POV-Ray : Newsgroups : povray.general : Duplicate ? Server Time
22 Apr 2026 05:11:06 EDT (-0400)
  Duplicate ? (Message 1 to 10 of 26)
Subject: Duplicate ?
Date: 24 Nov 2002 12:02:23
Message: <Xns92D0B6F081DF6raf256com@204.213.191.226>
I have following problem - I want to cover large area (about 1000x1000
units) by grass, each grass "leaf" tooks about 1 unit space on ground, so I
wolud need about 1 mln leafs.
Each leaf is build from about 500 triangles, with gives 500,000,000
triangles - way to much to hold in memory.
So I thinked of optimisation :
1. every grass leaf is a mesh
2. organise 10x10 leafs into an union like GrassBlock
3. cover area (flat land) with same GrassBlock object
problem is with step #3 - each :
  object { GrassBlock translate <X,0,Z> }
results in duplicating GrassBlock in memory - so no memroy is saved as I
aspected.
AFAIK if GrassBlock would be a mesh (not union of 100 meshes) then it wolud
not be duplicated right ?
So I suggest 2 future reguests to achive this :
1. allow syntax
mesh {
  mesh { ... rotate ... translate ... } // leaf 1
  mesh { ... rotate ... translate ... } // leaf 2
} // grass block
2. add new syntax :
  duplicate { ... }
that will work in same way as
  object {... }
but will re-use memory
Subject: Re: Duplicate ?
Date: 24 Nov 2002 12:30:53
Message: <3de10ccd@news.povray.org>
"Rafal 'Raf256' Maj" <raf### [at] raf256com> schrieb im Newsbeitrag
> 1. allow syntax
> mesh {
> } // grass block
Why don't you just use a macro for this? Okay, you will end up, with one
mesh with some thousands of triangles, but that should be no problem, as
most meshes are much larger.
Marc-Hendrik
Date: 24 Nov 2002 12:44:19
Message: <3de10ff3@news.povray.org>
In article <Xns### [at] 204213191226>, "Rafal 'Raf256' Maj"
> aspected.
If this is happening to you, you are not using the mesh object properly.
Follow Marc's suggestion and maybe you also should try to just explain your
problem and wait for an answer, not immediately turn it into a redundant
feature request...
    Thorsten
e-mail: tho### [at] trfde
Date: 24 Nov 2002 12:48:10
Message: <chrishuff-C869B0.12464124112002@netplex.aussie.org>
> 1. allow syntax
> mesh {
> } // grass block
This type of thing has been discussed many times before. It would be a
fairly major piece of work to do it completely, but it has a chance of
being done as a 3.5 patch. Something similar for blobs would be nice too.
> 2. add new syntax :
>   duplicate { ... }
>   object {... }
There is no need for a new syntax, copy by reference can be done with
the existing syntax. However, it would take a lot of work, don't expect
it before the 4.0 rewrite.
The best solution to your problem would be to just put multiple grass
blades in a single mesh tile. This is the most efficient way to do mesh
grass.
http://tag.povray.org/
Subject: Re: (exacly) - Duplicate ?
Date: 24 Nov 2002 13:04:54
Message: <Xns92D0C18A32116raf256com@204.213.191.226>
"Marc-Hendrik Bremer" <Mar### [at] t-onlinede> wrote in
news:3de10ccd@news.povray.org
> news:Xns### [at] 204213191226...
>> 1. allow syntax
>> mesh {
>> } // grass block
I do use macro :)
Exacly :
Macro PutGrass - generates single grass leaf (about 200-500 triangles).
It works as :
mesh {
  // loop {
    triangle { ... }
  translate ... rotate ... // ((-1-))
Macro PutGrassArea calls PutGrass in loop
Later, we have
#declare GrassBlock = union { // ((-2-))
  PutGrassArea(0,0,10,10)
The problem is, that I cann't change union to mesh in line ((-2-)) due to
transforms in ((-1-))
In free time I will try to work-around, by either :
1. removing ((-1-)) and applying this transform to each wector of each
triangle by hand (vrotate etc)
2. writting a C program that will generate grass for me (GrassBlock)
any other ideas ?
Date: 24 Nov 2002 13:06:00
Message: <Xns92D0C1BA42826raf256com@204.213.191.226>
"Thorsten Froehlich" <tho### [at] trfde> wrote in
news:3de10ff3@news.povray.org
> properly.
> your problem and wait for an answer, not immediately turn it into a
> redundant feature request...
Ok, I did it. I know that it would be better to have one mesh istead union
of 100 meshes, but as I explain - it's a problem due to transforms in each
"sub-mesh"
Date: 24 Nov 2002 14:07:25
Message: <3de1236d$1@news.povray.org>
>> properly.
> "sub-mesh"
No, create one mesh, i.e. #declare mymesh = mesh { ... }.  Then transform it
using object { mymesh translate ... rotate ... }.  In consequence you have
exactly one mesh in memory and can then transform it as necessary.  The mesh
data will not be copied.  Of course, the transform data needs to be stored
for each copy of the mesh (unless you don't transform it, of course).
That way your one million pieces of grass (meshes) will take somewhere
between 100 and 500 bytes per piece of grass (meshes).
    Thorsten
Date: 24 Nov 2002 14:07:49
Message: <3de12385$1@news.povray.org>
In article <chr### [at] netplexaussieorg> ,
Christopher James Huff <chr### [at] maccom>  wrote:
>> 2. add new syntax :
>>   duplicate { ... }
>>   object {... }
> grass.
You forgot that meshes are already reference copied.
    Thorsten
Date: 24 Nov 2002 14:09:41
Message: <3de123f5$1@news.povray.org>
> It works as :
> mesh {
>   // loop {
>     triangle { ... }
> Later, we have
This in no way shows what you are doing.  Do you create multiple
"GrassBlock"s?  Or do you copy them?  Just some rough scatch of your scene
will not allow anybody to determine what you are doing wrong, nor really
help you without having to guess most of the important facts.
    Thorsten
Date: 24 Nov 2002 14:29:45
Message: <Xns92D0CFED285BAraf256com@204.213.191.226>
news:3de12385$1@news.povray.org
This future will be very usefull for other objects, i.e. I made trees
basing mostly on cones. I'm planing to make a sity - there I would use
mostly box'es (differences / intersecions / union's of them)
