POV-Ray : Newsgroups : povray.general : Feature Request: Line-by-Line Parsing (Error Tracking) Server Time
15 Jul 2025 01:29:16 EDT (-0400)
  Feature Request: Line-by-Line Parsing (Error Tracking) (Message 1 to 10 of 15)
Subject: Feature Request: Line-by-Line Parsing (Error Tracking)
Date: 21 Apr 2018 20:12:56
Message: <5adbd388$1@news.povray.org>
Sometimes, when the scene files have become insanely large, and there is
somewhere a logical error in it, it is very hard to find - especially
when having to look at thousands of code lines.
I want to propose a new feature that is standard with most software
compilers: to parse a scene up to a certain selected line (number) only,
or to parse a scene line-by-line.
This way, it would be much easier to locate logical errors.
In my case, I am getting a problem with a macro texture (inside an INC
file) when calling it from my main scene file, but I don't get that
error inside that INC file when using it with a test scene file. Thus,
there must be somewhere an error within the main scene file. It has
thousands of code lines...
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Subject: Re: Feature Request: Line-by-Line Parsing (Error Tracking)
Date: 21 Apr 2018 20:50:01
Message: <web.5adbdb5bc48ed6a65cafe28e0@news.povray.org>
Right - "stepping" through.
As I think has been mentioned before, the editor isn't really part of POV-Ray,
it's a 3rd party windows thing.
Maybe there's some other editor that would allow you to do that, I dunno.
What you can likely do is insert #error directives in your code, wrapped with an
#if
Then you can declare a variable at the top of the scene, and do something like:
#if (Step = 1)
     // some #debug stuff to let you know what's going on.
     // probably best to write a macro to output the desired info
     #error
#if (Step = 2)
     ReportMacro()
     #error
Perhaps this is an indication that now is a good place to slow down, and think
through what your code does, and where the problem could be.
What's different about the test scene and the real scene?
Can your real scene code be structured better to make errors more obvious?
Can you send information to the #debug stream to narrow things down?
Are you using a beta version or a stable version?
Make a new scene, and start adding in copy-pasted bits until you experience the
error.   Or comment out sections until the error goes away.
Stepping through the code likely won't help you depending on what the problem
is.
Welcome to debugging.   ;)
Date: 21 Apr 2018 22:19:33
Message: <5adbf135$1@news.povray.org>
On 04/21/2018 08:12 PM, Sven Littkowski wrote:
> Thus,
Thousands of lines in one file is really not a best practice. Surely,
there must be a way you can break that up. Put objects and/or textures
in their own files, etc.
My movie is 80,000 lines of hand crafted SDL [1] (plus god knows how
much java-generated foo [2]).  I have 270 files with an average of 309
lines of code per file.
Plus, to take that a step further, I organize subprojects by directory.
ttlo - the launch scene
ttvo - the cave scene
ttCommon - globals
My main scene file contains just the directives to get things started.
Now I'm working on my space scene, ttso.
   #declare TTSODIR="./";
   #declare TTLODIR="../ttlo";
   #declare TTCOMMONDIR="../ttCommon/";
Those are specific for rendering from *that* directory.
Then I have a pile of includes
   #include concat(TTCOMMONDIR, "ttGlobals.inc") // global positions
   #include concat(TTSODIR, "direct.inc")     // timings for this scene
   #include concat(TTLODIR, "spaceLoco.inc")  // I built him over there
   #include concat(TTSODIR, "world.inc")      // put objects in the scene
This list of includes can be pasted anywhere because I've abstracted out
the actual directory.
I can comment out spaceLoco.inc and it still renders because in
world.inc is this construct:
   #ifdef (SpaceLoco)
     object {
       SpaceLoco
       rotate    SpaceLocoRot
       translate SpaceLocoVec
With 1000s of lines, you *will* get lost, and it helps immensely to have
some organization.
Another trick I do is, near the top of each object include I have
   #ifndef (HausDoorOpen)
     #declare HausDoorOpen=0;  // normally closed
Then if I don't bother to define a needed symbol, the object takes care
of that himself.
*Plus* :)  HausDoorOpen runs from 0 to 1. All of my public symbols do.
Then, in the object file I deal with it as needed.
   #local doorClosed =  90;
   #local doorOpen   = 210;
   #local doorRot = HausDoorOpen*(doorOpen-doorClosed)+doorClosed;
   rotate y*doorRot
Then if I decide doorOpen looks better at 200, I don't have to change
everybody that uses it. I only have to change it in that one place.
Everybody else just cares that it's open or not.
[1] http://git.buckosoft.com/gitstats/tteoac/files.html
[2] ex:
http://www.buckosoft.com/tteoac/tteoac/service?scene=ttlo!fps=23.976!type=Thrust!frame=346
dik
Rendered 328976 of 330000 (99%)
Date: 22 Apr 2018 01:44:54
Message: <5adc2156$1@news.povray.org>
Thanks for the suggestions, they are justified, I agree.
But even so, it would be useful to have such a step-parser feature.
In regards to my problem, I came already to the same conclusion and
stored the main text amount in a new file, copied only piece by piece
into the original file, and found finally the error. Still not sure how
to fix it. I will create a new thread in this sub group about it, so
look out. It will be named "Macro Problem".
Hoping for the step-parser.
http://www.avg.com
Date: 26 Apr 2018 14:05:20
Message: <5ae214e0@news.povray.org>
>> Thus,
> ttCommon - globals
>    #ifdef (SpaceLoco)
>      object {
>        SpaceLoco
>        rotate    SpaceLocoRot
>    #end
> some organization.
>    #end
> of that himself.
>    rotate y*doorRot
> [2] ex:
What if you get an error in file 153 that is caused by a flaw in file 73?
Having smaller files won't help in this case, and it's a case that can
happen very easily.
Date: 27 Apr 2018 04:51:31
Message: <5ae2e493$1@news.povray.org>
> happen very easily.
It's actually a case that happens a lot. Usually when I forget an #end.
In this case, I figure file 153 hasn't changed in years, and file 73 is
what I'm working on, so start there.  Sometimes I have to git diff for a
good visual clue where the missing #end is.
dik
Date: 27 Apr 2018 08:00:00
Message: <web.5ae31027c48ed6a6c437ac910@news.povray.org>
Yeah, I've run into this issue with closing curly braces }
That's why I really double-down on structuring my code with noticeable
indentations, comments on closing braces and #ends, and embedding #debug code
blocks into the various sections.
Embedding "opening" and "closing" #debug messages for macros and include files,
writing values of arguments passed to these to the #debug stream, and the
results of critical intermediate and final calculations can be a huge help in
tracking down what went wrong, where, and why.
Don't start writing your cvode assuming it's going to work - write it assuming
it's going to go horribly wrong, and 3 weeks from now when you can't even
recognize it as your own code or remember what you did or why --- you're going
to be SO thankful for those comments and helpful debugging features.  :)
Date: 27 Apr 2018 13:02:35
Message: <5ae357ab$1@news.povray.org>
I like that philosophy: assume your code goes horribly wrong.
But my suggestion for a Line-By-Line step parsing and for a
Until-Line-Number step parsing remains. Needed. And such a feature would
give much more convenience and support to the user.
http://www.avg.com
Date: 28 Apr 2018 02:56:20
Message: <5ae41b14$1@news.povray.org>
Don't get me started!
Oh Boy! Each time I swear to do that and, of course, forget during the
next project. I am a famous re-inventor of wheels if not hopeless
wanderer through a dark code wood. Still, I prevail in the end! ;-)
But, seriously, yes. The best advice to anybody indeed. I am now, when I
revisit an older scene, checking the state of the comments and add them
lavishly when necessary; taking out well-documented code snippets for
later use, etc.
The best checker is yourself.
Date: 28 Apr 2018 06:04:37
Message: <5ae44735$1@news.povray.org>
#end for me atm. :-(
Regards
