This is driving me crazy. I have a shape that's basically a circular
collection of clipped torii and cylinders but as a union I can
represent as a short cylinder with axis along the z-axis. I want to
take a 30 degree wedge out of the bottom of it.
I've defined the wedge as
#declare Wedge = cylinder {
<0, 0, -5>, <0, 0, 5> OuterDia + MinorDia * 2
clipped_by {plane {x * 1, 0 rotate z*15}}
clipped_by {plane {x * -1, 0 rotate z*-15}}
It really doesn't need to be that thick but it's okay for my purposes
right now.
I then do
#declare EmblemTest = difference {
cylinder {<0, 0,.01>,<0, 0, -.01> 15}
object {Wedge }
object {EmblemTest}
I get nothing. I've tested using intersection and and see the wedge
shape. I've tried setting the wedge to inverse in the difference and
the intersection declarations and I still can't get a disc with a
wedge removed. I've tried a few other combinations that don't come to
mind at the moment but still nothing.
Suggestions?
Thanks,
Lilith
I'm not sure clipped objects work in CSG as you expect. Have you tried
with intersection rather than clipped_by, to see if it works ok like that?
That could be it. I'll probably need to redefine the wedge along the
means you've suggested.
Thanks,
Lilith
>Thanks,
>Lilith
Very kewlsome. That worked.
Thanks again,
Lilith
