POV-Ray : Newsgroups : povray.general : Star Filled Sky Server Time
25 Nov 2025 04:53:22 EST (-0500)
  Star Filled Sky (Message 1 to 9 of 9)
Subject: Star Filled Sky
Date: 15 Nov 2002 15:50:52
Message: <junk-1511021450530001@ip68-97-75-252.ok.ok.cox.net>
Okay, I'm trying to add a night sky to my scene and I'm running into two
problems.  First, here's what I have:
sky_sphere {
      granite
      color_map {
         [0    color Black]
         [.08  color Black]
         [.1 color White]
         [.1 color Black]
      warp { turbulence 1 }
      scale .1
      frequency 2
Problem number one.  I really like the look of this, but I really want
about 1/10th of the stars that are in here.  I've tried messing with scale
and frequency, but I just haven't found the right way to make the stars
appear less frequently in the pattern.
Prolem number two.  My scene has plenty of ugly jaggies and thus really
needs anti-aliasing.  Unfortunately, when I trace with that, at any of the
different settings I've tried, I turn the above starfield into a solid
black sky.  Is there no way to have both?
Thanks in advance for any and all help.  I've still got buckets to learn
about tracing.
James
Subject: Re: Star Filled Sky
Date: 15 Nov 2002 16:24:37
Message: <3dd56615@news.povray.org>
James Gray wrote:
<snip>
Try this out:
#declare D = .5;
sky_sphere {
                crackle
                color_map {
                        [pow(0.5, D) color Black]
                        [pow(0.6, D) color White*10]
                scale .005/D
It should render fine with aa. You can also adjust the star density with
the 'D' variable.
Date: 15 Nov 2002 16:48:11
Message: <chrishuff-F01A24.16472715112002@netplex.aussie.org>
In article <jun### [at] ip68-97-75-252okokcoxnet>,
Try reducing the amount of color map that is non-black. Move the
0.08-0.1 boundary further towards 1 in your map.
There really isn't a good way around this. The texture technique takes
advantage of pixels being point samples, antialiasing samples an area,
and the bright areas get drowned out by the larger dark areas.
The antialiasing code also clips colors to the [0, 1] range before
averaging the colors for the final pixel color, so you can't just make
individual extremely bright stars. (it does this to avoid jagged edges
on extremely bright objects, in my opinion the fix is worse than the
problem)
The most reliable technique seems to be to use spheres randomly
positioned in a half-sphere around the scene, sized just big enough to
always cover a pixel. This usually looks really ugly in my opinion, and
is sensitive to the image size (though you could automatically
compensate for that) but is resistant to antialiasing.
http://tag.povray.org/
Date: 15 Nov 2002 18:21:01
Message: <3dd5815d$1@news.povray.org>
"James Gray" <jun### [at] grayproductionsnet> wrote in message
news:jun### [at] ip68-97-75-252okokcoxnet...
[deletions]
: Prolem number two.  My scene has plenty of ugly jaggies and thus really
: needs anti-aliasing.  Unfortunately, when I trace with that, at any of the
: different settings I've tried, I turn the above starfield into a solid
: black sky.  Is there no way to have both? -- James
I've encountered the same problems. I solved it in a two
step process. First I rendered the star field on a black
background. Then I rendered my foreground without the star
field on a black background, then OR the foreground onto
the background. I did this in a small animation once and it
looked very nice.
=Bob=
Date: 15 Nov 2002 18:46:29
Message: <3DD58953.F79C91D8@comcast.net>
I made a starfield graphic using FractInt.  Then image_map'd
it onto a large sphere( radius 1e6 ).  My graphic is 2048x2048.
It stands up well to AA, and animates correctly.
In FractInt, I used a plasma image, then rendered a starfield
from it.
Emory
> sky_sphere {
>    pigment {
>       granite
>       color_map {
>          [0    color Black]
>          [.08  color Black]
>          [.1 color White]
>          [.1 color Black]
>       scale .1
>       frequency 2
> about tracing.
> James
Date: 16 Nov 2002 03:49:08
Message: <3dd60683@news.povray.org>
One solution (eg. used by Colefax's galaxy include) is to put real objects
(eg. spheres) as stars. You'll need to create some thousands of them, but
that shouldn't be a problem.
Date: 19 Nov 2002 11:18:42
Message: <3dda6462$1@news.povray.org>
Warp <war### [at] tagpovrayorg> wrote in message news:3dd60683@news.povray.org...
objects
Or to save memory, perhaps copies of a mesh pentagon oriented to face the
camera.
 -Shay
Date: 19 Nov 2002 11:43:44
Message: <chrishuff-9963B8.11422319112002@netplex.aussie.org>
In article <3dda6462$1@news.povray.org>, "Shay" <sah### [at] simcopartscom>
> camera.
This won't save much memory, in fact it could consume more. A sphere is
almost as close to the smallest possible object as you can get. Aside
from the stuff common to every object, a sphere has to keep a center
vector and a radius, 4 double values total. A mesh has a pointer to mesh
data, a long integer of the number of textures, a pointer to an array of
texture pointers, and a short integer used by the inside_vector code.
Now, if you made several different meshes, each with multiple stars, and
used randomly rotated and positioned copies of these, you would save
more memory. There would be a few patterns of stars repeated over the
sky, but it shouldn't be noticeable if they are randomly oriented and if
there are enough different patterns.
Date: 19 Nov 2002 15:01:02
Message: <Xns92CB98B9ABFDBtomatimporg@204.213.191.226>
jun### [at] grayproductionsnet (James Gray) wrote in
news:jun### [at] ip68-97-75-252okokcoxnet:
> two problems.  First, here's what I have:
<snip>
> James
If you would like the actual constellations then check out this page:
http://www.geocities.com/CapeCanaveral/Galaxy/8018/
Tom
