POV-Ray : Newsgroups : povray.general : min_ and max_extent of an intersection object Server Time
16 Aug 2025 23:57:02 EDT (-0400)
  min_ and max_extent of an intersection object (Message 1 to 10 of 11)
Subject: min_ and max_extent of an intersection object
Date: 26 Jun 2020 02:43:36
Message: <5ef59918$1@news.povray.org>
I should have known of course, and instead of swearing by Eagle the
Bald, sacrificing nameless things to the Clipka idol and invoking the
good spirit of Saint William of the Pokorny (in that order) for a couple
of days, I should have opened the Grimoire and read:
"Note: This is not perfect, in some cases (such as CSG intersections and
differences or isosurfaces) the bounding box does not represent the
actual dimensions of the object."
The hell it doesn't!
So, I am left with the good old trial-and-error finding of the right
dimensions/locations of intersection objects. Not a big deal afaiac ;-)
Still, I have been wondering if there would be other, smart, ways to do
the same? And - just out of pure curiosity - why do min_extent and
max_extent not work with intersections or differences? Where isosurfaces
are concerned, I can imagine indeed...
Subject: Re: min_ and max_extent of an intersection object
Date: 26 Jun 2020 03:10:01
Message: <web.5ef59e96a14394982945efad0@news.povray.org>
LOL, the problem is so much simpler: This is a patch added from the old MegaPOV,
and all it does is provide access to the internal bounding boxes POV-Ray uses to
speed up rendering. Of course, a perfect bounding box does not matter as much
for this purpose, and the bounding in POV-Ray was never well optmised.
In fact, for CSG is is mostly additive (for the most part the biggest box
bounding all objects) and for isosurces you do actually provide the bounding box
via contained_by .
Thorsten
Date: 26 Jun 2020 03:15:04
Message: <web.5ef59f4ba14394984d00143e0@news.povray.org>
hi,
(when making sacrifices, substituting the virgins with their grandmothers does
not help!  :-))
> the same? ...
perhaps the 'Bounder' will work with "intersection objects"?
regards, jr.
Date: 26 Jun 2020 06:55:01
Message: <web.5ef5d332a1439498fb0b41570@news.povray.org>
..oO(Oh boy, he's swearing again...)
Well, yes, we all knew that - which is what jr's bounding macro - using trace ()
- is all about, and my attempt at doing the same using SVD were all about.
I had a bit of a hard time visualizing some of what the docs were saying a while
back, and clipka gave a little more explanation about about certain pathological
cases. (presumably he was not referring to you at the time)
If your human/mathematical knowledge lets you know approximately the range of a
function in an isosurface, but you don't know _exactly_the bounds of the
surface, you can iterate through the function with a nested x, y, z #for loop
and use min and max to update the value of an indicator with each evaluation.
Date: 27 Jun 2020 02:37:02
Message: <5ef6e90e@news.povray.org>
Op 26/06/2020 om 09:10 schreef jr:
> hi,
> not help!  :-))
I just discovered that indeed! ;-)
>> the same? ...
And so I forgot about that tool! :-/
However, it does not work either for the case in question. The results
are different from the classical way but still wrong.
I attach a little test scene together with version 3 of Bounder where I
only changed two #local statements to #declare.
Download 'bounder.inc.txt' (9 KB) Download 'intersection_test.pov.txt' (5 KB)
Date: 27 Jun 2020 02:38:47
Message: <5ef6e977@news.povray.org>
Op 26/06/2020 om 09:07 schreef Thorsten Froehlich:
> via contained_by .
> Thorsten
Ah! yes, I hear a distant bell tolling.
Date: 27 Jun 2020 02:44:06
Message: <5ef6eab6$1@news.povray.org>
Op 26/06/2020 om 12:51 schreef Bald Eagle:
Couldn't be helped ;-)
Unfortunately, his bounding macro does not work correctly either in this
case (see my answer to jr).
Well, I was not working with isosurfaces in this particular case but
with good old CSG's. However, I shall keep this suggestion in mind (if
my dreadful memory permits; I totally forgot about jr's macro...).
Date: 27 Jun 2020 05:35:00
Message: <web.5ef71204a14394984d00143e0@news.povray.org>
hi,
appears to work but wrong result?  the stuff of nightmares.  :-(
thanks.  I'll have a look sometime this weekend.
regards, jr.
Date: 27 Jun 2020 09:40:09
Message: <web.5ef74b27a14394984d00143e0@news.povray.org>
hi,
one thing that grabbed my attention is the scaling of 'Crossing', after it has
been created.  so I moved the 'scale 1.01' from line 73 into the declaration of
'Crossing', as line 66.  the figures output, and the images, differ slightly,
and
I am at a disadvantage in that I do not know what the "correct" result should
look like.  :-)
regards, jr.
Date: 28 Jun 2020 02:48:41
Message: <5ef83d49$1@news.povray.org>
Op 27/06/2020 om 15:35 schreef jr:
> hi,
> and
> look like.  :-)
I solved it! And, like always, it was a trivial problem :-)
I forgot to increase the resolution parameter in Bounder. For testing, I
had kept it low (10) but when increasing the value to, e.g. 50 or
higher, Bounder gives the correct answers for optimized min and max extents.
So, after all, your macro works also correctly for intersections (and
probably differences too), which is good to know of course. I shall keep
it close at hand from now on.
