POV-Ray : Newsgroups : povray.general : Infinite Objects Server Time
12 Apr 2026 03:39:10 EDT (-0400)
  Infinite Objects (Message 1 to 10 of 15)
Subject: Infinite Objects
Date: 21 May 2008 12:24:16
Message: <f4j834991908jrf4arraldfilngp0ro8tc@4ax.com>
I've just noticed that if I scale a sphere by 10000 it becomes an
infinite object. Are there any implications to this?
Regards
Subject: Re: Infinite Objects
Date: 22 May 2008 02:28:58
Message: <483512aa@news.povray.org>
Stephen napsal(a):
-since double precision is only 16 digits you cannot have objects with
scales differing by more than 8 digits.
-if the camera is inside the sphere you must make it hollow or inverse.
-such object will probably be traced by every ray. This has performance
implications of using complicated objects (an unlikely need)
this method is often used to create a background because a sky_sphere
doesn't cooperate with radiosity very well.
the ultimate time-killer:
+a0.0 +am2 +r9
Johnny D
Date: 22 May 2008 03:21:51
Message: <48351f0f@news.povray.org>
  It's not a must.
  What do you mean? I have never noticed any problems.
Date: 22 May 2008 04:17:50
Message: <48352c2e$1@news.povray.org>
Warp napsal(a):
>   It's not a must.
I'm sorry for this.
This is only needed if one uses media.
Some people have reported black spots. I have noticed some too, but I
thought that it was caused by sharing samples between parallel surfaces.
Date: 23 May 2008 11:14:03
Message: <hond34hug8d4nrln91npietsj7a04vgbcf@4ax.com>
On Thu, 22 May 2008 08:28:52 +0200, Jan Dvorak
Thanks Jan,
	I was just wondering. I am using a large sphere for a
skysphere as I want a planet to be obscured slightly by clouds and a
skysphere will not do this. Incidentally I had to add the hollow
keyword to the sphere and the union it was in to get rid of the
warning.
Regards
Date: 23 May 2008 11:28:34
Message: <4836e2a2@news.povray.org>
  Btw, a layer of clouds is never a sphere centered at the camera.
If you are making a huge sphere to work as a sky sphere centered at
the origin (or the camera), that won't really work as realistic clouds.
  The sky_sphere is not even intended to be used for clouds (never mind
what the documentation and example scenes claim). It's intended for the
change in coloration of the sky which depends on the angle of incidence
(sky usually looks whiter closer to the horizon). Clouds should usually
be added as a plane or similar object.
Date: 23 May 2008 15:14:25
Message: <0e5e34hfm9davr1r5ote0322im2o4utcv7@4ax.com>
Drat! Would you expand a little, please?
At the moment I'm just using the sphere as a means of having a sky for
reflections on the sea and I will start working on the textures soon.
So any help will be appreciated.
Interesting, would you suggest a sky_sphere for the air with a "cloud
plane" in front of my background planet?
Regards
Date: 23 May 2008 15:34:33
Message: <48371c49@news.povray.org>
http://f-lohmueller.de/pov_tut/backgrnd/p_sky1.htm
Date: 23 May 2008 15:38:17
Message: <48371d29$1@news.povray.org>
Stephen nous illumina en ce 2008-05-23 15:14 -->
Unless you are at the center of a free floating bubble of air.
You can flatten the sphere with an uneven scaling and shift it down
(scale<1,0.5,1> translate -Radius/4*y). You'd still get the reflections.
The sky_sphere will also get reflected. Good for the background of the sky.
Remember that a sky_sphere never interact with any light and never cast any
shadow. It's a unit sphere centered on the camera, whose pigment get returned
whenever a ray is not stopped by an object.
That's the general idea. The cloud plane is transparent exept for the clouds
that will have various levels of opacity.
The sky_sphere hold the background pigment that is beyong everything else.
You can then add some fog or media.
Please hassle me, I thrive on stress.
Date: 23 May 2008 15:41:43
Message: <48371df6@news.povray.org>
  Maybe something along the lines of:
camera { location <0, 0, -1> look_at z angle 60 }
light_source { <-5, 10, 0>*1000, 1 }
sky_sphere
{ pigment
  { gradient y color_map
    { [0 rgb <.8, .9, 1>]
      [.4 rgb z]
      [1 rgb z*.7]
plane // ground
{ y, -10
  pigment
  { granite color_map
    { [0 rgb <1, .75, .5>]
      [1 rgb <.9, .6, .4>]
    scale 10
plane // clouds
{ -y, -100
  pigment
  { bozo color_map
    { [0 rgb .7]
      [.3 rgb 1 filter .4]
      [.5 rgbf 1]
    turbulence 1
    scale 100
  finish { ambient 1 }
sphere
{ <0, -2, 70>, 8
  finish { reflection { .75, 1 } }
