POV-Ray : Newsgroups : povray.general : Not grokking mesh camera Server Time
3 Nov 2025 13:07:47 EST (-0500)
  Not grokking mesh camera (Message 1 to 10 of 17)
Subject: Not grokking mesh camera
Date: 29 Apr 2023 22:30:48
Message: <644dd2d8$1@news.povray.org>
I am trying to understand the mesh camera and picking apart the demo
scenes but I'm just not getting something.
I thought the mesh involved had to have on triangle per pixel, and
that's easy enough. The normal vector of the triangle determines the
direction of the ray for that pixel. Does the position of the mesh also
determine the location of the ray?
A second question: is the first triangle in the mesh the upper left
corner of the image or bottom left corner?
A third question: does the ray start at the first vector in each triangle?
I set up a simple scene with a vertical cylinder, but through the mesh
camera it shows up horizontally. So I'm wondering if the second triangle
in the mesh has to follow the column or the row.
Any help from those of you who are way smarter than me?
Thanks
Uncle Josh
Subject: Re: Not grokking mesh camera
Date: 30 Apr 2023 08:08:50
Message: <644e5a52$1@news.povray.org>
On 30/04/2023 12:30, Josh English wrote:
> I am trying to understand the mesh camera and picking apart the demo scenes but I'm
It's a long time since I wrote the mesh camera code, so please excuse me if my memory
is rusty, but I'll try to answer.
The following applies to distribution methods 0, 1 and 2:
> The normal vector of the triangle determines the direction of the ray for that
pixel.
Yes, with the consideration that if the camera Z direction is less than 0, the normal
is reversed.
> Does the position of the mesh also determine the location of the ray?
Yes, with the caveat that the Z location of the camera is then used to offset the
ray's origin along its direction.
> A second question: is the first triangle in the mesh the upper left corner of the
Upper left. The face index is mapped as y * width + x, where y, width and x are all
first mapped to unsigned int.
No, it's shot from the triangle's centroid.
About mesh selection:
Distribution 0 is single or multiple rays per pixel, with each additional ray going to
the next mesh in the sequence in which they were declared.
Distribution 1 is 1:1 distribution across summed meshes, potentially with multiple
rays per pixel. The faces of all the supplied meshes are logically summed together as
if they were one single mesh. If shooting multiple rays per pixel, the face index is
determined as (width * height * ray_number) + pixel_number.
Distribution 2 is multiple logical cameras, placed side-by-size horizontally, with
mesh #0 being the left-most camera, and mesh #n is the right-most. Rays per pixel is
ignored.
I won't cover distribution 3 here as it's quite different from the above.
I also suggest that, if you haven't already done so, you take a look at Jaime's mesh
camera page at http://www.ignorancia.org/index.php/technical/mesh-camera/. He's also
posted some other examples here in the groups, e.g.
http://news.povray.org/povray.binaries.images/thread/%3C500fb7e5%40news.povray.org%3E/
-- Chris
Date: 30 Apr 2023 17:44:13
Message: <644ee12d@news.povray.org>
> Jaime's mesh camera page at
> -- Chris
Thank you.
I was going through Jaime's demo files and just not understanding the
logic. I still don't but I think my problem may be in my mesh
generation. I am looping through each row, then each column, and
creating a triangle, but I was not creating an equilateral triangle and
I thought that was the problem. I updated my code to match Jaime's but
the problem remains.
My loops:
// frame for the mesh
#declare UL = <(-image_width/image_height)/2, 2, -4>;
#declare LR = <(image_width/image_height)/2, 1, -4>;
#declare u_vect = <LR.x, UL.y, LR.z> - UL;
#declare v_vect = <UL.x, LR.y, LR.z> - UL;
#declare tr_base_1=<        0,2/3,0>*0.1;
#declare tr_base_2=< 1/2, -1/3,0>*0.1;
#declare tr_base_3=<-1/2, -1/3,0>*0.1;
#declare camera_mesh =
mesh {
   #for(V,0,image_height,1)
     #for(U,0,image_width,1)
       #declare here = (UL+u_vect*(U/image_width)+v_vect*(V/image_height));
       triangle {
         here + tr_base_1, here + tr_base_2, here + tr_base_3
     #end // for U
   #end // for V
} // mesh
The first attachment shows the basic scene, where I've built the mesh
and what it's looking at. The second attachment shows the results of
using the mesh with distribution 0. The cylinder is diagonal and repeated.
The mesh camera code itself is
   mesh_camera { 1 0
     mesh { camera_mesh }
   location <0,0,-.1>
   direction z
I have no idea what's going on with this code.
Josh
Download 'mech_cam_blocking.png' (196 KB) Download 'mesh_cam_wtf.png' (18 KB)
Preview of image 'mech_cam_blocking.png'
Preview of image 'mesh_cam_wtf.png'
Date: 1 May 2023 08:45:00
Message: <web.644fb3e469f7937358c093306cde94f1@news.povray.org>
hi,
while I would not be able to tell, at any rate, a ready-to-run copy'n'paste code
to "try things" would have been nice/helpful.
regards, jr.
Date: 1 May 2023 15:32:46
Message: <645013de$1@news.povray.org>
On 5/1/2023 5:43 AM, jr wrote:
> hi,
> regards, jr.
True. Unfortunately my code is so hodge-podge I am always reluctant to
post it because a) I suck at documentation, and b) you guys shouldn't
have to perform archeology for me.
I gave up and stole one of Jaime's macros then hacked it to do what I
wanted.
I've attached the code that's misbehaving.
Download 'mesh_explorer.png' (30 KB)
Preview of image 'mesh_explorer.png'
Date: 1 May 2023 21:54:15
Message: <64506d47$1@news.povray.org>
>> hi,
>> copy'n'paste code
>> regards, jr.
> wanted.
  Oh ffs.
Download 'mesh_explorer.pov.txt' (5 KB)
Date: 2 May 2023 07:25:00
Message: <web.6450f2e969f7937358c093306cde94f1@news.povray.org>
hi,
> >> code to "try things" would have been nice/helpful.
> > True. Unfortunately my code is so hodge-podge I am always reluctant ...
know that feeling :-)  also think though that when one runs into a problem,
writing some code just to replicate the problem in the simplest scene possible,
can often provide (new) insight.
>   Oh ffs.
</grin>
thanks.  will follow this thread with interest, as mesh cam is a big puzzle to
me.
regards, jr.
Date: 5 May 2023 02:17:07
Message: <64549f63@news.povray.org>
On 5/2/2023 4:24 AM, jr wrote:
> hi,
>>    Oh ffs.
> </grin>
> me.
> regards, jr.
I found the mistake that is causing the skewed image. I forgot the end
condition on a FOR loop will can the end value of the loop, so I was
calculating one extra pixel per row, which the mesh camera dutifully
pushed to the next row, so my original code was generating more
triangles than needed.
Live and learn.
Well ... live.
Josh
Date: 5 May 2023 06:25:00
Message: <web.6454d95f69f793731f9dae3025979125@news.povray.org>
Ah - that explains it.
Of course, now that you've discovered that, you could actually (ab)use that to
do things like a TV-interference effect.  Also wondering what happens if you
double the columns and halve the rows.  Triple, quadruple...
Perhaps at some point when you get everything mostly worked out to your liking,
you can post a working scene file.  It would be nice to make some explanatory
diagrams to complement the extant documentation, and maybe make a version that
makes use of a Bezier patch as the camera control surface.  :)
Nice job hunting down the cause.
- BW
Date: 5 May 2023 16:30:02
Message: <6455674a$1@news.povray.org>
I'm thinking about how to explain some of my discoveries to expand on
Jaime's work.
But bezier patches? That's a cruel challenge. I don't know how to
convert a patch to a mesh in the first place. That's why I used them: to
let POV-Ray do the hard work.
Josh
