POV-Ray : Newsgroups : povray.general : volumetric textures? Server Time
25 Apr 2026 21:50:54 EDT (-0400)
  volumetric textures? (Message 1 to 5 of 5)
Subject: volumetric textures?
Date: 25 Jun 2000 20:40:20
Message: <8F5EDB907dashixpressnet@204.213.191.228>
can anyone point me to a URL or anything for making a volumetric textures
in pov? I'm thinking white energy beams or something....I can make the 2d
texture without a problem, but it doesn't have any depth to it...
do I need to use media to do this? (any pointers if this is the case?)
if its media wouldn't that put the render time through the roof....maybe I
should consider not doing this?
thanx in advance
Subject: Re: volumetric textures?
Date: 26 Jun 2000 01:07:51
Message: <3956e527@news.povray.org>
"daishi" <das### [at] x-pressnet> wrote in message
news:8F5EDB907dashixpressnet@204.213.191.228...
If you have, or get, MegaPov ( www.nathan.kopp.com/patched.htm ) then it's not
so very slow to use media.  I think that media is your only option since
objects tend to always show their edges.  Well, now that I think about it a
dense white fog inside a bunch of cones might look reasonable, just nothing
like media would look.
Example:
// BEGIN
global_settings {
        max_trace_level 10
light_source { 0 color rgb 1}
  location  <5,5,-15>
  angle 30
  look_at   <0,0,0>
sphere {0,1 hollow
        pigment {gradient y color_map {
                [0 color rgb <.5,.25,.125>]
                [1 color rgb <.125,.25,.5>]
       finish {ambient 1}
    scale 100
fog {
  fog_type 1
  distance 1
  color rgb 1
merge {
#declare N=10;
#declare sNx=seed(1234);
#declare sNy=seed(4321);
#declare sNz=seed(2341);
#while (N>0)
#declare rNx=rand(sNx);
#declare rNy=rand(sNy);
#declare rNz=rand(sNz);
cone {0,.1,y,.5
      pigment {rgbf 1}
    scale <1,5,1> rotate <rNx,rNy,rNz>*360
#declare N=N-1;
 no_shadow inverse
// END
Not very useful as beams of light really.
Date: 26 Jun 2000 12:31:28
Message: <39578560@news.povray.org>
I use spotlights in media, you need to use fade_power and fade_distance
sometimes too. Media method3 in megaPov is fast when used for this purpose.
Mick
> thanx in advance
Date: 26 Jun 2000 20:35:38
Message: <chrishuff-C9054C.19400926062000@news.povray.org>
In article <8F5EDB907dashixpressnet@204.213.191.228>, das### [at] x-pressnet
> roof....maybe I should consider not doing this?
You need to use media. As for the render time, you should get MegaPOV,
which has new sampling methods which greatly speed up rendering. Also,
always contain your media in an object, even if it means enclosing the
entire scene in a large sphere or box, it generally works much better
than global media. If you are doing a sort of laser effect, try using
emitting media confined in a cone or cylinder as the beam...emitting
media is much faster than scattering media.
Date: 27 Jun 2000 00:07:26
Message: <8F5FF6178dashixpressnet@204.213.191.228>
right. I whipped up a quick little test today using moray to create the
emitting media in, and I got pretty good results. alas my eval version of
rhino has expired so I won't be making any scenes until I purchase the full
version..
I know I could do it in pov, but I like rhino as far as modelling goes (and
creating all the blobbies/sphere's along a path would be kinda a pain for
what I had in mind)
chr### [at] maccom (Chris Huff) wrote in <chrishuff-
C9054C.19400926062000@news.povray.org>:
