Is there a way to make a sky_sphere show up in reflections but not in
the image? I want to create a render with alpha channel, but am not sure
how to hide the sky_sphere but still have it show up in reflections. Thanks.
Mike
> Mike
I'm assuming you've tried the standard no_image tag and it doesn't work with
sky_sphere?
>> Mike
> sky_sphere?
Correct.
Mike
>>> Thanks.
>>> Mike
>> work with
>> sky_sphere?
> Correct.
> Mike
What about the ancestor of the sky_sphere: a real sphere (0,1) scaled
large enough.
With no_image, later.
> large enough.
What about lighting? Should I set the emission to 1?
Mike
> large enough.
Okay, here is my new sphere:
sphere
0, 1
pigment
gradient y
color_map
[0/4 color srgb (<0.6,0.7,1.0>+1)/2]
[3/4 color srgb (<0.0,0.1,0.8>+1)/2]
finish
diffuse 0
ambient 0
emission 1
reflection 0
scale 2048*16
no_image
It works fine normally, *but* when I add focal blur, I can still see
stuff in the background. E.g.
camera
orthographic
location -z * 4
direction +z * 4
up +y * 2
right +x * 2 * image_width/image_height
focal_point <0,0,0>
aperture 1/16
blur_samples 512
confidence 15/16
variance 1/256
Is this a bug? Is there a workaround?
Mike
Am 08.08.2018 um 00:16 schrieb Mike Horvath:
> camera
> orthographic
> location -z * 4
> direction +z * 4
> up +y * 2
> focal_point <0,0,0>
> aperture 1/16
> blur_samples 512
> confidence 15/16
> variance 1/256
Apparently orthographic camera and focal blur don't mix well. What
you're seeing is (as far as I can tell) not the pseudo sky sphere /per
se/, but its reflection, blown up in /some/ manner I haven't had the
time & energy to analyze in more depth.
>> camera
>> orthographic
>> location -z * 4
>> direction +z * 4
>> up +y * 2
>> focal_point <0,0,0>
>> aperture 1/16
>> blur_samples 512
>> confidence 15/16
>> variance 1/256
Is there another way besides focal blur to eliminate the moire patterns
on the ground plane toward the horizon?
Mike
Am 08.08.2018 um 16:03 schrieb Mike Horvath:
UberPOV's anti-aliasing mode 3 would do the trick.
> > large enough.
> sphere
> 0, 1
> pigment
> gradient y
> color_map
> finish
> diffuse 0
> ambient 0
> emission 1
> reflection 0
> scale 2048*16
> no_image
> camera
> orthographic
> location -z * 4
> direction +z * 4
> up +y * 2
> focal_point <0,0,0>
> aperture 1/16
> blur_samples 512
> confidence 15/16
> variance 1/256
> Mike
Just a guess but would hollow in the sky sphere help.
