POV-Ray : Newsgroups : povray.general : Strange cuts on rendered objects Server Time
26 May 2024 02:52:39 EDT (-0400)
  Strange cuts on rendered objects (Message 1 to 10 of 18)
Subject: Strange cuts on rendered objects
Date: 3 Feb 2020 10:35:01
Message: <web.5e38381eb3cfd5d4c30604810@news.povray.org>
Hello !!
I'm a Master student in Space Engineering in Politecnico di Milano.
I'm using POVRay for my master thesis project and I was really impressed by
POVRay rendering capabilities.
Specifically, I'm using POVRay to generate images of a spacecraft in random
position into a generic orbit, which subsequently I'll analyze with different
computer vision algorithms to try to recognize the spacecraft into the scene.
The spacecraft has first been modeled with Autodesk Inventor, then it has been
imported into Blender to exploit the POVRay addon for Blender capability to
generate directly generate POV code.
The POV blender code was then manipulated in order to obtain a .inc file
containing the "spececraft" object, which is assembled by the "merge"
(https://gitlab.com/bosconovic/spacacecraft-pov/blob/master/satellite.inc#L158)
of the different spacecraft mesh2 components.
I did the merge in order to be able to simply call the "spacecraft" object in my
pov
file and place it into the scene, with the ability to rotate and translate it by
simply manipulating the object's attitude\position matrix (which is randomly
generated) :
https://gitlab.com/bosconovic/spacacecraft-pov/blob/master/tango_102.pov#L24 .
The issue is that, sometimes, for certain combination of spacecraft\camera
relative position the spacecraft it is not entirely rendered, and I cannot
understand why.
Here two pictures of the problem :
 - https://gitlab.com/bosconovic/spacacecraft-pov/blob/master/tango_102.png
 - https://gitlab.com/bosconovic/spacacecraft-pov/blob/master/tango_30.png
In the first one almost half of the spacecraft is cutted, in the second on the
left a piece of the solar panel is cutted.
Can anyone help me out to understand what I'm doing wrong ?
Here is the POV source I'm using along with the Blender model :
This is the command I use to generate the images : povray tango_102.pov +H1200
+W1920
Subject: Re: Strange cuts on rendered objects
Date: 3 Feb 2020 13:25:01
Message: <web.5e3865396f77a7a54eec112d0@news.povray.org>
Sounds very cool - what computer vision algorithms are you using?
And welcome to the forum.  :)
Without seeing the code for your scene --- it could be almost anything.
With that said, if I had to simply guess, I'd say that maybe what you're seeing
is a hard shadow from something, if you have other objects in your scene.
Adding finish {diffuse 0.5} and maybe adding a white sky_sphere to your scene
would help you determine if you're just not reflecting any light from occluded
surfaces.
- Bill
Date: 3 Feb 2020 14:04:11
Message: <5e386eab@news.povray.org>
Le 2020-02-03 à 10:30, Francescodario Cuzzocrea a écrit :
> Hello !!
> pov
> generated) :
> understand why.
> +W1920
If you had used an orthographic camera, that would be expected for any
part that are behind the camera, but your sample files are using the
default perspective camera.
Using an union instead of a merge is more effecient and render faster.
The merge is intended for transparent compound objects where internal
surfaces should not be visible.
In your case
#declare Space_Craft = merge{...}
and
#declare Space_Craft = union{...}
Will give you the exact same end result, but the second will render faster.
Date: 4 Feb 2020 03:15:31
Message: <5e392823$1@news.povray.org>
Op 03/02/2020 om 19:24 schreef Bald Eagle:
> surfaces.
> - Bill
I tested the scene a bit (not extensively, alas) and I also guess that
there is a hard shadow, possibly Earth? In tango_102 you translate your
light_source quite a bit along the x-axis! Does it get partly /behind/
the Earth?
Date: 4 Feb 2020 03:55:01
Message: <web.5e3930dc6f77a7a5c30604810@news.povray.org>
> surfaces.
> - Bill
Hi Bill, thanks for your reply !
I posted the sources at the end of the post, btw here is again the link :
https://gitlab.com/bosconovic/spacacecraft-pov/ :)
Sadly neither adding the sky sphere, nor the finish {diffuse 0.5} did the trick
for my scene :(
Date: 4 Feb 2020 04:00:01
Message: <web.5e39317c6f77a7a5c30604810@news.povray.org>
> > Hello !!
> > pov
> > generated) :
> > understand why.
> > +W1920
> In your case
> and
Hi Alain, and thanks for your reply !
Thank for the union tip ! I was using union with split_union off before
(otherwhise the object was splitted up in unpredictable way when
rotated/translated), then I discovered merge and decided to go for it as it
seemed more appropriate, but effectively using union rendering times are a bit
faster :)
Date: 4 Feb 2020 04:15:00
Message: <web.5e3935266f77a7a5c30604810@news.povray.org>
> > surfaces.
> > - Bill
> the Earth?
> Thomas
Hi Thomas, thank you for taking your time to poke with my scene !!!
The light source is translated by (more or less) the "true" distance between the
Earth and the Sun.
Said that, I also was guessing that the spacecraft could be partly behind the
Earth before and I tried removing the Earth from the scene as well as nearing
the light source to the object (for istance I putted 1.4723e2) and moving the
light source also along y and z, but none of those worked unfortunately :(
This weird rendering issue was also happening when I was using point lights.
It is very strange because if the object is right front of the camera and the
camera is pointing at the object itself then the object should be rendered in
its entirety :(
Date: 4 Feb 2020 05:35:58
Message: <5e39490e$1@news.povray.org>
Am 2/4/20 3:55 AM, also sprach Francescodario Cuzzocrea:
> faster :)
Did the union fix the problem?  (I liked this idea. I ran into a similar
issue where I thought merge was more appropriate for cutting my
mono-colored object, but it had glitches that were solved by using union
instead.)
dik
Rendered 49,882,521,600 of 49,882,521,600 pixels (100%)
Date: 4 Feb 2020 06:05:01
Message: <web.5e394f816f77a7a5c30604810@news.povray.org>
> > faster :)
> instead.)
> dik
Unfortunately no :( either using union or merge results in the same glitch :(
Date: 4 Feb 2020 09:04:31
Message: <5e3979ef$1@news.povray.org>
On 2/3/20 10:30 AM, Francescodario Cuzzocrea wrote:
> Hello !!
Hi. It looks like there is a bounding problem. My up front bet is it has
something to do with the large scale of your scene, but debug work would
have to be done to be certain. I can see it's bounding because I have a
branch of master (v3.8):
https://github.com/wfpokorny/povray/tree/fix/restore36UserBoundingControl
which restores the v3.6 ability to 'truly' turn off all bounding and it
is merged into my personal version of povray(1).
Anyway! A -mb work around hides the fact there is a bounding issue, but
given you have not many shapes and that meshes have their own 'shape'
bounding running with no bounding would likely work for you.
I'm occupied with other things at the moment, but a shot in the dark
might be to specify a bounded_by object for the satellite mesh as a box
or sphere much larger than is determined from the mesh automatically.
You would need to keep user bounding on (is it -ur or +ur...? the
default these days strips 'most' user specified bounding). Getting
ridiculously large user bounding going perhaps another way to work
around the actual bounding issue for now.
If you cannot figure out how to do all yourself, hopefully others can
assist you with determining the automatic bounds currently set and flags
or options to try this. Of late only checking in here once and a while.
Aside 2: Those tif files are really slow to parse... Surprised me.
Though I don't often work with large image files for textures maybe this
speed is normal?
Bill P.
(1) Release 3.7 intentionally - or perhaps not - changed code so
specifying -mb or +mb<count>, with a count so high bounding does not get
used, doesn't always turn off the last level bounding checks.
I noticed years back because -mb is a useful way to get the bounding out
of the way and just check the shape/solver's returned roots. However,
the pull request I submitted to fix this was never picked up and after
sitting for years I closed it out. Long winded way to say -mb would be a
work around for you - except the only way for you to use it would be to
compile my branch - or duplicate the changes in a compile of your own.
