POV-Ray : Newsgroups : povray.general : [3.8] Forward And Backward Reaching Inverse Kinematics Server Time
17 Nov 2025 21:08:54 EST (-0500)
  [3.8] Forward And Backward Reaching Inverse Kinematics (Message 1 to 10 of 13)
Subject: [3.8] Forward And Backward Reaching Inverse Kinematics
Date: 1 Dec 2018 06:14:24
Message: <XnsA9AB7C841FAFAseed7@news.povray.org>
Did a quick search but nothing showed up for POV-Ray & FABRIK. So here's
my first attempt at the most basic version. Next steps will be more
complex skeletons with multiple ends and then joint constraints. I hope
that the latter can nicely done with the trace function.
Dictionaries are nice.
// Pov-Ray   : 3.8
// Scene File: FABRIK.inc
// Author    : Ingo Janssen
// Date      : 01-12-2018
// Version   : 1a
// Forward And Backward Reaching Inverse Kinematics (FABRIK) by Andreas
Aristidou.
// http://www.andreasaristidou.com/FABRIK.html
// http://www.andreasaristidou.com/publications/papers/FABRIK.pdf
http://www.andreasaristidou.com/publications/papers/Extending_FABRIK_wit
h_Model_C%CE%BFnstraints.pdf
// Excellent code inspiration & guide, by unknown author:
// https://developer.roblox.com/articles/Inverse-Kinematics-for-
Animation#FABRIK
#version 3.8;
#macro FABRIK(VecArr, VecTarget)
  // init
  #local self = dictionary {
    ["Joints"]      : VecArr,
    ["_O"]          : VecArr[0],
    // should be replaced by SetTarget
    ["Target"]      : VecTarget,
    // use .SetTarget(vec) to set a new target and iterate
    // still to be done somehowe.
    ["SetTarget"]   : false,
    ["Tolerance"]   : 0.1,
    ["MaxIter"]     : 100,
    ["_M"]          : false,
    ["_N"]          : false,
    ["_Reachable"]  : false,
    ["_Lengths"]    : false,
    ["_TotalLength"]: false,
  #local self._N = dimension_size(self.Joints, 1);
  #local self._M = self._N-1; //max index of array
  #macro LengthsArr()
    //#debug "LengthsArr :\n"
    #local Lengths = array[self._N-1];
    #local i = 0;
    #while (i < (self._N-1))
      #local Lengths[i] = vlength(self.Joints[i]-self.Joints[i+1]);
      //#debug concat("i : ",str(i,0,0)," len : ",str(Lengths
[i],0,3),"\n")
      #local i = i + 1;
    Lengths
  #local self._Lengths = LengthsArr();
  #macro LengthsSum()
    //#debug "LengthsSum :\n"
    #local Length = 0;
    #local i = 0;
    #while (i < dimension_size(self._Lengths,1))
       #local Length = Length + self._Lengths[i];
       //#debug concat("i : ",str(i,0,0)," len : ",str(self._Lengths
[i],0,3)," sum : ",str(Length,0,3),"\n")
       #local i = i + 1;
    Length
  #local self._TotalLength = LengthsSum();
  #macro Reach ()
    #debug "Reach : "
    #if (vlength(self._O-self.Target) > self._TotalLength)
      #local Reachable = false;
      #debug "False\n"
    #else
      #local Reachable = true;
      #debug "True\n"
    Reachable
  #local self._Reachable = Reach();
  #macro Backwards(Joints)
    #debug "  Backwards :\n"
    #local Joints[self._M] = self.Target;
    #for (i, self._M-1, 0, -1)
      #local l = self._Lengths[i]/vlength(Joints[i+1]-Joints[i]);
      #local Pos =  (1-l) * Joints[i+1] + l * Joints[i];
      #local Joints[i] = Pos;
      #debug concat("    i : ",str(i,0,0)," pos : ", vstr
(3,Pos,",",0,3),"\n")
    Joints
  #macro Forward(Joints)
    #debug "  Forward :\n"
    // set first point back to its original position
    #local Joints[0] = self._O;
    #for (i, 0, self._M-1, 1)
      #local Pos =  (1-l) * Joints[i] + l * Joints[i+1];
      #local Joints[i+1] = Pos;
    Joints
  #macro Stretch(Joints)
    #debug "Stretch :\n"
      #local l = self._Lengths[i]/vlength(self.Target-Joints[i]);
      #local Joints[i+1] = (1-l) * Joints[i] + l * self.Target;
      #debug concat("i : ",str(i,0,0), " pos : ", vstr(3,Joints[i+
1],",",0,3),"\n")
    Joints
  #macro Solve(Joints)
   #debug "Solving :\n"
   #if (self._Reachable = false)
      #local Joints = Stretch(Joints);
    #else
      #local itercount = 0;
      #local dif = vlength(self.Joints[self._M] - self.Target);
      #while (dif > self.Tolerance)
        #debug concat("  dif : ",str(dif,0,3)," iter : ",str
(itercount,0,0),"\n")
        #local Joints = Backwards(Joints);
        #local Joints = Forward(Joints);
        #local dif = vlength(Joints[self._M] - self.Target);
        #local itercount = itercount + 1;
        #if (itercount > self.MaxIter)
          #local dif = 0;
      #debug concat("\n  dif : ",str(dif,0,3)," end iter\n\n")
    Joints
  #local self.Joints = Solve(self.Joints)
  self
// testscene
#global_settings {assumed_gamma 1.0 }
#default {pigment{rgb 1} finish{ ambient 0.2 diffuse 0.9 }}
light_source{<1000,1000,-1000>, rgb 1}
plane{-z,0 pigment{checker rgb 0.8 rgb 0.5}}
camera {location <0, 4.5,-15> look_at <0,4.5,0>}
#macro Connect(Arr, RGB)
  #local l = dimension_size(Arr,1);
  #local i = 0;
  union{
    #while (i < l-1)
      sphere{Arr[i],0.2 pigment{rgb RGB}}
      cylinder{Arr[i],Arr[i+1],0.1  pigment{rgb RGB}}
      #local i=i+1;
    sphere{Arr[l-1],0.2 pigment{rgb <0,1,0>}}
#declare S = array[10]{
  <0,0,0>,<1,1,0>,<2,2,0>,
  <3,3,0>,<4,4,0>,<5,5,0>,
  <6,6,0>,<7,7,0>,<8,8,0>,
  <9,9,0>
#for (i,9,-9,-1)
  #declare T = <i,9,0>;
  #declare Spine = FABRIK(S, T);
  Connect(Spine.Joints, <1,0,0>)
Subject: Re: [3.8] Forward And Backward Reaching Inverse Kinematics
Date: 1 Dec 2018 11:18:41
Message: <XnsA9ABB01AD9149seed7@news.povray.org>
An updated version. Can now initialise the FABRIK without giving a
target. Add a target with
#declare Spine = FABRIK(somearraywithvectorsthatarejoints);
#declare Spine.Target = SetTarget(Spine, T);
and it calculates the new positions of the joints
ingo
// Pov-Ray   : 3.8
// Version   : 1a1
Aristidou.
Animation#FABRIK
#version 3.8;
#macro FABRIK(VecArr)
  #local self = dictionary {};
  #macro Init(self, VecArr)
    #macro LengthsArr(self, VecArr)
      #local self._Lengths = array[self._N-1];
      #local i = 0;
        #local self._Lengths[i] = vlength(VecArr[i]-VecArr[i+1]);
        #local i = i + 1;
    #macro LengthsSum(self)
      #local self._Length = 0;
      #local i = 0;
         #local self._Length = self._Length + self._Lengths[i];
         #local i = i + 1;
    #local self.Joints = VecArr;
    #local self.Tolerance = 0.1;
    #local self.MaxIter = 100;
    #local self._O = VecArr[0];
    #local self._N = dimension_size(VecArr, 1);
    LengthsSum(self)
  Init(self, VecArr)
  // internals
  #macro _Reach(self)
    #debug "Reach : "
    #if (vlength(self._O-self.Target) > self._Length)
      #local self._Reachable = false;
      #debug "False\n"
    #else
      #local self._Reachable = true;
      #debug "True\n"
  #macro _Backwards(self)
    #local self.Joints[self._M] = self.Target;
      #local l = self._Lengths[i]/vlength(self.Joints[i+1]-self.Joints
[i]);
      #local Pos =  (1-l) * self.Joints[i+1] + l * self.Joints[i];
      #local self.Joints[i] = Pos;
  #macro _Forward(self)
    #local self.Joints[0] = self._O;
[i]);
      #local Pos =  (1-l) * self.Joints[i] + l * self.Joints[i+1];
      #local self.Joints[i+1] = Pos;
  #macro _Stretch(self)
      #local l = self._Lengths[i]/vlength(self.Target-self.Joints[i]);
      #local self.Joints[i+1] = (1-l) * self.Joints[i] + l *
self.Target;
      #debug concat("i : ",str(i,0,0), " pos : ", vstr(3,self.Joints[i+
1],",",0,3),"\n")
  #macro _Solve(self)
      _Stretch(self)
    #else
        _Backwards(self)
        _Forward(self)
          #local dif = 0;
    true
  // external
  #macro SetTarget (self, Target)
    #local self.Target = Target;
    _Reach(self)
    _Solve(self)
  self
// testscene
camera {location <0, 0,-20> look_at <0,0,0>}
#macro Connect(Arr, RGB, r)
  #local i = 0;
  union{
    #while (i < l-1)
      sphere{Arr[i],r pigment{rgb RGB}}
      cylinder{Arr[i],Arr[i+1],r/2  pigment{rgb RGB}}
      #local i=i+1;
    sphere{Arr[l-1],r pigment{rgb <0,1,0>}}
  <9,9,0>
#declare Spine = FABRIK(S);
#macro Draw(T)
  Connect(Spine.Joints, <0,0,1>, 0.2)
#for (i,0,3,1)
  #switch(i)
    #case(0)
      #for (n,9,-9,-1)
        #declare T = <n,9,0>;
        Draw(T)
    #break
    #case(1)
      #for (n,9,-9,-1)
        #declare T = <-9,n,0>;
        Draw(T)
    #break
    #case(2)
      #for (n,-9,9,1)
        #declare T = <n,-9,0>;
        Draw(T)
    #break
    #case(3)
      #for (n,-9,9,1)
        #declare T = <9,n,0>;
        Draw(T)
    #break
Date: 1 Dec 2018 12:45:53
Message: <5c02c8d1@news.povray.org>
> Aristidou.
> //http://www.andreasaristidou.com/FABRIK.html
Very interesting. I also took a look at your you tube channel with the
motion capture. Again very interesting. About 15 years ago I downloaded
about 400 BVH files from MIT. Who opened the course data to the public.
I could have used your methods for cleaning up the foot slippage and
joint deformities. That was a lot of work in Poser, before exporting the
meshes to PoseRay then into Mesh2 for Pov.
Please keep us updated with your work.
Regards
Date: 1 Dec 2018 13:37:11
Message: <XnsA9ABC79532498seed7@news.povray.org>
>> Andreas Aristidou.
> the motion capture.
Not my channel Stephen, I just stumbled over Andreas' work yesterday and
implemented it in POV-Ray (peeking a lot at other code), well, just a part
of it for now.
Cheers,
ingo
Date: 1 Dec 2018 23:51:52
Message: <5c0364e8$1@news.povray.org>
>>> Andreas Aristidou.
>> the motion capture.
> of it for now.
My oops then. :)
Good luck with your IK project.
Regards
Date: 2 Dec 2018 05:55:00
Message: <web.5c03b9b475ee21eb25503a850@news.povray.org>
> >> Andreas Aristidou.
> > the motion capture.
interest
Date: 5 Dec 2018 03:49:16
Message: <XnsA9AF63E8912FBseed7@news.povray.org>
Another update. Before implementing more complex structures, I made it
possible to solve multiple independen IK's with one Fabrik 'object'
ingo
// Pov-Ray   : 3.8
// Rev Date  : 05-12-2018
// Version   : 1a2
Aristidou.
Animation#FABRIK
#version 3.8;
// macros starting with an underscore should not be called 'from the
outside'.
// only chains mentioned in the process dictionary will be initialised
// absence of the process dictionary will result in an error
// The FABRIK macro needs a rather complex datastructure as input, to be
explained later.
// Create an 'instance' of the Fabrik 'object': #declare S = FABRIK(F);
where F is the
// datastructure. Fabrik 'returns' an updated/initialised version of the
input structure.
// To run the IK solver use SetTarget(S, T) where S is the afore
mentioned insatance of
// Fabrik and T a datastructure holding the target(s)
#macro FABRIK(self)
  #ifndef (self.Proc)
    #error "\nNo Process 'Proc' dictionary defined\n"
  // add FABRIK global defaults, they can be overridden by adding a
Default
  // dictionary to a Chain dictionary. The Chain dict is checked first
for
  // these values, if not available the 'global' ones are used.
  #local self.Default = dictionary {
    ["MaxIter"] : 100
  #macro _Init(self)
    #macro _Lengths(self, Chain)
      #local self[Chain]._Lengths = array[self[Chain]._N-1];
      #local self[Chain]._Length = 0;
      #local i = 0;
      #while (i < (self[Chain]._N-1))
        #local self[Chain]._Lengths[i] = vlength(self[Chain].Joint[i]-
self[Chain].Joint[i+1]);
        #local self[Chain]._Length = self[Chain]._Length + self[Chain].
_Lengths[i];
        #local i = i + 1;
    #for (i,0,dimension_size(self.Proc,1)-1,1)
      #ifdef (self[self.Proc[i]].Joint)
        #local Chain = self.Proc[i];
        #debug concat("init chain : ", Chain, "\n")
        #local self[Chain]._O = self[Chain].Joint[0];
        #local self[Chain]._N = dimension_size(self[Chain].Joint, 1);
        #local self[Chain]._M = self[Chain]._N-1; //max index of array
  _Init(self)
  // internals
  #macro _Reach(self, Chain) //SimpleSolver & EndPoint
    #debug "Reach : "
    #if (vlength(self[Chain]._O - self[Chain].Target) > self[Chain].
_Length)
      #local self[Chain]._Reachable = false;
      #debug "False\n"
    #else
      #local self[Chain]._Reachable = true;
      #debug "True\n"
  #macro _Backwards(self, Chain)
    #local self[Chain].Joint[self[Chain]._M] = self[Chain].Target;
    #for (i, self[Chain]._M-1, 0, -1)
      #local l = self[Chain]._Lengths[i]/vlength(self[Chain].Joint[i+1]-
self[Chain].Joint[i]);
      #local Pos =  (1-l) * self[Chain].Joint[i+1] + l * self
[Chain].Joint[i];
      //if constraint
      //check constraint
      //if not within constraint adjust Pos
      //2B done
      #local self[Chain].Joint[i] = Pos;
  #macro _Forward(self, Chain)
    #local self[Chain].Joint[0] = self[Chain]._O;
    #for (i, 0, self[Chain]._M-1, 1)
      #local Pos =  (1-l) * self[Chain].Joint[i] + l * self[Chain].Joint
[i+1];
      //if constraint
      //check constraint
      //2B done
      #local self[Chain].Joint[i+1] = Pos;
  #macro _Stretch(self, Chain)
      #local l = self[Chain]._Lengths[i]/vlength(self[Chain].Target-self
[Chain].Joint[i]);
      #local self[Chain].Joint[i+1] = (1-l) * self[Chain].Joint[i] + l *
self[Chain].Target;
[Chain].Joint[i+1],",",0,3),"\n")
  #macro _SolveSimple(self, Chain)
    #if (self[Chain]._Reachable = false)
    #else
      #local dif = vlength(self[Chain].Joint[self[Chain]._M] - self
[Chain].Target);
      #while (dif > self.Default.Tolerance)  //2B done also check chain
local defaults
[Chain].Target);
        #if (itercount > self.Default.MaxIter)//2B done also check chain
local defaults
          #local dif = 0;
  // external
  #macro SetTarget (self, T)
    #for (i, 0, dimension_size(T.Index,1)-1,1)
      #local Chain = T.Index[i];
      #debug concat("set target : ", Chain, "\n")
      #local self[Chain].Target = T[Chain];
      _Reach(self, T.Index[i])
      _SolveSimple(self, T.Index[i])
  self
/*test scene*/
#global_settings{assumed_gamma 1.0 }
#default{pigment{rgb 1} finish{ ambient 0.2 diffuse 0.9 }}
//plane{-z,0 pigment{checker rgb 0.8 rgb 0.5}}
camera{location <0,0,-8> look_at <0,0,0>}
// Two 'independent' chains
#declare F = dictionary{
  ["Proc"]: array[2]{"Base1", "Base2"},
  ["Base1"]   : dictionary {
      ["Joint"] : array[6]{<0,0,0>, < 0,1,0>, < 0,2,0>, < 0,3,0>,
<0,4,0>, <0,5,0>},
  ["Base2"]   : dictionary {
<0,4,0>, <0,5,0>},
#declare T = dictionary {
  ["Index"] : array[2]{"Base1", "Base2"},
  ["Base1"] : <4,0,0>,
  ["Base2"] : <-4,0,0>
SetTarget(S, T)
#for (i,0,dimension_size(S.Proc,1)-1,1)
  #ifdef (S[S.Proc[i]].Joint)
    #local Chain = S.Proc[i];
    #for (n,0,S[Chain]._M-1,1)
      sphere{S[Chain].Joint[n], 0.2}
      cylinder{S[Chain].Joint[n],S[Chain].Joint[n+1],0.2}
    sphere{S[Chain].Joint[n], 0.2 pigment{rgb x}} //end points
Date: 10 Dec 2018 10:38:04
Message: <XnsA9B4A9371664Eseed7@news.povray.org>
Added an updated version in p.b.scene-files FABRIK IK
<XnsA9B4A7C06381seed7@news.povray.org>
http://news.povray.org/povray.binaries.scene-files/thread/%
3CXnsA9B4A7C06381seed7%40news.povray.org%3E/
Still needs a lot of work but the basics do work.
I have an implementation for moving other nodes than the end nodes but
it's complicated to integrate. I have an implementation for movement
restriction, simplified from what is in the paper. Closed loops is one I
havn't looked at yet.
Specifying the whole FABRIC dictionary as it is now is tedious and will be
simplified. Most of the data there can be derived during initialisation,
ingo
Date: 19 Dec 2018 13:51:12
Message: <XnsA9BDC9F61A606seed7@news.povray.org>
in news:XnsA9AB7C841FAFAseed7@news.povray.org ingo wrote:
> So here's
Several more attempts followed. I put the code in a Fossil at
https://chiselapp.com/user/ingo/repository/POV-Ray-FABRIK/home
It runs smoothly now. Updated the interface to the macro to make it easier
to experiment. All still not well documented.
Next will be the addition of movement constraints.
ingo
Date: 19 Dec 2018 18:55:01
Message: <web.5c1ad94775ee21eb48892b50@news.povray.org>
hi,
> ... I put the code in a Fossil at
thanks, downloaded.
looking forward to more playing.  :-)
also, a "feature request": during initialisation, a means to enable or disable
the debug output for that scene would be handy.
regards, jr.
