POV-Ray : Newsgroups : povray.general : rose :) Server Time
12 Jan 2026 06:06:28 EST (-0500)
  rose :) (Message 1 to 6 of 6)
Subject: rose :)
Date: 27 Oct 2002 18:54:20
Message: <Xns92B58EE588B6raf256com@204.213.191.226>
Hello,
i'm planing to make little un-typical "gift" for someone :P one of it's
elements would be an rose. Any suggestions how to make it ?
Currently i'm planing :
spheres-sweep as main part, thene cones (or some more comples shapes)
putted along main part as spikes.
Biggest proelm is with top of flower, maybe isosurface ? Any suggestions
what formula(s) will be usefull ?
Subject: Re: rose :)
Date: 27 Oct 2002 19:51:20
Message: <3dbc8a08$1@news.povray.org>
Your best bet is probably something like a triangle mesh or something else
that can be flat; and you should probably model it in another problem, since
rose petals are not easily modelled with primitives, especially through
scripting.
In a pinch, I imagine one could make decent tulip petals via spheres using
clipped_by...
 - Slime
[ http://www.slimeland.com/ ]
Date: 28 Oct 2002 03:27:04
Message: <3dbcf4d8$1@news.povray.org>
Or some gerberas using meshes. These were
modelled in POV, using splines (my own
POV-script implemented version of bezier-splines),
sine waves overimposed on the meshes...
A little tiny bit difficult, but the gerbera was an
easy model. I've thought about modelling a rose
someday, but not now. Haven't got the time...
Look on my homepage, under "Past Projects". You
might find some clues on how to tackle your problem.
Tim
Tim Nikias
Email: Tim### [at] gmxde
since
> scripting.
> clipped_by...
Date: 28 Oct 2002 06:35:01
Message: <3dbd20e5$1@news.povray.org>
I suggest you to use Spatch, or Hamapath. they are freeware that enable you
to create bicubic patch very easily. I dont remember where you can download
the program, but I think I could find an archive on my HD.
Chaps.
"Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote in message
> Hello,
> #macro
g(U,V)(.4*abs(sin(9*sqrt(pow(x-U,2)+pow(y-V,2))))*pow(1-min(1,(sqrt(
> pow(x-U,2)+pow(y-V,2))*.3)),2)+.9)#end#macro p(c)#if(c>1)#local
l=mod(c,100
> );g(2*div(l,10)-8,2*mod(l,10)-8)*p(div(c,100))#else 1#end#end
light_source{
> y 2}sphere{z*20
9pigment{function{p(26252423)*p(36455644)*p(66656463)}}}//M
Date: 28 Oct 2002 07:24:13
Message: <MPG.18273cf322ece8d2989c06@news.povray.org>
In article <3dbd20e5$1@news.povray.org>, cha### [at] yahoocom says...
Hamapatch - http://www.geocities.com/Tokyo/Ginza/6625/soft10.html
Jamie.
Subject: RE: rose :)
Date: 29 Oct 2002 20:08:19
Message: <3dbf3103@news.povray.org>
3dbd20e5$1@news.povray.org...
you
download
These links lead you to the programs download (and tutorials, and objects,
links...):
spatch: http://www.geocities.com/getspatch/index.html
hamapatch: http://www.geocities.com/hamapatch/program/index.html
This one works with meshes, but it's very useful (and also free):
anim8or: http://www.anim8or.com/
A rose model in spatch format (you can use spatch or hamapatch to open it):
http://www.geekspace.com/~rozzin/graphics/3-D/sPatch/rose/
Hope this helps
Txemi Jendrix
http://www.txemijendrix.com
