oct 2003 00:40:19
Message: <oprwckljrimulnlm@localhost>
I did some experiments and have reached the unambiguous conclusion that
the trace function will not hit the inside of the torus.  If anyone can
claim they're sure it works for them, I don't know what to say.  I'm using
MegaPOV 1.0, by the way.
Date: 1 Oct 2003 01:32:36
Message: <mwgFSCAFame$EwSJ@econym.demon.co.uk>
I came very close to agreeing with you (except that I was using POV 3.5)
My mistake was using  "trace(Shape,Q,P)" in the following code instead
of "trace(Shape,Q,P-Q)". Perhaps you're doing something simlar.
#include "functions.inc"
global_settings {assumed_gamma 1.0}
camera { location  <-1, 3, -4> look_at <0, 0, 0> angle 27}
background {rgb <0.5,0.6,0.7>}
light_source {<-100,200,-100> colour rgb 1}
#declare F_bozo=function{
  pigment{bozo
     colour_map {[0 rgb 0][1 rgb 1]}
     scale 0.2
#declare Shape=
isosurface {
  function { f_torus(x,y,z,0.7,0.5) + F_bozo(x,y,z).grey*0.3}
        max_gradient 2
        contained_by{sphere {0,1.3}}
        pigment {rgb 0.1}
        finish {phong 0.5 phong_size 10}
object {Shape}
#declare A=0;
#while (A<360)
  #declare B=0;
  #while (B<360)
    #declare P = vrotate(vrotate(<0,0.5,0>,A*z) + x*0.7, B*y);
    #declare Q = vrotate(x*0.7, B*y);
    #declare T = trace(Shape,Q,P-Q);
    sphere {T,0.03 pigment {rgb 1}}
    #declare B=B+8;
  #declare A=A+15;
Date: 1 Oct 2003 08:59:50
Message: <cjameshuff-43D5C7.08583901102003@netplex.aussie.org>
In article <oprwckljrimulnlm@localhost>, melundbe@mtu.edu wrote:
> NOpe, I have objects both inside and outside the toroid, and the trace
> simply ignores the intersections with the inside.  At least I'm pretty
> confident that it is.  I'll check again.
Now I have no idea what you're describing. The trace() function has
nothing to do with object-object intersections, and any objects not
passed to trace() simply do not exist, as far as it is concerned.
> The lumpiness is a function that combines a bozo colormap and some others
> with the f_torus, giving the torus a hilly landscape, or lumps.  This is
> the reason I'm not simply constructing a torus through other means.
So you are tracing against an isosurface...should have paid more
attention. Could be problems with max_gradient, or something with the
locations you're tracing from confusing the isosurface solver.
As for vector math, you could pretty easily build it out of a mesh, like
the height field macros in shapes.inc, and do something similar to
project points onto its surface. The trace() function would still be the
simplest way to find a point on the surface, though.
Your conclusion is simply wrong. The trace() function, when used
properly, will hit any part of the surface of an object. There is
nothing special about these surfaces, except for the fact that the
object is relatively inaccurate.
Date: 1 Oct 2003 09:39:47
Message: <oprwc9kks7mulnlm@localhost>
Funky! It worked!  Thank you Mike!
*reads documentation on trace() one more time*
Oh, so that's what it said.
>   pigment{bozo
>      scale 0.2
> #declare Shape=
> isosurface {
>         max_gradient 2
>         pigment {rgb 0.1}
> object {Shape}
> #declare A=0;
> #while (A<360)
>   #declare B=0;
>   #while (B<360)
>     #declare B=B+8;
>   #end
>   #declare A=A+15;
> #end
Date: 1 Oct 2003 12:25:00
Message: <web.3f7aff2c137049fc10dd5cfd0@news.povray.org>
Actually, I think, if you replace:
with:
#declare P = vrotate(vrotate(<0,0.5,0>,A*z), B*y);
and then replace:
with:
#declare T = trace(Shape,Q,P);
you don't need to subtract vectors. . . . (I think. . . .)
(By the way, thanks for this example.  Thanks to it, I believe that I
finally figured out how "trace" works.  It's funny how with certain
examples a light bulb goes on, and with others, well, I just sit in the
dark and stare at the code -- kind of hard to read that way. )
Dave Matthews
