POV-Ray : Newsgroups : povray.general : Pov -> mesh Server Time
22 Apr 2026 06:44:27 EDT (-0400)
  Pov -> mesh (Message 1 to 6 of 6)
Subject: Pov -> mesh
Date: 5 Nov 2002 00:18:33
Message: <Xns92BD3F756738Fraf256com@204.213.191.226>
Hello,
do we have some POV scripts that converts scenes into mesh formats that can
be i.e. exported to 3dSMax ?
Subject: Re: Pov -> mesh
Date: 5 Nov 2002 01:06:28
Message: <dunesuojb1hue309jnd2cae2e07gd5ls71@4ax.com>
On 5 Nov 2002 00:18:33 -0500, "Rafal 'Raf256' Maj" <raf### [at] raf256com>
wrote:
you can find a Moray plugin at www.tb-software.com which can export a
Moray scene to 3d faces.
>Hello,
Date: 5 Nov 2002 04:00:57
Message: <3dc788c9@news.povray.org>
I heard about tesselate, but it seams to be a patch for the source code...
The idea would be to modify the source to ouput the mesh datas in a separate
file, am I wrong ?
L.H.
Xns### [at] 204213191226...
> Hello,
can
> #macro
g(U,V)(.4*abs(sin(9*sqrt(pow(x-U,2)+pow(y-V,2))))*pow(1-min(1,(sqrt(
> pow(x-U,2)+pow(y-V,2))*.3)),2)+.9)#end#macro p(c)#if(c>1)#local
l=mod(c,100
> );g(2*div(l,10)-8,2*mod(l,10)-8)*p(div(c,100))#else 1#end#end
light_source{
> y 2}sphere{z*20
9pigment{function{p(26252423)*p(36455644)*p(66656463)}}}//M
Date: 5 Nov 2002 04:15:04
Message: <c92fsu88kujqvevu6k9urnrhrla99h1gtn@4ax.com>
On 5 Nov 2002 00:18:33 -0500, "Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote:
> Hello,
Some shapes are not easy translable. In case you can recreate your scene only
with parametric objects, meshes, surfaces enclosed in splines then you can use
macros from Ingo to export it. Of course exporting CSG is not trivial. Another
way is to use patched POV: tesselator by Jerome Gribert or idea of adding new
method with tesselation of primitive objects.
ABX
Date: 5 Nov 2002 07:03:55
Message: <3DC7B3E1.5090709@free.fr>
> file, am I wrong ?
tesselate is a patch, so you are correct.
Problem:
 tesselate works only with:
  - Finite
  - 3D
  - Bounded
Objects. (these conditions are cumulatives).
There is also a mesh import/export to GTS format(GTS: Gnu Tesselated
Surface, IIRC), loosing the texture in the process (GTS does not have
texture).
So, if your scene can be tesselated, you can export it...
Date: 14 Nov 2002 05:58:44
Message: <3dd381e4$1@news.povray.org>
I guess this is exactly what I need.
Merci :)
 Luc.
3DC### [at] freefr...
code...
separate
> > file, am I wrong ?
> Problem:
>   - Finite
>   - 3D
>   - Bounded
> texture).
